which coil packs for thirdgen ls1 swap?
The speartech run-through for a thirdgen ls1 swap uses truck coil packs because the stock ls1 packs hit the a/c box. Anybody else experience this?
The 98's with individual mounting don't have a problem. The swap crossmembers usually adjust the engine just a hair to clear too. Even with 99+ and the stock crossmember it still seems hit or miss. I would suggest plopping her in and then seeing if you need new ones.
Kevin D.
Kevin D.
All i have is the short block and the hawks conversion mounts. So I could go any direction for coils. The truck ones are supposed to have a higher output right? Id go msd but those are a bit pricey for my budget.
any coil pack route you take will still have a very hot spark, capable of getting ya to the single digits...
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
as for the clearance "problem" 30seconds with a dremel on the oversize lip of the AC box fixes it. no worries. i wouldnt let that decide how to spend your money.
dude it's prolly easy to get some from MSD or just get some made. I love that kind of ghetto fab stuff kills me most people prolly won't even know when you are done AND you saved yourself like $700. Nice work.
