Please Help! Jeep Grand Cherokee steering box swap on a-body
Hey guys I purchased a 1998 Jeep Grand Cherokee box for my swap. Everything bolted up fine, but when I went to install my pitman arm onto the new box it will not even come close to fitting. The splines on the new box are approx 30mm and my old box is around 27mm. Is an a-body power steering pitman arm different then a manual arm? I'm trying to swap from my old manual steering box to the jeep power steering box.
Anyone else run into this issue?
Well I picked up a "power steering" pitman arm today and found out more info.
FYI for anyone wanting to do this swap.
The power steering pitman arm is larger on BOTH ends which means it will not work with the manual steering drag link either. This has turned into a much larger project then it was supposed to. LOL
The guy I got the pitman arm from also had the power steering drag link so I got them both. Hopefully I now have all the parts I need.
