Conversion harness, diagnostic port not working...
This lead is a 12v source from my Mustang harness, and it's constant. Must not be getting power, right?
Hopefully the tuner didnt botch something in the PCM...but I dont think you can screw it up that bad to have the ALDL not work.
Justin
I have no idea why it makes a difference
Electricity is some weird stuff...
Justin
So the diagnostic port wasn't working because one of the grounds wasn't good enough, fixed that and the port came to life. Used the code scanner to pull the code (PO200) and that threw me off...tested the injectors and turns out one of the injector leads in the scanmyride.com fuseblock wasn't solid, causing the driver side injector bank to not fire. Once that was fixed it fired right up and revved like it should
Took it for a spin and the hydraulic setup I used for the T-56 seems to work fine, but the clutch pedal only needs to be pushed a little less than halfway down to operate the clutch...is that normal? It seems like it needs to come all the way out to engage, but then it's on/off (has a SPEC clutch, not sure what type though) and it seems to go fine. I haven't had a chance to really drive it yet, so I have no other impressions really. I hope to drive it tomorrow to calibrate the speedo, and of course see what she's got! Trending Topics
As for your hydaulic question... Im not positive what car you have...I think you have a stang right? Anyway, I just recently got my pedals set where they should be and got the hydraulics working properly. however i have high engagment as well. Usually it doesnt engage until near the top...maybe the last third of the pedal. But I adjusted to it, and it still holds fine and shifts fine. I have a spec 3...
Justin
Glad you got it running. Did you look at the throw on your master? Sounds like you may need to offset the connection point to the pedal a little to alter the pedal height. Maybe bring it forward from the pedal an inch and see how that works out?
