Conversion folks please list your conversion in here
Old Mar 3, 2012 | 11:02 AM
  #1201
nopostduece's Avatar
1971 Nova, orange on cream, 2 door, 4speed barn find. Been stored inside sense 1980. Front disc brake conversion, 9" 4:56s, locker, on stock steel wheels with hubcaps (:
06, corvette LS2, stock bottom end, custom grind NO2 cam .236/242@50 .601/.610 114lsa, LS7 lifters, comp cromo push rods, Lunati gold duel spring kit, ported 243s, ported Victor Jr. Holley 850HP, NX stage6 plate.
Muncie M22, Center Force DFX 6puck sprung disc and 2500lb pressure plate
Old Mar 6, 2012 | 08:31 AM
  #1202
hemiqc2003's Avatar
66 Chevelle
02 6.0 carb'd with 4L60E
Old Mar 8, 2012 | 03:27 PM
  #1203
tsnow678's Avatar
1969 Camaro Z/28 (clone) Speedway blue w/white stripes, black standard interior (upgrading to the 02 Camaro Ebony leather seats front and rear), three point seatbelts front and rear, 8.5" 10 bolt 3.42:1 posi Moser axles and Trick Flow cover, 408 all-forged balanced LS stroker 11.5:1 compression ARP main studs, ARP head bolts, Katech timing chain, ATI balancer, Melling oil pump, L92 heads w/ .660" Patriot springs and titanium retainers , LS3 intake w/42lb injectors 96mm throttle body, LS7 lifters, custom Comp Cam .631"/.657" lift, 1-7/8" Dynatech ceramic coated headers, American Thunder Series 2-1/2" Flowmaster exhaust, T56 trans Hurst shifter with an LS6 clutch, LS6 valley cover, Moroso oil pan w/remote oil filter, 4 wheel disc brakes, modified stock fuel tank with a 2003 Ford F350 6.8l mid ship fuel pump and Corvette filter/regulator, Vintage Air Gen IV sure fit a/c with a Kwik bracket, GTO water pump, 08 Corvette alternator bracket w/ 08 Corvette clutch pulley alternator.
Old Mar 8, 2012 | 03:33 PM
  #1204
Twin_Turbo's Avatar
82 Corvette 04 GTO LS1/T56
82 Trans Am LS?/F body T56
Old Mar 8, 2012 | 10:05 PM
  #1205
dennymelcher's Avatar
2003 S-10 Xtreme, Extended cab, White.
6.0 LS2, 4L70e, C4 Vette Independent Rear, frame narrowed 6in., tubbed 3in., Cantilevered shocks.
Baer 13" front, C4 discs rear, all dimpled and slotted. 255/45x18 front, 295/35x19 rear.
2011 Hot Rod Power Tour, Long Hauler and registered for 2012 (Detroit to Irving, TX).
Old Mar 12, 2012 | 09:44 PM
  #1206
crowtree99's Avatar
Default 69 chevelle, lq4, 4l60e
1969 chevelle
2001 lq4, 4l60
12 bolt rear, 3.73 posi
coilover rear
vintage air
all stock so far (collecting parts)
tuned by Doc at EFI Alchemy, Green Cove Springs, Florida
300rwhp, 340torque, all stock and stock truck manifolds.
Will be happy with 350rwhp so fairly easy to reach I think.
Old Mar 18, 2012 | 05:18 PM
  #1207
schary's Avatar
Default 68 camaro Trans Am Touring car
Here are some of the latest shots..
68 camaro
modified l92 / ventura speed center serpentine drive system
t56 magnum
12 bolt
thanks for all the help !!!
Attached Thumbnails Conversion folks please list your conversion in here-img_4879.jpg   Conversion folks please list your conversion in here-img_4880.jpg   Conversion folks please list your conversion in here-img_4882.jpg   Conversion folks please list your conversion in here-img_4884.jpg   Conversion folks please list your conversion in here-img_4891.jpg
Conversion folks please list your conversion in here-img_4885.jpg   Conversion folks please list your conversion in here-img_4887.jpg   Conversion folks please list your conversion in here-img_4890.jpg
Old Mar 21, 2012 | 01:17 PM
  #1208
OneOffStroker's Avatar
I'm swapping an LM7/4L60E into my '69 Suburban this weekend. Well, that and a ton of other stuff. I'm rebuilding all of the suspension, brakes, and steering, too. Also...I have a lot of rust repair on the cowl, firewall, and floorboards. I'm shooting for near completion of everything in 4 days. Wish me luck.
Old Mar 21, 2012 | 03:06 PM
  #1209
sleeper507's Avatar
Default 1979 malibu
This my build a .79 malibu 4 door my grandma bought new .currently installing a 5.3 out of a 04 chevy ,a 4l60 e tranny ,car is lowered ,3 inches front 1 inch rear sitting on foose rims ,repainted viper blue ...interior all redone in black ,car was originally brown.
