SFI 25.2 Mustang/LSx build "The Renegade"
#3263
Slowly were moving along, got the coolant system plumbed, fittings will be here tomorrow to get the fuel side done, we put a skim coat on the bumper and still need to sand it, also started the wiring got some basics done.
![](http://i277.photobucket.com/albums/kk80/JessNPhil_2008/2000%20Mustang%20Drag%20Radial%20Hot%20Rod/IMG_00627-1.jpg)
![](http://i277.photobucket.com/albums/kk80/JessNPhil_2008/2000%20Mustang%20Drag%20Radial%20Hot%20Rod/IMG_00628-1.jpg)
![](http://i277.photobucket.com/albums/kk80/JessNPhil_2008/2000%20Mustang%20Drag%20Radial%20Hot%20Rod/IMG_00629-1.jpg)
![](http://i277.photobucket.com/albums/kk80/JessNPhil_2008/2000%20Mustang%20Drag%20Radial%20Hot%20Rod/IMG_00630-1.jpg)
![](http://i277.photobucket.com/albums/kk80/JessNPhil_2008/2000%20Mustang%20Drag%20Radial%20Hot%20Rod/IMG_00632-1.jpg)
![](http://i277.photobucket.com/albums/kk80/JessNPhil_2008/2000%20Mustang%20Drag%20Radial%20Hot%20Rod/IMG_00625.jpg)
![](http://i277.photobucket.com/albums/kk80/JessNPhil_2008/2000%20Mustang%20Drag%20Radial%20Hot%20Rod/IMG_00624.jpg)
![](http://i277.photobucket.com/albums/kk80/JessNPhil_2008/2000%20Mustang%20Drag%20Radial%20Hot%20Rod/IMG_00626.jpg)
![](http://i277.photobucket.com/albums/kk80/JessNPhil_2008/2000%20Mustang%20Drag%20Radial%20Hot%20Rod/IMG_00619.jpg)
![](http://i277.photobucket.com/albums/kk80/JessNPhil_2008/2000%20Mustang%20Drag%20Radial%20Hot%20Rod/IMG_00621.jpg)
#3273
Car is looking really good. I love the fact how everything is documented. I always wanted to do that on cars I built and always get in such a hurry to start forget about taking photos.
I went back to the very post of this build and the car has came along way from the original build goals. I cant wait to see the track results for the new setup.
#3274
Going into work late today so I got some stuff done this morning, Got the molding,seals and all the lexan installed this morning. Pulled the dry sump and switched over 2 fittings and got it back up in the car. New hose ends will be here tomorrow so I can get the dry sump/oiling system buttoned up. Got the ARC switch panel installed for the final time and ran the connection wire down to the relay board. Got the tranny filled with fluids and knocked out the rear end also. Coolant system is filled with distilled water and redline. Tomorrow we should get the motor oil from Brad Penn and a bunch of little stuff to finish the engine bay.
#3280
One fuel system is done, one is 1/2 way done. The oil and coolant systems are done. Just need to make a bracket for the fuel filter under the intake, relocate the ignition coil, do the wiring and a couple small things.
Goal is....
1.12-1.15 60'
3.14-3.17 330'
Goal is....
1.12-1.15 60'
3.14-3.17 330'
