Fox Body LS Swap Radiator
What style radiator do you guys recommend?
I am using a truck water pump, with the vertical angled outlet.
I will be building a big single turbo setup.
Ford Style? Chevy Style? Both inlet/outlet passenger side?
F-body radiator?
Thanks guys!
F-body radiator?
Thanks guys!
So, overall SLOW!!!
I used a 28" allstar performance dual pass when the car was put together.
I also had a -16 AN welded to the truck pump and use -16 AN upper hose
made hose routing much easier!
I am switching to an F-body setup this year so I am getting rid of the front accessories that are pictured
second pic is the waterpump showing the AN fitting
