Conversion folks please list your conversion in here
Old Feb 27, 2019 | 06:19 PM
  #1781
AnnivSS's Avatar
1994 Camaro Z28
5.3L Turbo/4L80E/Moser 9 Inch
https://ls1tech.com/forums/drag-raci...rip-build.html
Old Feb 27, 2019 | 10:37 PM
  #1782
White Lightning2's Avatar
2002 Oldsmobile Bravada
Going on 2008 TBSS frame
Used rollover 2004 Buick Rainier for all wiring to retain all interior electronics functionality and have it OBD2.
All TBSS AWD drivetrain except putting LQ4 in it with i6 Trailblazer converter
Current work in progress but nearly complete.
Old Apr 10, 2019 | 01:01 PM
  #1783
soayj's Avatar
89 wrangler yj. 4.8, nv3500, np241c with sye. ford 8.8 rear 4.10 gears. man does it surprise people.
also had to add traction bar because horrendous wheel hop and axle wrap. still spring under axle.
Old May 8, 2019 | 05:32 PM
  #1784
Fixxer's Avatar
1989 Pontiac Firebird GTA
-2002 LQ4 w/95 LT1 T56 (Pull style clutch)
1978 International Scout II
-2003 4.8 w/4l60E (From 99 4.3 truck) 1990 Suburban transfer case
1992 Chevrolet c1500
-2005 4.8 w/4L60e
2004 Silverado 4.3
-2002 LM7 5.3
Old May 9, 2019 | 09:17 PM
  #1785
pdlightning's Avatar
Default LS1 into a 1971 Porsche 914
New,(NOS) crate LS1 , Y (Corvette) motor into a 1971 Porsche 914 with a modified 915, 5 speed trans. Getting help from friends because I don't want to reinvent the wheel.
Old May 16, 2019 | 12:01 PM
  #1786
BMR Tech2's Avatar
LS1Tech Premium Sponsor
I don't know that a 915 will hold up. Might need a 930 or G50
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Jul 9, 2019 | 08:23 PM
  #1787
sixtypilot57's Avatar
Default 1965 Chevy Malibu LS3 - A Body
Hi guys, getting ready to start a LS3 swap on my 1965 Malibu SS. This will be my first attempt and I hope that I haven’t gotten in over my head. Please feel free to comment and provide suggestions.
Starting point:
1965 Malibu SS
Hotchkis Suspension
Rick’s Tank w/in pump fuel pump
Donor 1984 Corvette
I just bought this last week and just have notes on the build provided by the builders exwife.
Built LS3
New 6.2L Block
I don’t have notes on crank just know that it is a 24x crank reluctor and has been “machined”
L92 pistons 10.5:1
Rotating assembly has been balanced
LS2 knock sensor
2002 camaro oil pan - TX speed says this will work in the 65 A body
Comp Cam 54-454-11
cloyes Hex a just timing chain set
Comp Cams 15850-16 roller lifters
Btian Tooley Racing pushrods
Stock LS3 Heads - machined, valves seats machined, LS3 hollow intake valves installed, stock exhaust valves
Stock LS3 intake
90mm edelebrock throttle body
I guess my biggest hurdle is ecu, wiring, etc.
Included with the corvette was an ECU, about a million wires, fuse box. I believe the ecu is out of a 2010 Sierra pickup. Pic provided. My initial thought after reading many post is to have this ecu flashed for my particular setup. I plan on buying a preassembled wiring harness maybe from PSI as I got an ice cream headache just from looking at the box of wires. I’d appreciate any recommendations.
Im not sure what transmission I will be running yet. There was a 4l60e provided with the car but the notes say that it has a 3000-3200 stall, might be a bit radical for the street for me. I have been i talks with American Powertrain about building me a tko600. A T56 would be nice but I don’t plan on cutting the floor as again I am a novice.
