those who went A4/A3 to Power glide
Need some info from people w/glides.....I have researched for hrs. on this site ...most of the info I have read is from folks that have never ran a glide ,are not running one and heard from a friend of a friends,uncle's-mother -sister ect. ect ect..... .
My car is around 500 hp n/a...12 bolt w/4:11's .I will be spraying 100-150 on top of that.It weighs around 3750 w/me in it.my 4l60 e broke 3 weeks ago.I have a built glide w/a ultra bell and pro brake.I would like 2 know from those who went from A4 or A3 to glide...how it affected there performance ie: 60 ft...1/8 et....1/4 et....trap speed ect
I've never ran a glide but at 650 hp I think a glide, not having that 1st gear, is gonna kill your 60' and ET.
With 650hp, you could put a good th350 in there (that's what I used at 750hp) but with your heavy raceweight, I think a good th400 would be your best bet. You'll probably have to take those gears down a notch also, depending on your tire size maybe 3:73's, 3:55's.
Main thing is I have the glide already....so... Crossmember 239
drive shaft 350
L/C dip stick 100
Stall conv. 700
total 1389.00
I can get a good th400 built fo $900.00 but I would still need all the above.So that total would be $2189.00
I was thinking w/the glide I would loose 40 lbs. ,gain about 20 RWHP and the glide has a brake.So with these 3 factors I might 60 ft just as good.I am about to loose my mind trying to decide....lol
drive shaft 350
L/C dip stick 100
Stall conv. 700
total 1389.00
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
get a PTC converter and leave off the brake, you wont have ANY issues. To build a 400 the same as the glide you could spend alot of that money to make up any difference, such as new shocks or something. Nothing wrong with glides at almost any weight, in fact with a heavier car being able to hit it with more out of the hole with less traction issues is one of the main selling points
![Thumbs up](https://ls1tech.com/forums/images/icons/icon14.gif)
Moderator
I recently decided to pull the 4L80E out of the truck due to the new 418 and N20 I plan on putting through it (It was a stock 80E). I spoke to 3 reputable trans shops. Every one of them told me a 400 would 60 a little better but I would have a better ET and mph with the glide dispite the slightly slower 60 foot simply due to the . Every one of them also said the glide would be way more consistant and with the right converter my 60' would not suffer much even at my 3,525lbs.
I have not taken it to the track yet but plan to in August.
