Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Neanderthal Carb Guy BS Thread
Old 03-29-2017, 06:52 AM
  #1481
TTur1996's Avatar
I wonder if your belt is not slipping and getting it hot at high rpm. Have you tried it configured like this? It will grip the crank and water pump much better.
Attached Thumbnails Neanderthal Carb Guy BS Thread-capture-_2017-03-29-06-45-35.png
Old 03-29-2017, 01:29 PM
  #1482
TXsilverado's Avatar
I've run his belt configuration to 7500 rpm with no problems. I know several guys who have routed their belts that way as well that don't have issues. we've all done it with OEM truck tensioners.
Old 03-29-2017, 03:21 PM
  #1483
Doug G's Avatar
I'll get another "test" this weekend I hope....needs gas too
Thanks
Old 03-29-2017, 04:42 PM
  #1484
Originally Posted by Doug G
Tensioner is new and manual ICT part.
I think I found an issue... alt was aligned with crank, tensioner aligned with crank...but tensioner wasn't inline with the alt. Got it inline within .100 I guess....needs another "test"
this makes my brain hurt...
if the tensioner is in line with the crank, and the alternator is in line with the crank, the tensioner and alternator should be in line. what am I missing here?
Old 03-30-2017, 04:38 AM
  #1485
Doug G's Avatar
exactly
I used a 2' level for a straight edge....so I'm guessing I missed the pulley being twisted (misaligned on the horizontal not the vertical plains)
Old 04-01-2017, 12:48 PM
  #1486
In-Zane Moderator
ZONES89RS's Avatar
Sad news. Lost a local friend last night from a heart attack. Was at the track, had made a pass and was walking the pits when it happened. He was an outstanding type of guy and he will be missed by the racing coomunity. His family will have a massive void that will not be easy. He was a member here as well.
Old 04-01-2017, 05:06 PM
  #1487
Doug G's Avatar
Sorry to hear Zane....thoughts and prayers to his family.
But I'm glad to report.....no belt throwing this "test" session.
Thoughts ? AFR log
Old 04-03-2017, 11:54 AM
  #1488
Old School Heavy
speedtigger's Avatar
I run the Corvette accessories with power steering pump and stock belt tensioner. I make regular trips to 7500 RPM and a few to 8000 RPM. Since I replaced the factory tensioner some time ago, I have never lost a belt. However, I have fried my alternator. That may have been from too much RPMs.
Old 04-03-2017, 11:56 AM
  #1489
Old School Heavy
Thoughts ? AFR log
This looks like it is saying 13.5:1 average A/F. Is that correct? If so, I would richen it to 12.5:1.
Do you have an RPM graph?
Old 04-03-2017, 04:32 PM
  #1490
Doug G's Avatar
Not yet, I need to wire up the rpm and maybe the MAP.
As for the AFR, what you think ? 2 steps up on the jets ? (also remember this is 10% Ethanol puke)
Old 04-03-2017, 04:42 PM
  #1491
Old School Heavy
Between 2 to 4 should get you there. I would start with 2 sizes all the way around.
Old 04-03-2017, 05:30 PM
  #1492
Doug G's Avatar
Trying to remember whats in it
Trying to iron out some stuff and maybe hit the track this Saturday
Old 04-04-2017, 02:51 PM
  #1493
after you richen it up a little and see if your MPH goes up, try a slightly larger squirter to see if eliminating that lean spike helps your 60' time.
Old 04-04-2017, 03:18 PM
  #1494
Doug G's Avatar
Will do.
Always did this by reading plugs....I love using the gauge, easier and see changes right now.
Old 04-04-2017, 05:20 PM
  #1495
Doug G's Avatar
OK, Tach is now hooked up
Started in the garage with the door 1/2 open...tested tach (still works) and data logger...both reading/recording.
Still thinking about the MAP....just for grins.
Would love to do the speedometer....but $$...maybe later down the road ?
2 minute log....need to find jet kit in my "organized confusion"
Old 04-05-2017, 06:21 PM
  #1496
a wideband, tach and time slips is all you need to get you there at our level...
Old 04-05-2017, 06:22 PM
  #1497
how much are jet kits? I have one that I may be willing to sell now that I don't have a carb....kept it around because i'd like to have a carbed setup again someday.
Old 04-05-2017, 07:48 PM
  #1498
Doug G's Avatar
Not sure on the kits, I usually buy what I think I need and have a bunch of jets.
I found my "kit" and need to see whats in the carb Vs what ones I have.
Old 04-06-2017, 01:28 PM
  #1499
the final piece of the puzzle for my Camaro (hopefully)
it's hard to believe it's been a year and 4 months since I've last started it. anyone know where the best place to sell my old tubular uppers/lowers off of my 69 Camaro? they are speedway control arms that are made in USA by Golden Star Auto here in Lewisville, TX
Old 04-06-2017, 03:55 PM
  #1500
Doug G's Avatar
Those in the pic ? Look new....anywho, www.Camaros.net is mainly a 1st Gen site and has a free classified area too (I'm a Mod over there)
http://www.camaros.net/forums/29-forum-classifieds/
But, now I have to ask whats going in Vs. the tubulars ?
Year and 4 months WTH ?
Quick Reply: Neanderthal Carb Guy BS Thread
