Conversion folks please list your conversion in here
Old Feb 8, 2006 | 08:08 PM
  #421
Wardrum's Avatar
Default '57 Bel Air LS-7
1957 Bel Air 2dr hardtop
AME tri-five chassis
LS-7 engine
T56 Tremec trans
Old Feb 9, 2006 | 09:37 PM
  #422
LS1Bandit's Avatar
Just getting started with it ...
'78 T/A "Bandit Style"
'01 LS1 + T56
More info to come ....
Old Feb 11, 2006 | 02:38 PM
  #423
Norm '88 GT's Avatar
The Beretta has been sitting as I decide what to
put in it engine wise after the block cracked from being beat on after it was stolen. I had a 3.1 bored .030 with a bunch of intake and exhaust work and topped it all off with a Powerdyne supercharger.
The Fiero guys are big inspiration with
the larger choice of engines but Northstars V8s are
expensive and cost more to replace. Fitting it in
the front to the stock manual is limiting. I really
want a V8. Looked at putting a rear differential in
the Beretta...independent or solid... C5 torque tube
setup is novel and within an inch of the Beretta wheel
base and width. It includes the front and rear
subframe as one piece housing the full suspension. Some cutting will be required
and adapters made to fit the Beretta chasis to the
Corvette bottom.
Here is what the running gear would look like:
http://norcal-cobras.com/GTM/gtm_bui...s/IMG_3173.jpg
If I am going to spend couple of thousand for a good boosted V6
setup good for about 300whp I am going to need
brakes...another couple of grand. The open differential with 260 wtrq is no fun when one of the wheels decides to hydroplan. For few grand more I could have the ultimate in chasis running gear as the slavaged C5 might be the ticket with all aluminum
subframe. I might even loose weight from the stock
2700 lbs. replacing steel subframe with aluminum. The rear trailing arm does weigh over 100 lbs. without wheels and the front subframe cradle has got to weigh in close to 700 lbs. wet as it was difficult to slide on the garage floor this past week. Lots of parts for sale! I
don't know if the Z06 for a few grand more would be
worth it since the I probably will not have to do
anything to the suspension and aftermarket bolt-ons
are plentyful for the 5.7 V8. Just cost and time as a constraint. But bookark this page for future updates.
Here is a C5 panel fitted up to the Beretta door.
http://i29.photobucket.com/albums/c2...oorskin008.jpg
http://i29.photobucket.com/albums/c2...oorskin007.jpg
http://i29.photobucket.com/albums/c2...oorskin006.jpg
http://i29.photobucket.com/albums/c2...oorskin005.jpg
http://i29.photobucket.com/albums/c2...oorskin004.jpg
http://i29.photobucket.com/albums/c2...oorskin002.jpg
http://i29.photobucket.com/albums/c2...oorskin001.jpg
http://i29.photobucket.com/albums/c2...oorskin003.jpg
The skin fits surprisingly close to the stock door. The dew strip on the bottom of the window fits relatively snug and the bottom is flush. The door pull will have to realigned and door latch end of the C5 skin has a scallop in it exposing some of the door innards. I'll probably just add a filler panel.
Old project:
http://www.beretta.net/board/ib3/iko...act=ST;f=9;t=8
Norm
http://www.beretta.net/board/ib3/iko...f=9;t=261;st=0
Old Feb 12, 2006 | 07:34 AM
  #424
joelvette's Avatar
1973 firebird formula 6.0L ls6 intake, cam(?), hooker headers, p&p 317 heads, 1.7 harland sharps, comp cams valve train. 4l60e tci t/c, transgo shift kit, corvette servo. 10 bolt auburn posi, 3.73. brp install kit, global west a arms & bushings, edelbrock shocks, eibach coils, vbp leafs, baer sports, nitto 450's, 17" wheels (?). 92 t/a seats, cruise, elect mirrors,locks,windows.
right now these parts are spread all over the house. good thing im single or i'd be divorced.
joel
Old Feb 12, 2006 | 03:36 PM
  #425
87Ls1Camaro's Avatar
1987 Camaro Z28
Swaping in 98 LS1 and 4L60 (A4)
Fun project almost got everything done
Attached Thumbnails Conversion folks please list your conversion in here-dsc00073-1-.jpg   Conversion folks please list your conversion in here-dsc00090-1-.jpg
Old Feb 15, 2006 | 07:15 PM
  #426
1 Fine 69's Avatar
1969 camaro, global west front control arms, dropped rear springs, moser rear with 3:73 Budnik fat lips 17 in front 18 in rear and
ls7 or bored ls2 being put in along with t 56 soon!
