The G-Body Swap Thread
Old Nov 9, 2011 | 07:21 PM
  #681
tryinggenIII's Avatar
Default f body headers and column shifter?
I'm running some cheapy China fbody headers and the hole collector is stopping the shift linkage from moving. Has anyone run column shift with fbody headers and remedied this? It's a 1983 Chevy el camino
Old Nov 10, 2011 | 01:30 PM
  #682
streetknight2's Avatar
Anyone done a Turbo 5.3 in a G body, or am I in the wrong thread?
Old Nov 10, 2011 | 02:57 PM
  #683
spacemanspif's Avatar
Look into Lokar products, they have a lot of cable adapters for column shifters. I'm using midlength headers on my 87 Monte and was able to bend the bar a little to still work the trans. I'm pretty sure long tubes would not have worked so you may need a cable one that will have more wiggle
Old Nov 10, 2011 | 08:09 PM
  #684
samckitt's Avatar
What have you guys used for the quick connect fuel fitting at the intake? I want to do something that looks like it came from GM, and not have 14 blue and red AN fittings to get it to work.
Old Nov 11, 2011 | 01:44 PM
  #685
G-Body's Avatar
sawzall wielding director
I have one in process, and I have seen a few more in threads around here. Its on hold at the moment, needed some time to fix some broke crap on my mom`s car and I`m prepping a couple snowmobiles for winter.
Old Nov 11, 2011 | 05:45 PM
  #686
the_merv's Avatar
I used all GM stuff..
Old Nov 11, 2011 | 08:15 PM
  #687
builder1's Avatar
Answering about the column shift hitting the header. I had to slot the bracket that holds the cross linkage on the frame and move that up away from the header. It is also on a elcamino with f body headers
Old Nov 12, 2011 | 09:57 PM
  #688
thanks for the reply. any pics?
Old Nov 12, 2011 | 11:08 PM
  #689
here are a few pics of my swap. my wireless is super low right now so i don't want to wait just to make a thread. the engine is a 2008 6.0 ly6 with a built th350c trans (converter is made to 2400 stall specs)
Old Nov 12, 2011 | 11:19 PM
  #690
LSCustoms's Avatar
Attachment 325674
Attachment 325675
Attachment 325676
Attachment 325677
what mounts did you use, no clearance issues it looks like with the stock hood and the truck accessories
Old Nov 13, 2011 | 12:08 AM
  #691
I made mounts from 1/2 aluminum plate and used the factory clamshells. I have to run a cowl hood, because I mounted the engine high so that i wouldn't have any a/c compressor or pan clearance issues. I'm running the stock oil pan. For them most part everything went smoothly, but I've done a few pretty involved lsx swaps, so this is a cakewalk. i have to heat up the drivers side header (fbody) and bring it in closer to the trans and down to allow my column shifter to fit and i'll be done.
Old Nov 13, 2011 | 12:49 AM
  #692
LSCustoms's Avatar
Attachment 325678
ok figure would have clearance issues, just was thrown off by the first pic of the hood closed...
Old Nov 14, 2011 | 08:38 PM
  #693
samckitt's Avatar
Originally Posted by LS1MCSS
Here is a pic of my 5.3 with kwik Performance a/c brackets and LS6 intake. You will need an 07 and newer truck water pump. You can also get the compressor from Sanden with the correct head on it for the factory hoses to connect to. If you get the compressor from Kwik, it will not have the correct head on it. You power steering pulley will clear the steering box if you put the motor in the right place. just build your own brackets for the motor so you can place it where you want it, not where someone else wants it.
What do I look for if I order the compressor from Sanden direct to get the correct head? You say it can use the factory hoses? Monte hoses? Aren't they a bit long cause the stock compressor location was on the driver's side....?
Thanks
Old Nov 25, 2011 | 10:18 PM
  #694
GNCLONE's Avatar
Default This thread is huge, yet hard to find
ttt .
Old Nov 26, 2011 | 02:07 AM
  #695
Default done for now
runs awesome! I havent gotten any tickets yet, so I will probably stop driving it with open headers before I do. Here are a few pics
Old Nov 26, 2011 | 02:25 AM
  #696
LSCustoms's Avatar
Attachment 327478
Attachment 327479
Attachment 327480
Hell Yeh! does the 2" clear the alternator? looking good man
Old Nov 26, 2011 | 10:58 PM
  #697
Everything clears fine. I'm going to do the same swap on my 87 beater el camino minus the a/c and I mocked it up and it all fits under the stock hood. I'll get pics at my earliest convenience
Old Dec 15, 2011 | 07:31 AM
  #698
81cuttysupreme's Avatar
Can anyone tell me how they have done the wiring and sensors for the air condditioning? I have a dark green wire on my cuttlass for compressor clutch activation. Are you guys using this and a ground with the appropriate plug to run the lsx compressor? Are there any sensors that need to be wired up? Sorry I'm not very knowledgable with the whole ac system.
Old Dec 15, 2011 | 04:19 PM
  #699
bigmandengo's Avatar
Which harness do you have? red and blue connectors?
Old Dec 15, 2011 | 04:43 PM
  #700
I have an fbody harness.
