Best way to launch 6-speed on 200 shot?
Last time I went to the track, I had traction issues when I sprayed 200 off the line.My car is an M6 with 3.73 on 26 inch tires.Whats the best way to get full potential of the NOS without going to a 28 inch tire?I was thinking progressive 100 shot off the line then ramping it up to 200 shot in 2 seconds.What do u all think?i know it will turn off everytime I let off, if i dont power shift,any suggestions?
I can't imagine that you'll hook up to good with 200 shot with those little of tires.
I use to do 200 out of the hole, BUT that was with 28 and than 30, with an A3. Even when I was an M6, the most I did was 150 out of the hole, but was on 28".
Maybe Tanner can help with the M6 thing and a little more
The progressive would help. You can speed shift (barely lift and shift very very fast), vice granny or power.
I question: why are you attached to the 26" tires? With your engine (and as long as the rest of your drive train and suspension is up to it) and a 200 shot, you should be in the 9's. BUT with 26" ?
Do you have any time slips?
David
As a side note, here a trend that may also help: https://ls1tech.com/forums/drag-racing-tech/693601-how-launch-6-speed.html
David
CARTEK Racing
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Honestly I would do a 28" tire.
With 507HP I am trapping 131+mph, with 10HP more PLUS 200 shot you should be close to 150mph if I was to guess. At 7000rpm with 3.73 you will only see 145mph.
A few years ago, a 75 wet-shot took me from 122mph to 128mph. 6mph on a 75shot, a 200 shot should be worth 16-18MPH, and your car should be trapping 131 or 132 as it is N/A. That is damn near 150mph, and I doubt you will spin a motor on a 200shot to 7000rpm, so the way I see it you will run out of gear. Plus, even with my limited 5 years drag racing experience, I don't see how you can hook on a 26" slick. Your 408 is making 475Ft Lbs Torque, with a 200 shot that is probably an additional 300Torque easy. How do you expect to put down almost 800Ft Lbs of Torque with a 26" tire?
What do you have against a 28" tall slick?
Why do people think a 26'' tire can't hook a h&c n.o.s m6 combo ? My last year combo was a 346ci,463hp 414 tq (mustang dyno)n/a m6 car. when the 150hp nos put hp to 595 & 656tq and on my M&H 26x11.5x15 cheeter slick, i pull 1.34 60 foots. 1.42 60 foots n/a. i also have 4.11 gears in the rear. this year i'm on a 402ci w/200 to 250 shot and will try a 27'' tire,but no 28'' tire for me. Now...how i luanch the car. i stage real low at 4,000 rpm's and dump the clutch. I have no progressive controller just a window switch. N/A i luanch at 6,500rpm's. if you can't hook try the M&H tire,i've tried hoosier and M/T's and for me they did not work. goodluck to ya bro. www.intercotire.com
This was my best time N/A, 10.71et , 1.41 60ft , @127mph
Best time 100 TNT nitrous shot,10.23 , 1.50 60ft , @136mph I could feel the tires spinning halfway down the track.I was also thinking of a 27".I have nothing against a 28" that why Im asking to get feed back of whats the best to do,I wont probably have 28's till next month,so 26 is the way to go for now.
CARTEK Racing
I ran 10.70 @ 128 with a 26" M/T tire with a old *** H/C setup [396rw] and a 75 shot. With 4.11's I was running out of gear. The car pulled 1.41 60's with that setup and I never got out of the 1.5 N/A.
I just think that he will run out of gear with that power and gearing. Plus a 28 will always gook better then a 26.
just my $0.02 again...
I just sold my tires to my friend Im getting 28's, but now were wondering,his car has a TH350 with 4.10's.He is going to spray a 150 shot is he going to run out of gear?
Since you got your answer let me hijack your thead. I'm gonna be using marine02ss 26's on my cam only car with an A3/4.10's gears and I wana spary a little 150shot. My previous passes on 26's traped around 6600rpms 115mph and a 11.40et.
