Conversion folks please list your conversion in here
79 Chevy C-10, 2000 5.3/4L60E
http://www.performancetrucks.net/for...d.php?t=406994
Hey man, how you doin? Long time no see lol. I cant wait to see your project up and running!
Ok folks, I need some help from all of you great wizzards. I am doing the LS (havent decided which one) into my 55. I need some physical dimensions.
All I have now are block (empty and dead), heads and intake to do the mock-up. Can someone please measure from the face of the block (not the cover)to
the outside edge of the balancer (sans pully/s) and also what diameter is the balancer? I am trying to decide what engine setback to use.
I have no idea what it does on the track yet, I want to get it dyno tuned first because I just switched to a smaller supercharger pulley, then its track time
As far as clearance, I run a 4" cowl hood now.
i just got my 79 c10 to halfway presentable shape, but dont know how to load a video of it. its got custom interior, a forged383 ls1, custom blower cam, fast90/90 setup, pacesetter longtubes, procharger d1sc w/intercooler, performabilt level3 4l60, 3200 vigilante stall, and a 12 bolt just to name a few things. my tuner says he believes we`re pushing around 600 rwhp with the 42lb injectors maxed out way early! i have a set of patriot ls6 heads, ls6 intake with a bbk80mm throttlebody, and a meth kit im going to put on it this spring. im going for 800 rwhp. i have a walk around the truck and a drive by i want to load, please help!
I'm in the early stages of swapping a 2004 (LQ4) Vortec 6.0 from a Yukon into my 88 Jeep YJ Wrangler. I have the old 6 cyl and tranny out, and the SYE kit and tranny adapter installed in the Xfer case. Am now cutting the old motor mounts off, and trying to figure out which of the old wiring I can abandon!
Starting swap of SBC LC9 5300 Vortec (all aluminum, Flex Fuel and AFM) into my 97 Land Rover Discovery. I would appreciate it if anyone has mechanical drawings, a pdf file or knows a location where I can get dimensions of the back of the block where the locating pins and bolt holes are for the transmission to mount. My idea is to fab an adapter plate to bolt the Rover ZF auto tranny to the back of the LC9.
Thanks,
Richard (Tellicorick)
Thanks,
doing a 00 LS1/4L60e into a 66 2 door sedan Nova. Got the block/oil pan and trans sitting in the subframe this weekend, made up the engine adapter plates to old style engine mounts and fabbed up the trans crossmember. Just need to drill holes for the crossmember and the eng/trans will be mounted.
I have a 1993 LX Coupe and a 00' WS6. The Trans-am is pretty much stock with a converter , exhaust and of course nitrous. My mustang has a 331 stock block stroker motor with a Tremec 5 speed transmission. With a pretty much stock WS6 at full weight I have gone deep into the 11' with the 10's in very very close reach. I drive the trans am to work and every where else i go and it still amazes me how it can run so well at the track and still be just as reliable as it was from the factory. I am getting ready to pull the motor and transmission out of the mustang and purchase another Ls1 motor and transmission to begin the transplant. I was thinking about going with the carbeurated set up with some minor head work and possibly a GM Hot cam. I will probably use a stock 4l60e with a converter and of course a good bit of the gas. I know they make alot of parts now for this proceedure but it is nice to know that there is people here who are going and have gone through the same steps that i am about to take. Any advice during this would be greatly accepted and I thank you all in advance. Good luck to everyone else.
I have just received my 2002 Mercedes E, now with:
LS1
AFR Mongoose Heads
Long Tube Headers
T-56 6 speed
Centerforce dual friction clutch
Stebro Exhaust
SL 500 Launch edition Wheels - staggered
Brembo Gran Tourismo Front Calipers
H&R Sway Bars
H&R Shocks
Custom Stereo
E55 AMG interior (to be installed)
This may be the first of its kind done.
LS1
AFR Mongoose Heads
Long Tube Headers
T-56 6 speed
Stebro Exhaust
H&R Sway Bars
H&R Shocks
Custom Stereo
