s10 ls1ers
Old Oct 21, 2006 | 03:40 PM
  #741
gmax111's Avatar
Originally Posted by Xtremes10
Ok, I just found out the hard way that the truck alternator does NOT fit in the corvette bracket, and even worse still, the pulley wont line up with the f-body water pump, so I am currently on the lookout for corvette stuff, any idea if my power steering pump (from the s-10) will fit in the c-5 bracket?
No the p/s pump wont fit the corevette bracket. You will have to get the vette p/s pump... also i believe you will still have to make spacers to space the vette bracket out to line up with the crank pulley unless you want to buy the vette crank pulley and tensioner as well...
vette bracket = vette alternator and p/s pump
truck setup = truck alternator and p/s pump...
they are all different in some little way...
The other alternative is to do some modifing of the bracket... or get a piece of aluminum and get it watter jetted... I think it will be cheaper to have aluminum brackets water jetted and make them fit the way you want to... rather than buying the vette stuff... You could just have a bracket jetted to fit the s10 accessories... make sure you get like 3/4inch aluminum that is heat treated(ie.. series 6000 which will soften if you weld on it..so dont weld it unless you want to pay to have it heat treated again...)
good luck
Old Oct 21, 2006 | 07:38 PM
  #742
'JustDreamin''s Avatar
The C5 stuff isn't too ridiculous, money-wise....
Some examples:
1.) Water pump. I scored a brand new take off LS2 (with flat pulley for increased radiator / fan clearance) waterpump off of a LS7 crate motor (they use the same pump) for $90 (typically sell for $180 new)
2.) Power Steering pump. I bought the power steering pump, reservoir, bracket, idler, and all the bolts from a salvage yard for $150.
3.) Balancer. Bought a new take off LS6 balancer from a guy on here. Paid $40.
That doesn't include all of the parts but it is most of them. I am running a truck alternator (145A) because it was a bunch cheaper than the vette unit. Paid $55 (salvage yard) for it and I've never seen one look that new. But, I did discover that it doesn't fit the C5 bracket, and ended up making an adapter out of alum (I love having a Bridgeport at my disposal at work) to make it fit properly.
Adds up to some money, but isn't $1,000's or anything. There are some folks out there trying to sell complete used C5 access drive packages for like $1,200. That's crazy, you can buy all new parts for that kind of money.
I had the benefit of being able to shop for it a bit (bought the parts over 4 months time) before I started swapping. You may not be able to come across as many good deals.....
'JustDreamin'
Old Oct 21, 2006 | 08:40 PM
  #743
Xtremes10's Avatar
well, I found out that the f-bod water pump will work, and well, I am just going to buy a vette underdrive crank pulley, and power steering and alternator, because I have the truck accessories, AND bracket, so I am going to sell them (only have 5 miles on them anyways) and use that to pay for it mostly
Old Oct 23, 2006 | 11:48 AM
  #744
Xtremes10's Avatar
Some examples:
'JustDreamin'
do you know if the f-body water pump will work? I am on the search for power steering stuff, the alt, and balancer (If i sell the truck pump, alt, power steering, and bracket I will end up just buying an after market underdrive balancer), and if I need the water pump, I will end up with that too. Btw, here is a fresh pic of the intake and fuel rails (havent decided what all I need to do for fuel delivery, I think I need the vette fuel filter? that all? I am going to be using an fittings and lines, any idea where the best place to buy the stainless lines is?)
Old Oct 23, 2006 | 02:20 PM
  #745
I personally don't know if the f-body and C5 water pumps are the same. But it should be close enought that I'd try it.
I'm running the Vette filter/regulator. I've got a mix of rubber lines (up to the filter & back to the tank from the filter) and AN lines (up to the motor from the filter). All of my AN stuff came from Summit (pretty black fittings). Russell makes some adapter fittings to plug onto the male quick connects on the filter. You'll need to work out how you want to handle the female quick connect on the filter. I used a section of hard line from Advance Auto that already had the male on both ends, cut off one end and installed a 3/8" tube to -6 AN adapter fitting. But there are other options. Check out the 67-69 Camaro FAQ in this section. There's some good info in there about fuel system stuff.
