My 1963 Ford Econoline 4.8/6L80E build
Old 12-09-2019, 09:34 AM
  #301
LSswap's Avatar
Just read through the entire project. Love the build!!
Old 12-09-2019, 05:08 PM
  #302
AAIIIC's Avatar
Concur that those Miata seats are in amazing shape! Nice find.
Old 12-29-2019, 08:29 PM
  #303
alllyellow's Avatar
I have a 64 and have been searching for ideas for my build. Love all the work you have done and definitely subscribed for future updates. Please keep posting.
Old 01-13-2020, 10:34 AM
  #304
tennerv8's Avatar
Holy faaack. Fab guy of the year. Your work is amazing. You've got to be 200 years old to have that amount of fab skill. How do you find the time?
Old 01-16-2020, 02:16 PM
  #305
transam5.7lt1's Avatar
Amazing, just amazing work and dedication, SuperVan is coming along looking great!
Old 01-16-2020, 06:30 PM
  #306
trozfan's Avatar
Finally made a custom bracket and got the Isuzu steering box mounted. The U joints have been a huge pain in the ***. Couldn’t find anything that fit the original Isuzu box- was either too loose or too tight. Ended up having to force fit one on there. Then I couldn’t find a vibration reducer joint from any manufacturer that was ‘in phase’ with the first joint. Spent a half hour with Flaming River and they assured me that being out of phase is fine. Especially since it is nearly a straight line from the column to the box. So yes- my joints are out of phase and I’m not too happy about it. At least I finally have a vehicle that I can steer.
Next on the agenda-
1- mount the new narrower radiator (yes another re-do). The Nova radiator is just too wide. Going with a Model A radiator.
2- fab front floor pans
3- finally tackle the rear end. Set the pinion angle and weld on the leaf spring saddles.
4- weld the rear upper and lower shock mounts
5- Get Denny’s driveshafts to make the custom driveshaft
6- plumb the brake lines, bleed brakes
7- mount shifter and get a custom shift cable (possibly from a boat setup because of the length needed)
8- DRIVE the van for the first time!!!!!!!!
Sounds simple but I am hoping to have this stuff completed by the end of summer. Will still have tons to do after that, but I need this thing driveable to keep me motivated.
Old 01-19-2020, 08:29 AM
  #307
trozfan's Avatar
Started working on the front floor pan support frame. This will give me something to attach the floor pans to in the center. This is the drivers side frame.
Old 01-19-2020, 02:28 PM
  #308
trozfan's Avatar
Got a few more hours in and worked on the passenger floor pan support. Also got the radiator mocked up and in place. Just need to make a bracket for it.
Old 01-26-2020, 01:27 PM
  #309
trozfan's Avatar
Started on the driver side floor pan. I have to make this in 4 pieces because of the shape, different levels, and the column and brake pedal coming through the floor. I am making a removable panel to be able to remove the pedal assembly bracket. I could have just welded the bracket to the frame but I like the idea of serviceability down the road. Here are 3 of the floor pieces fabbed up. One more to make by the door opening. I don’t know how but these 3 panels have taken me almost 9 hours to make. Doesn’t seem like that much work.
The following users liked this post:
transam5.7lt1 (01-27-2020)
Old 02-02-2020, 02:52 PM
  #310
trozfan's Avatar
Finally finished the drivers floor. I have 18 hours in it. Still have to make some cover plates for the steering column and brake pedal where they come through the floor. Also finished the radiator bracket and made some mounts for the electric fan. Just need to prime the floor and seam seal it.
The following 2 users liked this post by trozfan:
kpeters59 (02-04-2020), transam5.7lt1 (02-03-2020)
Old 02-08-2020, 03:51 PM
  #311
trozfan's Avatar
Mounted the shifter and made the drivers side of the center tunnel. Using a dash piece from a Ford Edge. Ended up taking the drivers air vent out and that will be where the shifter is. Will need to make a custom boot. This was the only solution I could come up with that would allow me to ‘center’ the radio and dash bezel. I’m really digging the layout. Easy reach to the shifter and the radio will be nice and close. I will come up with a different air vent for the drivers side.
The following 3 users liked this post by trozfan:
kpeters59 (02-16-2020), Motown 454 (02-15-2020), transam5.7lt1 (02-12-2020)
Old 02-12-2020, 01:49 PM
  #312
Looking impressive! O.O
Old 02-15-2020, 11:50 AM
  #313
gdf_77's Avatar
Looking great. Love how you are always looking outside of the box and beyond the next moment
Old 02-22-2020, 03:53 PM
  #314
trozfan's Avatar
Been going like crazy trying to finish all the metal work in the front. Have the drivers floor; center tunnel; upper radiator panel all complete. Just started the passenger floor and the passenger radiator cover. A few more pieces and I’ll be done. I know some of the shapes look odd but I was trying to keep everything as tight as possible. This will all be covered with carpet and interior panels/console anyways. I need to get better screws for the removable panels.
transam5.7lt1 (02-25-2020)
Old 02-22-2020, 10:41 PM
  #315
LSswap's Avatar
Progress
Old 02-24-2020, 04:54 PM
  #316
trozfan's Avatar
Also got the gauge cluster and menu switches mounted.
Motown 454 (02-26-2020), transam5.7lt1 (02-25-2020)
Old 02-24-2020, 06:25 PM
  #317
DW SD's Avatar
You are a master! Truly amazing work.
Old 03-01-2020, 04:04 PM
  #318
trozfan's Avatar
Finally finished up the floors and center tunnel. 67 hours total.
kpeters59 (03-03-2020), Motown 454 (03-01-2020)
Old 03-01-2020, 05:18 PM
  #319
Motown 454's Avatar
Nice!
Old 03-03-2020, 09:01 PM
  #320
DW SD's Avatar
super amazing work. How will you seal the panels's gaps? Are they removable for a reason?
Doug
Quick Reply: My 1963 Ford Econoline 4.8/6L80E build