Old Mar 27, 2012 | 09:44 PM
  #1210
GreazyDaMonsta's Avatar
1979 monte carlo 305 th350
5.3 on a th350
Old Mar 29, 2012 | 06:19 PM
  #1211
sleeper507's Avatar
Default 79 malibu
I have put in a 5.3 in my 79 malibu .fairly easy swap .have the 4l60e tranny ..got the power plant and tranny and harness from just chevy trucks ..motor mount kit from brp. Fuel set up from summit ...exhaust is truck to massaged pipes to clear the frame .have to shorten driveshaft ..shifter out of Monte ss ..still need the mast oil pan ..if you put truck motor in car --- don't do it in a low one .!!! Try to get pics up
Old Mar 29, 2012 | 10:36 PM
  #1212
COBRA.LS1's Avatar
Default cobra kit streetbeasts LS1
This is a car I built several years ago and am thinking of selling. 2000 LS1 with t56 with 50% od and 4.11 rear with discs all around. Car weighs 2100 and is scary fast.
Josh
Attached Thumbnails Conversion folks please list your conversion in here-cobra-ls1.jpg
Old Apr 6, 2012 | 04:53 PM
  #1213
ls1wrx's Avatar
1991 nissan truck bodydropped to the doors
ls1/4L60e
everything is brand new. new rear end to come just got it running last night
has camaro interior dash steering column...we did the whole harness out of a 99 SS so we can tune easy and still read codes...pics saturday
Old Apr 7, 2012 | 09:35 PM
  #1214
Joe325's Avatar
1994 BMW 325i
LS1/T56
3.73 gears 40% lock up
Old Apr 10, 2012 | 01:04 AM
  #1215
73metalman's Avatar
Default Corvair
1965 Corvair 2 door hardtop
997 Porsche 6spd trans/LS4 w/LS2 intake
C5 rear suspension-rear engine application
pics -http://www.facebook.com/media/set/?set=a.10150410423292351.388985.714102350&type=3
Old Apr 12, 2012 | 11:12 AM
  #1216
maddoglou454's Avatar
Looking for a 700R4-4L60-4L60E-4L65E-4L70E-4L80E,Please contact me for a professional consultation regarding your needs. We are happy to provide you with references both here in the United States and Internationally. Be sure to check out our website at maddogtransmissions.com
Hear what our customers and fans say on our Facebook Page at www.facebook.com/maddogtransmissions
We also accept orders over the phone. Be sure to contact us and we will recommend the correct transmission for your application. For your convenience, we accept PayPal and all major credit and debit cards.
If you prefer, we can call you personally, just e-mail us your phone number.
All our transmissions are very strong and reliable, and can be used for everyday driving. Extended warranties are also available.
Thank You,
"Mad Dog" Lou
Mad Dog Transmissions
Phone 770-781-0949
Fax 770-781-0969
Web: www.maddogtransmissions.com
Facebook: www.facebook.com/maddogtransmissions
Twitter: www.twitter.com/maddoglou
YouTube: www.youtube.com/maddogtransmissions
Old Apr 12, 2012 | 08:16 PM
  #1217
Vetteman61's Avatar
1) 1937 Chevrolet 4 door
2) 5.3 LQ4 from 2003 Silverado with intake. 4l60E trans. '99 Ford Explorer
rear end.
3) My build thread:
http://www.hotrodders.com/forum/jour...ge=1&reverse=1
Thanks,
Brandon
Old Apr 17, 2012 | 12:20 AM
  #1218
Avanti's Avatar
1963 Studebaker Avanti
2011 LS3 E-Rod
Old Apr 17, 2012 | 08:39 AM
  #1219
Symon623's Avatar
Default LQ4 in a 85 Toyota Crawler
Been running a 02 4.3/700r4/203/D300 combo for 5 years and decided it was time for the other 2 cylinders..... Was actually shopping for a 5.3 but ran accross a deal on a 6.0 so here we are;
Recipient; 85 Toyota 4x4 heavily modified for rock crawling and general offroading
Donor; 03 Chevy 1500 HD
Rest of the DT; built 700r4 with lockup, NP203 range box, Jeep Dana 300 transfer case, Dana 60's Front and rear. 5.38 gears.
Here's a link to the swap;
http://www.pirate4x4.com/forum/showt...ighlight=syota
Link to Pics;
http://s715.photobucket.com/albums/w...ERS/Syota%206/
http://youtu.be/jmjWtevHYhE
Old Apr 17, 2012 | 10:13 PM
  #1220
64TypeALSX's Avatar
Default LSX in 64 Chev Malibu SS
Just getting organized for this project. Looking for a stock LS and auto transmission. Trying to decide on conversion kits and looking for step by step instructions. Any suggestions? Thanks.
