Drag Racing Tech
SFI 25.2 Mustang/LSx build "The Renegade"
Old 03-13-2008, 08:54 PM
  #461
7 Second Club
Phil99vette's Avatar
Need to Weld the final gussets for the stock suspension reinforcement bars.
Old 03-13-2008, 08:55 PM
  #462
7 Second Club
Looking for some opinions on my final setup, Do you think I should use a 1/2" or a 1" HTD drive on the alternator?
Fuel pump:
ATI Damper with drive 23 tooth
Aeromotive Belt drive pump
- 44 tooth 1" wide HTD pulley
- Machine a piece of aluminum for interferance fit and pin to ATI shaft - I'll basically drill through the shaft and install a pin to keep it in place
~ 50% ratio
Dry sump:
Jones drive - 22 tooth HTD 1" drive pulley
SCP 5 stage pump - Jones 40 tooth 1" wide HTD
- Dry sump pulley on the snout of the shaft, alternator pulley next to pump
Alternator: Should I use a 1/2" or 1" pulley??
Mounted next to dry sump low in the bay
Jones 40 tooth mounted on dry sump
Alternator gets a either a 18 or 24 tooth pulley
18 gets me basically a 1:1 ratio of the alternator to engine speed
24 gets me a .95 :1 ratio
we're using a 16 volt system
Any opinions are welcome!
Old 03-14-2008, 01:32 PM
  #463
RAGENZ28's Avatar
1/2 it's an alternator not a blower drive =) Smaller belt, less weight, more power you never know when you might need that .00001 to win that race.
Old 03-14-2008, 08:48 PM
  #464
7 Second Club
One more project completed...
Old 03-15-2008, 12:39 AM
  #465
smokeum99ta's Avatar
That must be where the baby seat is going
Old 03-15-2008, 06:07 PM
  #466
'Bird Director
y2k_ta's Avatar
Location: Central Indiana Honors: 4th grade spelling bee contestant
I was thinking of how easy a cooler could by bungy-corded in there
Old 03-16-2008, 04:01 PM
  #467
7 Second Club
Finally figured out the dry sump and got the first couple lines done...
Old 03-16-2008, 04:16 PM
  #468
NA$TY-TA's Avatar
Looking good Phil...
Old 03-17-2008, 06:54 AM
  #469
Fireball's Avatar
And I thought I had a plumbing nightmare
Old 03-17-2008, 11:26 AM
  #470
"The Drag Racing Director"
Coach 02 A3 Z/28's Avatar
All I can say is WOW!
Coach
Old 03-17-2008, 11:56 AM
  #471
RAGENZ28's Avatar
Looking good Phil
Old 03-20-2008, 06:27 PM
  #472
7 Second Club
Today we saw some light at the end of the tunnel. Got the heads re-torqued 2x this morning and everything is buttoned up except for the oil pan. Got most of the mockup on the nightmare drive system done and its some close clearance in some areas. I'm going to pickup a piece of 1/4" aluminum and mill out another plate for the driver side. Still got to hang the altnernator next to the dry sump on the loose belt.
Old 03-20-2008, 06:50 PM
  #473
smoknta's Avatar
I hope you dont ever break a fuel pump belt, that looks like it could be time consuming. Looks very nice though.
Old 03-20-2008, 06:56 PM
  #474
7 Second Club
Once I get a longer belt I should be able to replace in about 5 minutes. one bolt and snake it through. Good thing is its a HTD belt which should last for a very very long time. Same type of belts get used for 60-80k in timing belt applications.
Old 03-20-2008, 07:46 PM
  #475
datsbad's Avatar
good luck with those Summit brand fittings. I have had nothing but trouble with those.
Didnt they outlaw the red and blue stuff yet? LOL !!!
Seroiusly nice ride you have there. When you plan on running it?
Old 03-20-2008, 07:51 PM
  #476
xfactor_pitbulls's Avatar
Great work Phil. I dont even want to offend you in trying to guess how many hours you have into the project. When its all said and done, you shouldnt even start it. Just trailer the bitch on the hot rod car show circuit.
Old 03-20-2008, 09:28 PM
  #477
7 Second Club
I've used them for some time now and I believe they are made by aeroquip for summit. What kind of problems did you have? I have not had a problem to date with them.
Old 03-20-2008, 09:30 PM
  #478
7 Second Club
Shiiiiiiiiiit. The best part of these builds is enjoying the final product. I've got a lot of time but if you compare I had 2x the time in my corvette. I'm crossing my fingers this one won't break as often.
Old 03-20-2008, 09:31 PM
  #479
7 Second Club
Oh and for the record, as soon as my dad comes over and primes/paints the undercarrage the motor is going back in..
Old 03-20-2008, 09:36 PM
  #480
DMH Fabrication's Avatar
Same. I've run them for years on numerous cars with no issues. I wouldn't be worried about it.
Quick Reply: SFI 25.2 Mustang/LSx build "The Renegade"