Old Feb 15, 2006 | 07:25 PM
  #427
Glenntx's Avatar
1993 Jeep Wrangler, spankin' new 6.0, used 4l80e, np241, Dana 60's.
Old Feb 15, 2006 | 10:31 PM
  #428
dynosmith's Avatar
68 vette
original - 327/300 and TH350
swap - 04 LS1 and 4L60E
Old Feb 15, 2006 | 11:37 PM
  #429
THIRD-GEN92's Avatar
1992 camaro rs
swaping in a 00 ls1 with a GM TKO II 5 speed, Forte parts connection hooked me up with a custom pilot bearing that well make it work with the ls1.
Old Feb 17, 2006 | 08:16 AM
  #430
99c5vert's Avatar
My conversion (Rotus 7) is ON THE ROAD!
Here's a very short vid of my tires being hopeless
http://filebox.vt.edu/users/arebrahi...ioncropped.wmv
and a pic of the engine bay
Old Feb 20, 2006 | 12:59 AM
  #431
AndreS's Avatar
my 86 Mazda RX7 is getting a LS1/4L60E from a bent 99 Camaro.
just finished getting the motor out of the camaro... and ordering parts. so basically, I'm just getting started... and selling off what I don't need.
I've already been digging up info on the swap, and will continue to do so... I'm sure i'll have unanswered questions when I'm in the thick of it.
Old Feb 25, 2006 | 08:39 PM
  #432
jim57's Avatar
Default 57 Chevy
57 Chevy with "Car Creations" modified frame
LS2 crate w/ T56 6 speed
Frame ships next week, body to the paint shop the week after.
Old Feb 25, 2006 | 09:08 PM
  #433
jim57's Avatar
LS-7 engine
T56 Tremec trans
I have just started a similar project with LS2/ T56 frame by Car Creations. Would appreciate any words of wisdom.
Old Feb 26, 2006 | 10:28 PM
  #434
Bagg'd99's Avatar
1969 Caprice 4Door HTDP
2002 6.0 w/4L80E
Old Mar 1, 2006 | 09:56 AM
  #435
Wardrum's Avatar
The goal for my '57 is to create a great handling street classic with good horsepower and braking. Received the AME chassis 1st week of February. The body has been dipped to completely remove all paint, rust, etc. We fit the body onto the chassis last week to check all clearances and panel fit. Everything fit better than expected. This week we will be fitting the engine and transmission. After all this mock up work is done, everything will be disassembled. The body will then be E-coated before we start paint and final assembly.
Send me a PM about your project so that we can keep in touch.
Old Mar 4, 2006 | 07:14 AM
  #436
nitrovette's Avatar
My conversion is an electronblue 1973 corvette ,i started from scratch with a new 99 ls1 block and added all 2004 internals with arp fasteners.I modified my hooker sidepipes and mated them to ls1 flanges so i could retain the sidepipes.Its backed by a modified 700r4 with a 2100 stall and 3.70 gears.Heres some pics of what ive done to it.
http://community.webshots.com/album/175347169dDabMZ
Old Mar 7, 2006 | 10:49 PM
  #437
nitsudls1's Avatar
just get'n started
69 half ton short bed smooth side
98 ls1/4l60E
Old Mar 8, 2006 | 06:53 PM
  #438
Victoria's Avatar
1989 Firebird Formula 350
Pics upon request lol
Jen-
Old Mar 11, 2006 | 03:48 AM
  #439
NIIN20's Avatar
First off, nice looking forum. Looks overwhelming with information!
My conversion will be starting later in the year after I finish my rolling chassis. I am working on a 67 Chevy II station wagon which will be getting a single turbo'd LS7 "Warhawk" block and headed engine. I've been torn back and forth between SBC and BBC for the last few months but once I saw the World Products "Warhawk" stuff I knew thats exactly what I needed to build. If things go my way I am aiming on dipping into the 7's on drag radials. I am starting this project from scratch right now and have been buying alot of my parts for the chassis and hope to have it back in the shop for the 25.5 chassis buildup withing the next 6 weeks. I am just trying to get the chassis done by Hot Rod Magazines Drag Week in which were gonna drop my friends SBC w/ an F-2 in it. After that I am gonna begin the new LS engine build up and hope to debut it early '07. Looking foward in "sponging" up all the info I need since I am pretty new to the LS stuff. Thanks.
Old Mar 18, 2006 | 10:31 AM
  #440
wagonmaster's Avatar
Lightbulb 1939 Chevy Sedan
Currently 327/turbo 350-12 bolt
On the gound to go in:
2003 6.0 and 4L80E
[IMG][/IMG]
[IMG][/IMG]
