Alternator wiring
and obviously you have the one big wire that goes from the alt. to the battery..
Simple as that
Painless wiring (pt# 30705) makes the pigtail kit, probably Summit and Jegs too. Atached link brings you to their directions which illustrates the proper connections including the resistor needed if you don't use the dummy light.
http://www.painlesswiring.com/Manuals/30705.pdf
Depends on the alternator. Try it with the one wire, and if it dosent charge than connect the other one also. And it needs to be a 12volt source thats hot only when the key is on. Hope this helps, Eric L
