Took 2 shots at getting the motor shoehorned inbetween the frame rails, failed both times. The motor is just too big. LOL! I need to notch the frame rails.
i suppose if the ams controller you have can do it (it is ams right?) you could also use the wg with the controller to be gear specific which would be a really trick setup.
its a seperate deal for the staging boost. It goes to the preset Co2 amount and as soon as the relay opens, it goes to 60#
