Conversion folks please list your conversion in here
Old Jan 5, 2011 | 04:54 PM
  #1041
drpepper's Avatar
40 ford coupe- ls1, comp cam, 243 heads, ls6 intake 4l60e
61 belair flat top ls3, hot cam, 4l60e
57 chevy 150 2dr sedan, lsx 454, 4l70e,morrison chassis
Old Jan 9, 2011 | 01:01 AM
  #1042
the_merv's Avatar
Veteran: Air Force
1984 MONTE CARLO SS
408/T56 9" REAR
http://www.youtube.com/watch?v=h9Tl13a3nDY
Old Jan 9, 2011 | 08:38 PM
  #1043
LQ4 S10's Avatar
past was 95 s10 6.0/4l80e tr224 cam ford 8.8 rear end
current is 71 c10 longbed 5.3 with turbo in progress
Old Jan 11, 2011 | 06:37 PM
  #1044
Monte4ever's Avatar
1982 Monte Carlo
Frame and wheel wells moved in 3 1/2" per side for 345x35x18 tires and 18x13 wheels.
403 LS1 with Edelbrock intake, F1A Procharger and FMIC
Power TBD
Old Jan 16, 2011 | 07:27 AM
  #1045
8.1 chevelle's Avatar
1967 SS Chevelle a true 138 car now running a 8.1 GM based Indmar Marine engine ( Indmar guru says 450 hp 560 ft# tq.) going to see this spring going to get it dynoed . Most tq. I have ever driven
Attached Thumbnails Conversion folks please list your conversion in here-th_scan0021.jpg
Old Jan 16, 2011 | 10:51 AM
  #1046
454spyder's Avatar
Thats cool. I thought about the 8.1 quite a bit. What does it share with the GenVI BBC's? Looks like your original headers worked fine. Intakes/Cam/Valvetrain?
Old Jan 16, 2011 | 02:11 PM
  #1047
headers,engine mounts. bellhousing,flywheel (396-427) internal balanced) they say a cam from 502 will fit. I just used what was in it . ol engine will scream but rev lim. at 5800 figure enough for a big block was also told I could get studs and change rockers to the adjustable type just one other thing all bolts are metric
Attached Thumbnails Conversion folks please list your conversion in here-th_sd531149.jpg   Conversion folks please list your conversion in here-th_sd531035-1.jpg
Old Jan 19, 2011 | 02:11 PM
  #1048
Josh40601's Avatar
got a build thread or any pics of the C10?
Old Jan 20, 2011 | 08:38 AM
  #1049
bigchief52780's Avatar
89 fox 6.0/th350 with 3.73 gear and holley 750dp. check out bigchief52780.
Old Jan 30, 2011 | 04:52 PM
  #1050
tchance's Avatar
Default My never ending project
1969 Camaro LS1 and T-56
https://ls1tech.com/forums/album.php?albumid=7906
Old Feb 2, 2011 | 12:28 PM
  #1051
Kwikcad500's Avatar
77 Coupe Deville, 100K junkyard LQ4 with original rings n bearings, unported 243's, cammed, GMPP carb intake, MSD ignition, T400, 10" converter, Street n strip, column shifted, best 1/4 mile pass 11.53 with more to come.
Old Feb 2, 2011 | 08:48 PM
  #1052
S10xGN's Avatar
I saw your pix in the Carb section, awesome ride!
Old Feb 3, 2011 | 04:34 PM
  #1053
Kwikcad500's Avatar
Thanx S10
Old Feb 3, 2011 | 09:01 PM
  #1054
H-FIELD's Avatar
In the process of putting a 2000'LS1 WS6 in my 84' CJ7
Old Feb 7, 2011 | 09:53 PM
  #1055
axon360's Avatar
1) 1989 240sx Coupe
2) LS1, 00' Z28 w/ T-56 [has 4L60e currently ]
Old Feb 8, 2011 | 09:32 AM
  #1056
UR50SLO's Avatar
Hey Axon.. was that car from Michigan? I was at a event there and this girl T-boned the wall at the end of the track and I swear that's the same car.
~Scott
Old Mar 3, 2011 | 11:45 AM
  #1057
ls1jaguar's Avatar
1986 Jaguar XJS (use to be) V12, LS1 conversion with 4L60E Stock For Right Now, Daily Driver!!!
Old Mar 3, 2011 | 06:24 PM
  #1058
i1aroc's Avatar
69 Camaro
LS engine
T56
9' rear
speedtech suspension
https://ls1tech.com/forums/chevrolet...ro-swap-2.html
Old Mar 4, 2011 | 03:56 AM
  #1059
bbs350z's Avatar
2003 350z, sold my built motor tt setup, swapping in a built low comp ls1/built t56 with a gtk1000 turbo, 3.3fd lsd, should be fun lol
Old Mar 7, 2011 | 07:49 PM
  #1060
Exidous's Avatar
You planning on running a KAZZ FD LSD? The torsion style in the FD really isn't all that strong. It holds up fine in my 94 RX-7 with the 420whp LS1 in there but you get ANY wheel hop and it's gone in a heart beat. I grenaded one at atco raceway in 2006 because of a little wheel hop. Split 2 of the "barrel?" gears down the middle the long way and it wedged in between the ring an pinion. Most folks go KAZZ or 03/04 cobra IRS to handle the torque.
