My 1963 Ford Econoline 4.8/6L80E build
Old 01-12-2019, 05:01 PM
  #261
trozfan's Avatar
Did you consider putting the licence plate in a different location so it would not obscure the diffuser?
Andrew
It was originally on the door, but I wanted everything to be symmetrical and the doors to have a clean look.
Old 01-19-2019, 02:11 PM
  #262
trozfan's Avatar
Picked up this sweet roof from a Ford Flex today. As if I needed more metal work. But I have been looking for a sunroof for years. The Flex has a very flat roof front to back, and the side-to-side curve is a close match to the van. The front is a power sunroof, the back is a panoramic panel that has (2) see-through sections in the front of it, and one large see through section towards the rear of it. I also grabbed the headliner that I will use for the built-in sun shades for each section. Should be cool!
Old 01-19-2019, 02:53 PM
  #263
Received 3,085 Likes on 2,401 Posts
Yeah, more metal/bodywork, but that roof will be SO cool, and I have a feeling you will make it look like it grew there!
Old 01-20-2019, 01:10 PM
  #264
Project GatTagO's Avatar
Received 1,433 Likes on 903 Posts
Man, that roof will be so damn cool!!!
Andrew
Old 01-20-2019, 04:43 PM
  #265
Motown 454's Avatar
Nice upgrade!
Old 01-22-2019, 10:29 AM
  #266
DW SD's Avatar
maybe the license plate can fold up or retract for when you are at the car shows! :-)
Doug
Old 01-22-2019, 10:35 AM
  #267
DW SD's Avatar
WOW! that roof with all the glass will be super cool
Old 03-18-2019, 04:04 PM
  #268
trozfan's Avatar
I finished welding the roll pan. Did the initial bodywork and shot some primer on it.
Old 03-18-2019, 04:06 PM
  #269
gdf_77's Avatar
I am in awe. It looks amazing. Done anything with that huge roof yet?
Old 03-18-2019, 04:37 PM
  #270
trozfan's Avatar
No. that is a ways down the road. Gearing up to do the Mustang II suspension/steering/driveshaft soon. We’ll see how all of that goes.
Old 03-18-2019, 04:55 PM
  #271
gdf_77's Avatar
I'll be very interested in seeing how the suspension goes. Are you looking at using the SuperVan as a driver?
Old 03-18-2019, 05:45 PM
  #272
trozfan's Avatar
Yes hopefully a daily driver. IF I ever actually get it done!
Old 04-03-2019, 02:21 PM
  #273
trozfan's Avatar
Started on the Mustang II suspension. Took out the old suspension, and cut out the original front frame rails. Started making new frame rails out of 3x2 3/16” tubing. I have everything level and square. The new rails are parallel with each other. Ready to start laying out the crossmember and making the cuts on it.
Old 04-04-2019, 04:18 PM
  #274
trozfan's Avatar
Some more progress today. Welded the spacers and tabs on the back of the crossmember. Got the crossmember notched and tacked in place.
Old 04-05-2019, 06:45 PM
  #275
trozfan's Avatar
Finished up the subframe after a very long day of measuring, cutting, welding, and more welding. Just have to weld it to the van
Old 04-05-2019, 07:03 PM
  #276
Motown 454's Avatar
Nice job it looks good.
Old 04-14-2019, 06:10 PM
  #277
trozfan's Avatar
Finally got the drivers side inner wheel well cut out and assembled the suspension and put the van down on its own weight on the drivers side. The ride height is exactly where I wanted it. I also have great turning radius that clears everything.
Old 04-14-2019, 06:16 PM
  #278
trozfan's Avatar
I also made a jig so that I can rotate the steering rack to make new mounts. The rack obviously needs to aim forward not rearward like normal cars. This jig allows me to keep the rack in its original up/down and forward/rearward position and simply spin it until it lines up with my steering linkage.
Old 04-14-2019, 06:20 PM
  #279
Good job! This thing will be such a cool cruiser!
Old 04-17-2019, 09:39 AM
  #280
trozfan's Avatar
Finally got the suspension put together and pushed the van out on all fours to check the stance. Now to take it all apart one last time to paint the A-arms, etc. Bonus security camera shot of the Ford Flex roof.
Quick Reply: My 1963 Ford Econoline 4.8/6L80E build
