Finally Running
Old Jul 27, 2010 | 08:00 PM
stcloudguy's Avatar
Default Finally Running
Finally finished my 6.0L conversion into my '71 Nova, got it done 2 days before I left for the Car Craft Show. Was a last minute thrash when I found out the short block I purchased 2 years before for the build had a crack in it. Thanks to Schwanke Engines for tracking down a new block for me, rebuilt it and had it running in 6 days. Car has a complete Heidts front suspension, TKO 600, and a 9". Looking forward to getting it on the dyno as soon as I get a few miles on it.Finally Running-100_2798.jpg
Old Jul 27, 2010 | 08:26 PM
deuce4935's Avatar
Damn, another badass Nova build. Check out this 67' L92 build...https://ls1tech.com/forums/conversio...-nova-l92.html
Old Jul 27, 2010 | 08:32 PM
stcloudguy's Avatar
Jim B and I are car building freinds, we only live about 75 miles from each other.
Old Jul 27, 2010 | 08:50 PM
cutlass_455's Avatar
Right on, I love hearing when convertion guys get their stuff running. I went thru a swap too and had some issues. Glad you got thru yours in time.
Old Jul 28, 2010 | 11:27 AM
98SuperchargedLs1's Avatar
any videos? stock motor?
Old Jul 28, 2010 | 11:47 AM
97s10ls's Avatar
I know you can move the coils but just out of curiosity what did you do with them?
Old Jul 28, 2010 | 02:28 PM
Probly behind the engine mounted to the head. There are kits for this, and its a fairly easy mod if you got room between the engine and firewall.
Old Jul 28, 2010 | 10:18 PM
stcloudguy's Avatar
The motor is a stock 6.0L shortblock, Comp Cams 222/230 .597/.600 112LSA+2, L92 heads, LS3 Intake. Hooker 1 3/4" LT's.
There is no room behind the motor, there is only 1/2" between the RS head and the firewall. The coils and the computer are mounted under the dash. Had to sacrafice the glove box. Access to what I need to through the glove box door.
Plan on taking it to the dyno, I'll post some video and numbers after I have it done.
Old Jul 28, 2010 | 11:06 PM
ls1nova71's Avatar
That's a really sharp looking Nova! What color of blue is that?
Old Jul 29, 2010 | 12:55 AM
welldonecj7's Avatar
very nice build looks very clean
Old Jul 29, 2010 | 07:11 AM
stcloudguy's Avatar
I believe the color is called Marina Blue. I plan on finishing the interior and body this winter. The body so far is the original paint. Found the car on Ebay 3 years ago, 1 owner, central Califorina, absolutely no rust anywhere on the car!
Old Aug 2, 2010 | 01:26 PM
Schwanke Engines's Avatar
LS1TECH Sponsor
Are you running our harness and controller? I can't remember now.
Car looks great. I bet it drives awesome.
Old Aug 2, 2010 | 04:41 PM
SlvrSierra4.8's Avatar
Currently working on a ly6/tko 600 swap for my 71' Nova and was curious what motor mounts you went with? As well as bellhousing, trans crossmember and if you went w/ mech or hydraulic clutch linkage? Great looking car btw, any interior pics?
Old Aug 2, 2010 | 04:59 PM
-TheBandit-'s Avatar
Very very clean. That looks dynomite.
How did you route your plugwires through the firewall? Did you use isolators of some kind or just grommets?
Old Aug 2, 2010 | 10:26 PM
stcloudguy's Avatar
Mark, started with one of your harnesses, had Speartech add knock sensors, O2 sensors, fans, and VSS pickup.
I made my own adaptors from 3/8" plates, set the motor back as far as I could, Energy Suspension mounts without the backing plates. I bought my TKO 600 as a kit from Kiesler, had EVERYTHING with it, bell housing, clutch, cross member and I bought the hydraulic clutch also. Great kit! Posted only interior shot I have, going to get the interior done this winter.
I did use wire seperators from Taylor, mounted them to a bracket I made right where they passed through the floor.
Old Aug 3, 2010 | 09:28 AM
LS1NOVA's Avatar
Looks good! Id love to see the car in person. Send me a pm next time your in the south metro.