I haven’t seen any recent A Body conversions on the forums so any updates or recommendations are highly appreciated. Also, I will be selling the 1984 vette once I pull the motor and trans. Has new C5 wheels, brakes, and suspension. Let me know if ya have any interest. Thanks all
Old Jul 10, 2019 | 09:38 AM
  #1788
Project GatTagO's Avatar
Do yourself a favor and use all of the Holley swap components for A-bodies.
https://www.holley.com/products/engi...ap_components/
Old Jul 13, 2019 | 12:40 AM
  #1789
thanks - I would love to use all of the holley components. I do have concerns with their headers however based on the super comps that are on their now. I bought them specific for the car and honestly they were a nightmare to get in, change plugs, etc. Hope the LS ones are better. I have looked at Dougs/Hedmann but not sure since ill be using the holley mounts.
any recommendation on buying a wiring harness for the LS3? Been looking at swapspecialites and psi.
Old Jul 13, 2019 | 06:20 AM
  #1790
B52bombardier1's Avatar
For my 70 El Camino, I went with PSI for an engine harness and American Auto Wire for the body harness. No complaints. I also used the Hooker / Holley Blackheart headers on my El Camino and again, no complaints. They fit like a glove and not once did I feel the need to reach for a large hammer to make them work. And zero trouble for reaching, removing or dealing with the spark plugs.
Rick
Old Aug 10, 2019 | 11:31 AM
  #1791
Swapper's Avatar
just started on a 1990 Camaro. its gonna be a 78/75 turbo'd 5.3l, t56 car.
Old Aug 13, 2019 | 02:09 PM
  #1792
panda240ss's Avatar
1993 Nissan 240SX with a 5.3 LM7 with a Custom Turbo kit.
Old Aug 16, 2019 | 07:13 AM
  #1793
Lsxhornet's Avatar
1972 Amc hornet lq4 4l80e Ford 8.8 60 day build
Old Aug 22, 2019 | 10:10 AM
  #1794
Goes2fast's Avatar
Current Performance Wiring is worth checking out most of the S10 guys use them for their swaps since they custom build a harness for their application. They also reflash the ecu for your needs.
Old Sep 5, 2019 | 10:40 PM
  #1795
Kevin Connolly's Avatar
Question HAS anyone ever LS swapped a 1989 ford e150 van
i have 2 ,89 e150 high top vans that need re-powering and ... i have a complete doner truck with LS motor n trans harness everything LOW MILES package and im just wondering how much better that would be than the sluggish boat anchor 302's how much room on clearances did you make mounts i ave quite a few motor swaps under my belt and feel confident i can do the job but has anyone else i want to pick your brain maybe see some pics ?? ok any help would be outstanding and if im not soposto ask this question im sorry im brand new here and love the LS MOTOR AN MY CHEVY-POWER !!!
Old Sep 11, 2019 | 01:32 PM
  #1796
claybob's Avatar
1952 Ford F1
LQ4- MSD Atomic
World Class T5
8.8 Posi
C4 Front Suspension
Old Sep 15, 2019 | 10:04 AM
  #1797
LS BRAVADA's Avatar
L76/MYC from a Pontiac G8 GT in 2008 Cadillac CTS
DOD/AFM delete
PAC 1819 valve springs
LS3 camshaft
Old Sep 15, 2019 | 11:50 AM
  #1798
Goes2fast's Avatar
Originally Posted by claybob
1952 Ford F1
LQ4- MSD Atomic
World Class T5
8.8 Posi
C4 Front Suspension
We need more pics of this one!
Old Sep 19, 2019 | 02:42 PM
  #1799
clay68c10's Avatar
68 Chevy C10 shorty
'04 LQ4
TKO 500
3.73 12 bolt
It's in pieces now, doing a slow "guy with a family" build
I've been lurking on here for a while. There's lots of good info. Thanks
Old Sep 25, 2019 | 11:18 AM
  #1800
claybob's Avatar
I finished the truck and need to add to Conversions. A few of the pics.
