1998 Harness 220 and 230 dash harness plugs
Alrighty, I've been searching for 3-4 days trying to find the pinouts for these on a 1998 Harness (Camaro). I've got the C101-C105 completed and ready, but the engine harness -> dash connections don't seem to be documented anywhere.
I was just hoping someone around here might have the pinouts of those connections documented.
I am aware that I can trace the wires though the entire harness, but I'd VERY much like to avoid that if at all possible.
Thanks a lot,
Blake
Thanks a lot,
Blake
This will explain alot....but get ridd of the 98 ECM its abad "year only " GM
"mistake".
https://ls1tech.com/forums/showthrea...69#post2894269
my 99 and up harness pin out Atten. A4 car!
https://ls1tech.com/forums/showthrea...1&page=1&pp=20
some inside from mr.dude
https://ls1tech.com/forums/conversions-swaps/317372-unidentified-harness-connectors-question.html
this explains the connectors and pin outs
"mistake".
Yeah,I've looked through those previously (I've read like 75-80 threads on it).
For a few reasons I'm keeping the '98 harness/pcm for now. I want to rule out other wiring/mechanical issues before I redo everything, and I also have HP Tuners for a 98, and don't particularly want to buy it for another year PCM, as that's a touch pricey.
I do appreciate the advice, and I'll probably swap to a later model harness/PCM when I do my turbo setup later on. For now I just need to find the 220/230 pinouts for a 1998 F-Body harness... which is surprisingly difficult.
I'm sorry if I'm missing those pinouts somewhere in the posts you linked. I am blind from time to time.
Blue (230) Plug Automatic 98 fbody
A GRY clutch anticipate signal v6 only!
B Brown-wht service engine soon indicator feed
C not used
D wht tachometer signal to intrument cluster
E dk Blu Theft Deterrent Fuel Enable feed
F DK GRN/WHT A/C Request signal
G ppl brake pedal switch output-torque converter clutch v6 vin k auto trans
G brn fuse output ignition 3 type III fuse v6 vin k auto trans
H lt blu-blk (automatic) tcc switch power feed
J orn-blk (automatic) park-neutral feed from transmission range switch
J lt grn back up lamp feed v6 vin k man trans
K ppl output field service enable
98 LS1 PCM to Dash Harness
White (220) Plug
A red generator feed to intrument cluster
B tan oil pressure to intrument cluster
C brn-wht low oil level indicator
D not used
E not used
F blk-wht 451--no note in GM book must be ground!
G grn-wht vss
H wht skip shift indicator man trans
J yel-blk vehicle anti-theft system starter enable relay output-coil
K dk grn coolant temperature feed to intrument cluster
Funny why you guys in the US dont just order a shop manual set...???
we paid for the 3 book set 98 fbody manual 560Euro till the donkey van pulled on our club yard
The LS1 swap is going so dammmm slow cause every little thing needs to be
imported
Thanks! That is all I needed to finish my swap.
I didn't order the shop manual because I had 95% of what I needed to complete it, without having the manual, and I have the FULL diagrams, but they don't show the plug pinouts. Besides, I figured someone around here would have that info.
Thanks a lot sir, if you're ever in the states, I owe ya a beer.
I miss my Highschool in Marion/Kansas!
Hot nights in Long Beach......
Racing on a 6 lane Ventura highway at night ........
And my GM Dealer in Cerritos S & J Chevrolet.....
digitalsolo any pics??thanx for the
From carb fuel **** to
TPI
to a LSX monster ......looking like a stock jap...nice sleeper
Saw the other thread but overlooked ya name back then!
Did you use the RX fuse box????
Or are you using the Fbody underhood relay/fuse box????
If someone reads this i would like to see a fool proof pic of the Fbody harness with the relay/fuse center ...???
Thats the last thing i havent really worked thru!
I will run the Fans of the CPU
I will fuse the Fuel pump off the harness
Can i skip the underhood fuse/relay stuff then???
TPI
TPI
TPI
I'll have some pictures and diagrams of my wiring setup next week sometime, no time this weekend unforunately.
edit: To clarify. I'm using the stock RX7 harness for all power/lights and juice to the ignition switch, and just tying off the factory ignition harness on the RX7 to give juice to the fuse block that I'm adding in the glovebox, which will then connect to the LS1 engine harness. I've done another RX7-LS1 this way a month ago, and it worked out quite well.
Hope that makes sense.
Originally Posted by Oscar Will
I have all the factory GM stuff including connector end diagrams and pin-outs. If I can help just holler!
Well, to bump this back up....
I'm missing one more wire... I can't find where the engine harness connects the OBDII data wire to the dash harness? Everything else is all wired up...
edit: My best guess so far is "Field Service Enable; C230 K ppl" That's the color of the wire on my OBDII connector... but I'm not sure why it doesn't say Serial Data or somesuch.
,,,,,any pics??
I will look it up in the shop manual after lunch
Mario
Mario
I'm just trying to figure out which of the wires in the 220/230 plugs is the serial data line for the OBDII connector. From referencing the naming on the list that Magnus gave, and crossing the PCM pinout colors, it appears that it's the purple wire in plug "K" on the blue "230" plug, which is "field service enable" as that is also it's location on later 99+ harnesses as well. I'm just trying to verify before I wire it up and cook my HPTuners or something else bad.
All of your help is much appreciated!
Pics? Not sure what you mean...
Ground Distribution:
Black-4
Black/White-5
Power Distribution / Fuse Block:
Orange-16
Powertrain Control Module:
Purple-2 (Serial Data Class II)
Tan-9 (Serial Data UART)
Is this what you're looking for?
Originally Posted by ACW
I'm not sure how that 220/230 stuff relates to this, but it looks like there's supposed to be a Data Link Connector (DLC) that OBDII tools connect to, with these connections in it:
Mostly, I just need to figure out if the "field service access" title in the book = "Serial data class II" in reality.
Making sense?
