New discoveries for LS1 into Mustangs Swaps
Old 06-17-2005, 04:04 PM
  #121
Mystic96's Avatar
Originally Posted by CMcCarthy
Out of curiosity, did you ever call McLeod directly and ask them about cobbling together a bellhousing kit? They make a universal bell for the LS1 and an adapter for the Cobra T-56, hell maybe they could combine some of the pieces from the two kits for you and come up with what you need. You REALLY should just call and ask. The worst that can happen is they'll say "sorry, we can't help".
Mcleod Tech - (714)630-3668
Have you ever tried to get through to Red, the one and only tech guy at McLeod? Man, I think it'd be easier to get in contact with the President or the Pope than it is to get a call into him!! It's busy everytime you call, and there is no voicemail to leave a message. It's the most rediculous thing I've ever seen.
So in short, yes I've called, but no, I've never been able to get though. I've even tried to contact some McLeod suppliers but they don't know anything.
Maybe someone can school me on how an LT1 T56 works?
Mystic96 is offline
Old 06-17-2005, 06:37 PM
  #122
89lx-ls1's Avatar
The lt1 t56 work only a little diff. than any other fork stlye trans and clutch.
The clutch fork has a pivot point just like most other trans between the throw out bearing retainer and the slavecylinder. The only difference is that the slave cyl. pushes toward the front of the car so it doesn't push on the diaphram of the clutch it pulls toward the back of the car. So if you were able to make something to connect the clutch cable to that fork it could basically work the same way as a t-5 the only diff. is the clutch but most clutches are 10 1/2 inches so i don't see how you could'n't just bolt that clutch on to a ls1 flywheel. The cable would be pulling the same way that the slave cyl. is pushing. Its hard to explain if i had a pic it would be easier. Also the lt1 t56 is about 1 1/4 inch shorter from the face of the bellhousing to the shifter mount that could of helped you with your shifter location.
The only thing i am not sure about is the input shaft. I talked to a guy at D and D performance and he kept saying that i couldn't use a lt1 t56 on an ls1 but i didn't understand what he meant so i hung up i got tired of listening to him blab on about a bunch of crap i didn't understand. I hope u understand everything i just wrote and that it helps u out.
89lx-ls1 is offline
Old 06-18-2005, 02:18 AM
  #123
jbk240z's Avatar
Default More ideas.....Mystic 96
Ok, lets try this one, A T56 consists of 4 comcponents: bellhousing, adapter plate, center section, tail housing. Apparently, the center sections are very similar between makes (viper, ford, gm), and the bells, adapter plates, and tailhousings can be interchanged. Check out this link, http://www.chevyhighperformance.com/...ns/index1.html
The problem with changing an LS1 bell and adapter plate to an LT1 bell and adapter plate is the LS1 input shaft is longer, see pic 1 LS1 on the right. The longer input is necessary with the LS1 as the crank is farther foward as compared to an LT1. This means a spacer/adapter is needed between the bell and trans adapter plate. See ebay item #7980650273. Now, the LT1 bell is shorter than the LS1 bell, (LT1 bell is 4.9 inches, LS1 bell is 5.5 inches) this along with the longer shaft is why a ring such as this is needed. If this all works out, you can then adapt the LT1 clutch fork assembly (which is very similar to the old type mechanical setup), to your existing Mustang clutch cable by maybe cutting off the end of the LT1 fork and weld on the end from the Ford T56 fork, then just a small bracket would be needed to hold cable end, maybe cut this piece from ford T56 and cut LT1 slave cylinder pocket and weld accordingly. See pics for reference. Ok, try this, a bracket/adapter can ordered or made. See last pic. This allows the retention of the factory T56 clutch master/slave combo. Of course it probably would require a few mods to work on a stang. The stang clutch cable quadrant would be unused, a suitable hole close to stang brake master cyl. would need drilling, and a clutch master pushrod/pivot point would have to be attached to clutch pedal arm as well. This custom bracket is made from aluminum flat stock and features the proper 22-degree angle for the T56’s hydraulic master cylinder. This bracket, along with the corresponding clutch pedal tab, which gets welded to the factory pedal, must be used to install a T56 hydraulic pull-off-style clutch. They are both available from Westcoast Connections, which can be reached at 707/546-9714. Again these are just ideas to ponder, no guarantees.
File Type: bmp
File Type: zip
File Type: zip
File Type: zip
File Type: zip
jbk240z is offline
Old 06-18-2005, 02:42 AM
  #124
jbk240z's Avatar
Lightbulb some research links....
ddperformance.com
keislerauto.com
fortesparts.com
rsgear.com
transmissionadapters.com
a simple cable bracket idea, I know it's hydraulic in the pic, but same idea could work. See pic 1.
When I get ready to do this swap, I may try to use the ford T56 with an LT1 bellhousing, clutch assembly, adapter plate, adapter ring, and LS1 input shaft. This would minimize the mods to trans crossmember, driveshaft, shifter hole, etc. I know, another crazy idea. Maybe I should a couple and go to bed.
To view pics: click on link, then click on save, not open, this send pics to your My Documents folder, which then you can hopefully view.
File Type: zip
jbk240z is offline
Old 06-18-2005, 12:44 PM
  #125
Chevystang's Avatar
Default Mustang conversion
Hi Mystic, I am beginning a LS1 powered Mustang (plan to begin buying parts this week) and would like to be able to contact you if I have any questions. Is there a phone number I could call you at?
I would really appreciate it.
Thanks!
John Lownik
Queens, NY
e-mail: johnlownik@msn.com
Turns out an LS1 will bolt into a Mustang like it came from the factory...
