Project RIP IT- C-10
Old May 2, 2014 | 10:38 AM
  #81
static low 92's Avatar
Haven't pulled any rod caps. I think the mains were just to tight at .002
Old May 2, 2014 | 11:27 AM
  #82
rollwithit's Avatar
Originally Posted by 99VetteFRC
I need that AC bracket too!
You can use a/c bracket off mid to late 90s s10 with 4.3 v6..
Thought i'd put that out there for you!
Old May 29, 2014 | 12:09 PM
  #83
Well after 3 weeks at machine shop. Got my short block back Friday the 23rd. The ARP rod bolts eggshaped the rods was the failure culprit.
So all the rods got resized, turned crank, new rod/main bearings, new oil pump, and machine shop assembled. All back in and running since Sunday. Probably have about 100 miles on it so far and one race. Seems to be going good so far. Has 60psi at hot idle, 75 at cruise, and 100psi at WOT. Seems extreme, but ill take it over to little.
Did an oil catch can setup also, since i really don't have a pcv system, and i have a ton of oil pressure.
Old Jun 24, 2014 | 10:30 PM
  #84
rpturbo's Avatar
Damn. You have been through it with this swap. I seen the guy who is helping you tune it, post up on HP Tuner forum. Did you get this worked out yet?
Old Jun 28, 2014 | 07:08 AM
  #85
Ian Johnston's Avatar
I am a bit late getting onto this build(dont get on here all that often)
Keep at it, will be worth it in the long run. I have a 78 SWB C20 that I fitted an LS1, and 4L60E trans. Better than a small block setup IMHO.
Your truck looks good.
Old Jun 28, 2014 | 05:54 PM
  #86
slowbu's Avatar
which walbro did u get to put in the tank
Old Jul 3, 2014 | 10:03 AM
  #87
Truck has been back together for over a month. Motor has 75psi oil pressure at cruise speed, 50/55psi at idle. Been running good for probably 4-500 miles now. So i thought i would take it to track. Expectation was a high 14
Ran 14.5/14.4s Not to bad. I think it has a 14.0/13.9 in it with more timing.
1st pass
2/3rd passes
4th
Old Jul 14, 2014 | 05:38 PM
  #88
FINALLY got a functional cam sensor. So truck starts on first crank everytime now vs. backfiring etc. Super excited about that. Had a dead signal wire, I swore we had ohm'd all wires a few weeks back. But I guess not. Ran a new wire and tada, works.
I did decide to throw on my tailgate, bodywork not quite done but close. Spray bombed for now.
Plastidipped my intake tube
Did some rewiring to eliminate possibility of interference and got rid of extension harness
Pic of giving a buddy a "ride" lol
Old Sep 23, 2014 | 11:38 AM
  #89
Been driving the **** outta the truck.
Made a second attempt at the track a month or so ago, hoping to see a 13.99 pass, couldn't pull it off. Best of 14.03 @ 101. 2.1 60fts. So I had a convertor built a few weeks ago, definitely woke it up down low. I was planning a trip to track next week with a drag radial, but gonna have to wait 2 weeks because and NHRA event bumped our Test & Tune night.
My research says my trap speed of a 101 should be good for a deep 13. So I really hoping the convertor and radial get me there. Been kicking around spraying 100 shot to get me in the 12s, Spent about 10-12 hours fabing a muliti-purpose nitrous/fire extinguisher/cup holder bracket out of round bar. Pretty proud of the end result.
I haven't bought a kit yet, but a buddy has everything I need for $500 (bottle/solenoids/purge/bottle heater) so probably try and get it soon and see if I can get in the 12's before track closes.
My vehicle ADD has got me again, added a 4th truck to my line up. 1989 C30 dually crew cab. 454/th400. Plans to hammer it, paint or plasti-dip it, and have a *****in cruiser/tow pig.
Old Sep 23, 2014 | 05:08 PM
  #90
98TA6.0's Avatar
very nice. you're in the deep 14s high 13s with manifolds? i put some schoenfield LTs on mine and it woke it the hell up! ill be going turbo this winter and will post my build thread on here. love the intake by the way. if i had more motor (5.3 with LS6 cam) i would go with that intake. also im gonna steal your PCM mounting idea when i rewire my truck for the turbo kit. mine is currently on the battery tray under the battery behind the driver high beam. great location but yours is much nicer and out of the way.
Old Sep 23, 2014 | 07:04 PM
  #91
truckdoug's Avatar
nice truck. i need to grab one of them SWB squares before all the clean ones get snatched up.
also diggin the paint on the dually. i'd add some flying fish or some surfers in there lol
Old Sep 26, 2014 | 09:10 AM
  #92
Thanks,
I've been told it was a bad idea to mount it there (heat). But I wanted it as hidden and clean of an install as possible. But I've been driving it all summer in 90 degree weather with no issues. I also had to hack down the heat sinks to get it to fit back there so its even worse potential to have an over heat issue.
My winter plans are hopefully cam swap/headers. Dyno/retune. and be in 12's on motor and 11's with spray.
Old Sep 26, 2014 | 09:12 AM
  #93
The clean square bodies are starting to get tough to find and prices are climbing and I think will continue to go up. I love this one.
Dually I think will get plastidipped, since im lazy and don't want to prep and do a real paint or primer spray on that large of a truck lol
Old Sep 26, 2014 | 09:13 AM
  #94
Got my drag radials mounted yesterday, so I went ahead and used up remaining tread on my street tires....
Longest burnout I've ever done. lol ENJOY!
View Video, http://s747.photobucket.com/user/sta...gwi4l.mp4.html
View Video, http://s747.photobucket.com/user/sta...mwkpx.mp4.html
Old Oct 2, 2014 | 11:28 AM
  #95
HUGE disappointment at track yesterday.
The converter and drag radials didn't help my 60' at all. Im trying to figure out if there is another issue somewhere, or it just needs a looser converter to get me into the powerband faster.
Old Oct 3, 2014 | 03:09 AM
  #96
Jimbo1367's Avatar
Thanks for sharing !!!
Old Oct 3, 2014 | 10:53 AM
  #97
Video of last pass of night against a buddy with a lightly modded G8, his 13.7 against my 14.0
Old Oct 4, 2014 | 07:41 PM
  #98
douglee25's Avatar
What trans? What stall speed? What rear gears? What cam?
Doug
Old Oct 6, 2014 | 09:36 AM
  #99
TH350, 2800ish, 3.73, LS6 (204/218@.50 .550/.550 lift 117.5 LSA?
Old Oct 6, 2014 | 09:50 AM
  #100
douglee25's Avatar
Based on your info, you're in the right area. That cam is a little weak by performance standards, but your numbers don't seem that out of line.
You may need to go up to around 3400-3600 stall speed. The truck isn't light by any means. Keep in mind that when you start creeping up in your stall speed, your daily driver may not be so 'daily' anymore. Your mileage will suffer.
You can call the converter manufacturers and see what they recommend.
Doug