'JustDreamin'
Old Oct 23, 2006 | 05:49 PM
  #746
Xtremes10's Avatar
well, the part numbers look to be the same, but if it doesnt work, no big deal, just get a new water pump, I have to figure out how I want to work the lines on the fuel rails, being as I have 4 connetors, 2 male and 2 female. has anyone tried to hook up an after market in tank fuel pump?
Old Oct 23, 2006 | 07:42 PM
  #747
gmax111's Avatar
Just posted alot of pictures of my swap over at s10forum.com
See sig for link...
Old Oct 23, 2006 | 08:31 PM
  #748
99 BUCKET's Avatar
sorry guys, away for the weekend. hood, yes I notched it. more for the cover than the alt however, the alt just touched it.
rad, be cool set up with flexalite 210 fans. nothing was pushed in. rad is in the stock location.
20 page thread on my progress here http://www.s10forum.com/forum/showthread.php?t=265079
I have drove it around the block, but have a miss/tapping cant seem to figure out.
Old Oct 23, 2006 | 08:33 PM
  #749
99 BUCKET's Avatar
xtreme10 I am using 255 walbro intanke with factory fuel lines to the filter area then -6an lines to the fuel rail.
Old Oct 23, 2006 | 09:33 PM
  #750
Xtremes10's Avatar
if its a tapping, or a ticking, it could be the noisey valvetrain these engines are known for
Old Oct 23, 2006 | 09:37 PM
  #751
Jake the SSnake's Avatar
The c5 and fbody water pump are the same,the pulley is thick enough to make up for the difference in where the belt rides on it.The c6 water pump is a shorter unit all together(pulley is about half the width)and will only work with the corvette accesories.It really helps if the pulley is too close to the fan/radiator.
Old Oct 23, 2006 | 09:42 PM
  #752
99 BUCKET's Avatar
more than common tick, running out of options
Old Oct 23, 2006 | 09:43 PM
  #753
Xtremes10's Avatar
well, I really have no problem with the clearance, since I am getting rid of the a/c rad and mounting the fans there, if I have a clearance issue, ill move the rad back or change the pulley, no big deal, but thats good news, wich frees up the money for the fuel pump, injectors, and ls6 oil pump, ive decided im going all out, no budget except what I have at the time for what I can get, especially since we sold the old motor, so if you do some of the math, new motor cost $3700(with tranny, harness, and EVERYTHING else) sold old motor for $2900, so new motor trans and ect cost = $800, plus I got free parts (intake, vette bracket, pulleys and such) and sold all the old stuff (truck intake, cam, valve springs, ect ect) so im actually with everything only about $2k into the swap, so im doing some more upgrading
ok, created a little shopping list:
corvette alternator
ported LS6 oil pump
tsp fuel pump kit with walboro 255 pump
36lb injectors
vette power steering
seat brackets(I bought APC seats, will corbeau brackets work on them?)
two dynomax bullets
fuel lines and an fittings
tranny crossmember
driveshaft(going single piece)
vette fuel filter
thats all I have on the list so far, sound good to you guys?
Old Oct 24, 2006 | 01:43 AM
  #754
Ls2Sonoma's Avatar
why do you need 36lbs injectors? how did you come up with that number?
Old Oct 24, 2006 | 09:07 AM
  #755
Xtremes10's Avatar
I just have a big feeling that im going to need more injector with this cam
Old Oct 25, 2006 | 01:47 AM
  #756
Ls2Sonoma's Avatar
so youre guessing? how much power are you expecting to push with your combo?
Old Oct 25, 2006 | 07:43 AM
  #757
Xtremes10's Avatar
around 380 to the wheels
Old Oct 25, 2006 | 03:27 PM
  #758
tjZ28's Avatar
This might be a stretch but does anybody have a good condition running stock 4cyl that they pulled out for their LS1 swap?
I'm looking for one for a truck I'm getting for darn near free. And yes I know I should LS1 swap it but I need a running DD that gets great mileage like yesterday.
Please PM me with anything you might have. Thanks!!!!
-TJ
Old Oct 25, 2006 | 06:31 PM
  #759
99 BUCKET's Avatar
I just got rid of a 99 2.2 and 5 speed complete for 400$ tired of looking at it in the garage
Old Oct 25, 2006 | 08:01 PM
  #760
tjZ28's Avatar
Crap.
Anybody else?
-TJ
