Conversion folks please list your conversion in here
Old Apr 17, 2011 | 01:01 AM
  #1081
markeheiden's Avatar
78 Full Size Jeep Cherokee Chief
2007 LC9 5.3L
2006 4L65E
NP241 Transfer Case
Old Apr 19, 2011 | 07:07 AM
  #1082
StrongCo's Avatar
2007 Jeep Wrangler (JK) - Corvette LS1 swap...
Old Apr 19, 2011 | 07:16 AM
  #1083
46Coupe's Avatar
1946 Chevy Stylemaster Business coupe.
2006 5.3 L59
Old Apr 19, 2011 | 07:36 PM
  #1084
blownnova's Avatar
67 Nova
2004 LQ9/TKO-600
Old Apr 28, 2011 | 07:32 PM
  #1085
i1aroc's Avatar
69 Camaro LS1/T56
Old May 2, 2011 | 07:35 PM
  #1086
Bowtiedford's Avatar
93 Mustang coupe
LS1 A4
Old May 3, 2011 | 02:31 AM
  #1087
Rare96WS6's Avatar
Default conversion project
1968 Camaro Z-28 LS2 T56. Finished!
Old May 3, 2011 | 06:40 AM
  #1088
GTMLS3's Avatar
1991 Camaro RS
LS376/480
4L80E
9" Ford Trutrack
Old May 7, 2011 | 05:34 PM
  #1089
Blevinator's Avatar
1968 Camaro
Engine,drivetrain,etc.
LS3 (from 2010 Camaro) Lingenfelter Heads,Comp Custom Grind Cam,560 Motor HP
Built T56 Transmission(700hp,tq),BRP Hotrods poly mounts,crossmember.McLeod twin disc clutch (800hp) (mechanical linkage),custom 1000hp aluminum driveshaft and u joints.Driveshaft safety loop. Husler 1 7\8 ceramic coated stainless steel headers,Custom 3" exhaust with custom x-pipe and Magnaflow mirror polished mufflers (straight thru design),GM Performance LS3 kit with computer, harness,etc, Entropy LS3 Radiator with dual fans \ aluminum shroud, Kwik Performance accessory brackets. Accesories include 98-02 160 amp alternator, sanden a\c compressor, new power steering pump. Car has power steering with quick ratio gear box. DSE narrowed fuel tank with Walbro 255LPH in tank pump. Global West Upper and lower control arms (front),Superior Spindles 2 inch drop spindles front and rear, Oversized sway bars front and rear. Front and rear power disc brakes with Hydroboost, built 10 bolt rear end with Eaton posi,3:55 gears. Optima battery relocated to trunk,all wiring in car is Painless Wiring.
Interior to include: Dakota digital guages, new deluxe door panels,new headliner,carpet,dash pad, all window glass,steering wheel, Flaming river tilt steering column, ProCar front seats and rear seat cover,JVC Kameleon in dash\cd\dvd. Two MTX amps,Focal component speakers flushed into black fiberglassed kick panels,jl subwoofer in custom enclosure, 3 point factory looking seatbelts, custom Fesler Built center console.
Exterior: Brand new custom paint in Sebring Silver.
Painted Rally stripes, Car completely undercoated with
3M Body Shutz, POR15 Chassis coat
LS3 emblems: Billet GM
All new original or OER trim.
Chrome rally wheels, BFG rubber
I have 100 percent of the parts
Car is in paint now and will be finished mechanically
mid June. I am taking many pics and will post a complete build.
Many,many hours of research!!
To add: (next few months)
DSE Mini tub
Cal Tracs
American Racing 18" wheels widened to 12" (rear)
335's in rear 285's front
12" moser rear with 3:73's
13" rotors (front and rear)
Baer C5 brake kit (front,rear)
Car is a full frame off nut and bolt resto
All steel body and NO RUST
Old May 7, 2011 | 06:25 PM
  #1090
eatrocks's Avatar
Conversion folks please list your conversion in here-dsc_0002-sm.jpg2005 Jeep Wrangler Unlimited (LJ) OEM to the jeep 6 speed with LM7 5.3, Novak Mounts and adapters.