Using a 4.6L factory Ford K-Member and factory 4.6L Cobra motor mounts, slightly modified, the LS1 slides in and fits great while using the factory GM F-body oilpan and exhaust manifolds.
The factory Ford motor mounts only need to have the 2 front holes rounded out just a little with a drill bit, and the 1 back hole needs to be cut and moved about 1/2" and rewelded.
The factory GM F-body manifolds will clear the steering shaft, but the flange rubs the steering shaft. The flange will need to be cut and have about 1" of pipe installed then have the flange rewelded for enough clearance. That is of course unless you have custom headers made.
The first pic is the driver's side mount, second pic is the passenger side mount, third pic is of the modification needed on the motor mounts, and the fourth pic is of manifold to steering shaft clearance.
**UPDATE about tranny mounts on Page 5...**
Chevystang is offline
Old 06-18-2005, 01:52 PM
  #126
Mystic96's Avatar
jbk240z...your research is amazing. Those pics are just a little small to get much detail though.
I see that the LT1 uses a clutch fork, and I could definately attach a cable to the end of it to pull the fork and engage the throwout bearing. I'm just not sure what is involved in bolting a LT1 T56 to a LS1. I've searched this website, and on Google, and most say it's not worth the trouble. But of course they're not doing hybrids...they're trying to swap them in for their own broken T56s in F-bodies.
Chevystang...best bet is to PM me here or get to me though emails.
Mystic96 is offline
Old 06-19-2005, 12:52 AM
  #127
jbk240z's Avatar
Cool Pics detail....
Mystic 96, I had to compress the pic files into a zip format, because when I tried to post them here, the attachment manager said the files were too large. Even then I had to erase parts of the pics to shrink the file. Anyway, if you are interested, I could try emailing the pics to you, maybe the view will be better. Apparently all you would have to do is change the LS1 bell and adapter plate to LT1 parts, and add the adapter/spacer between bell and plate. I'm not sure this is 100%, so I will continue my research............
jbk240z is offline
Old 06-19-2005, 05:20 PM
  #128
DopeFedZ's Avatar
Hey Mystic if you were putting in a 4l60e would this swap be easier or would there be any probs with using an auto over the M6?
DopeFedZ is offline
Old 06-19-2005, 06:47 PM
  #129
CHEVYNOTCH90's Avatar
i have a 355 small block may not be a ls1 but it sure whoops them....... also a th350 tranny best of both worlds light weight notch with a good power plant ...
CHEVYNOTCH90 is offline
Old 06-20-2005, 01:42 AM
  #130
VTESPEED's Avatar
4l60e would be a way easier swap
VTESPEED is offline
Old 06-20-2005, 02:49 PM
  #131
Mystic96's Avatar
Not sure about mounts or shifters, but there isn't any clutch setup to fool with, so I'm sure it'd be easier.
Mystic96 is offline
Old 06-20-2005, 02:57 PM
  #132
30th TA 0219's Avatar
who the hjell would want to do something boring like that?
30th TA 0219 is offline
Old 06-23-2005, 07:56 PM
  #133
terryr's Avatar
The THunderbird Turbo Coupe used a hydraulic clutch. It mounted in the steering shaft hole of any fox. Maybe you can adapt it.
http://members.shaw.ca/pekpress/HydraulicClutch.html
terryr is offline
Old 06-23-2005, 08:11 PM
  #134
turbo-max's Avatar
wow...that's all i can say
turbo-max is offline
Old 06-23-2005, 08:20 PM
  #135
Brains's Avatar
Boring?
Brains is offline
Old 06-23-2005, 08:55 PM
  #136
Good luck with TC stuff, only the 87/88s came with the hydraulic clutch, and they're getting harder and harder to find. I can get oyu a pedal set-up though!
Try www.turboford.org
Old 06-24-2005, 01:05 AM
  #137
jbk240z's Avatar
Lightbulb An answer at last???
Is this the answer? It sure seems this would be the way to go. I never knew this setup existed. Those ford engineers are clever after all. I really think this can work with only minor mods. Great idea, TerryR! I'm going to the boneyard a.s.a.p. and try to find a Turbo Coupe setup, there was an '87 or '88 model there last time. Finally this is what seems to be an easier way out, as I have been trying to come up with something.
Thanks again for the idea terryr
jbk240z is offline
Old 06-24-2005, 01:56 AM
  #138
Mystic96's Avatar
I was sure there were some Ford cars with hydraulic clutch setups. The Ranger I knew for sure had one.
The master cylinders pictured on that webpage look almost identical to the stock F-body master cylinder. At least the Ranger one does.
I'm assuming that is a clutch pedal out of a Thunderbird? I doubt the clutch assembly from an '88 T-bird would swap into a '96 Cobra.
Mystic96 is offline
Old 06-24-2005, 02:01 AM
  #139
TT_Vert's Avatar
what are the odds of someone producing an ls1 fox body header? Im not the best weith a welder. In fact my garage wont even support one
Dave
TT_Vert is offline
Old 06-24-2005, 02:32 AM
  #140
Mystic96's Avatar
Also, this doesnt get past the fact that there isn't much room on the firewall or floor to mount the master cylinder and connect it directly to the pedal.
If the space was there, I'd just drill a hole big enough to mount the F-body master cylinder to the stock Mustang clutch pedal. I'm worried the only place the master cylinder will fit well is in the old clutch cable location, and this is on the firewall, almost directly in front of the gas pedal location.
I've looked at taking the top of the F-body pedal (where the master cylinder attaches) and putting it where the clutch quadrant is. This would work but as the pedal rotates up, it comes in contact with the metal pushrod of the master cylinder before it starts to push the pushrod in.
Mystic96 is offline
Quick Reply: New discoveries for LS1 into Mustangs Swaps