Old May 7, 2011 | 08:50 PM
  #1091
LSCha0s's Avatar
Originally Posted by i1aroc
69 Camaro LS1/T56
Me likes
Old May 8, 2011 | 03:23 AM
  #1092
RPD_Vette84's Avatar
1991 Camaro Z28
2001 5.3L
ported ls1 intake
2002 Z28 cam
2001 4l60e
Old May 12, 2011 | 12:34 AM
  #1093
dakid223's Avatar
I'm trying to install my a/c compressor on the driver side of my 77 sb 350. Its in a 89 caprice classic but i cant find any brackets for the r4 compressor, can anyone help me and lead me in the right direction of where to find some brackets to make this work...
Old May 12, 2011 | 07:51 PM
  #1094
chevelle598bb's Avatar
1971 Chevelle
Drivetrain- 408 LS3, LS7 cam, SRP pistons, 11.2 to 1, eagle crank, eagle h beam rods, LS3 corvette accessories, LS3 corvette manifolds, LS3 intake, DIY custom harness, DIY custom tune (HP tuners), T56, LS7 Clutch, Moser M9 brace rear, Ford racing center section with detroit locker, Richmond 3.25 gears, no exhaust yet
Chassis- boxed and reinforced stock frame, C5 Z06 brakes up front, Ford explorer disc in rear with parking brake, afco 650 lb springs in front with adjustable spring cups, 3 inch lowering springs in rear 225 lb, Global west tubular upper and lower arms (front and rear), Afco shocks, Impala SS gas tank, Iroc steering box, C5 Z06 wheels powdercoated black, 275/40/18 front, 295/45/18 rear.
Body- Black for now, not sure what color I am going to paint it (possibly Atomic Sunset). SS dash with covans insert, late model GTO seats, stock console.
Some pics in the garage
Old May 15, 2011 | 02:34 PM
  #1095
CJaredo's Avatar
ok...
'82 CJ-7 Laredo
2001 LM7 with a superchips tune
advance adapters headers and motor mounts
98 LS1 throttle body
4L60E with Lokar 16" shifter and Novak t-case adapter/vss
Dana 300 twin sticked T-case
Old May 17, 2011 | 07:53 AM
  #1096
65 Countryman's Avatar
Default 51 ****** 4X4 station wagon
2002 5.3L from suburban. Muncie 4-speed with Dana 20 transfer case
76 Scout ll axles otherwise stock
Old May 17, 2011 | 07:58 AM
  #1097
Sorry
This is a 51 ****** 4X4 station wagon
Old Jun 2, 2011 | 12:09 AM
  #1098
ericindc's Avatar
Default 83 Jeep CJ7/TJ with Gen IV LH6
Jeep CJ7/TJ hybrid Jeep
Throttle down kustoms CJ7 Frame with TJ suspension
1983 Jeep CJ7 Body
d30 front, d35 rear (for now)
2005 LH6 5.3 Engine (35,000 miles)
(from a Saab 9-7x)
Just got the engine today. Complete engine, no pcm tho. Exceedingly strange oil pan tho. Will probably need a new one.
Need to source the 4L60e or 4L65e.
Have a NP231c and NP231j, so will figure out which one will work best.
Alot will depend on what transmission I will have to buy. Not sure what years will work with the gen iv pcm.
Old Jun 7, 2011 | 02:39 PM
  #1099
ScorpioV8's Avatar
Default Uk Ford Scorpio Cosworth with L33/4L60E
Looks like this:
http://en.wikipedia.org/wiki/File:Fo...v_Cosworth.jpg only not as shiny
L33 5.3 Vortec out of a 2005 Silverado 1500, 799 heads, LS6 intake, 02-04 LS6 cam/springs/pushrods, home ported DBW TB, 4L60E, 'vette LS waterpump and crank pulley, 97-00 'vette sheet metal manifolds, de-cat, no egr/evap...
car has LSD, huge discs and nice leather interior -was the flagship model back then. 2.9 V6 had 195hp, hope the LS has 395
My website has more info on our school projects.....www.trinityschoolracing.co.uk - take a look...
Old Jun 10, 2011 | 12:02 AM
  #1100
Gimme's Avatar
Default Ford 8.8/GM 10-Bolt Hybrid
99 Camaro SS
Ford 8.8/GM 10-Bolt hybrid
https://ls1tech.com/forums/gears-axl...8-project.html
Cheers,
Gimme
