Mini Tubbing
I'm just trying to figure out what parts are structural and what aren't.
I don't want to hijack this thread, but here is a link to a picture I made using the stock tank relocated.
http://smg.photobucket.com/albums/v3...rackidea43.jpg
Here is a fuel cell in the far back and down low. Ignore the stuff up top.
http://smg.photobucket.com/albums/v3...rackidea34.jpg
Here is another possible fuel cell location.
http://smg.photobucket.com/albums/v3...rackidea35.jpg
Then I could do the twin fuel cells in the back seat area. I haven't done a diagram for that, but you get the idea. The subs have to be rearward, but the fuel cell can go several different locations, but I'd prefer low and to the rear for better weight distribution.
I have two 12's in the trunk that sit over the t-top hump in a box.
Personally I would leave the stock gas tank, put the battery in the spare tire area and make a box that fits over the t-top hump.
You wouldn't have to cut anything and the cost would be low, I even saw a battery holder made to mount in the spare tire area that was only $34.00 I think, on some mail order place.
As a side note, moving the gas tank will let the rear axle go higher. I need that room for when I lower the car. That, some mini tubs and raising the trans tunnel in the rear and I'll be set to drop the car to the ground.
More info is here:
https://ls1tech.com/forums/showpost....&postcount=212
We ran 3 15's in my cousins car and it would give you a head ache pretty quick, steering wheel would vibrate back and forth about 3"s
I have all this room in the back seat area, but the subs have to be in the rear of the car so it creates a bit of a challenge. I don't want anything that has already been done before. I want it unique. Something that will make folks scratch their head and wonder how I did that.
With that last idea I would cut out the area above the gas tank, the upper part of the seatback area and the draftshaft tunnel. Then to tub the car I'll be cutting out the wheel wells. It kind of makes me wonder what will be left? Just the "frame rails"?
Or, I could weld some 2x3 box steel tubing over the green area where the "frame rails" are located. Then cut out the tank and trans tunnel piece right along the new tubing. Raise that whole middle section up and then weld it to the top edge of the square tubing. Then just add some filler pieces to the gaps in the front and back?
This way I would be adding strength and stiffness with the new rear frame rails and reduce some of the welding and new sheet metal needed.
Although I would not need to keep the yellow section on top, just the trans tunnel part. A fiberglass box could be molded to the top of the axle shape and have a flat top. That way the car can be lowered more. The work is similar to race car stuff, but just for different reasons. I'm definetly going to come back and reread all the stuff about grinding the stock metal to bare and all the hints to welding on it. This is all great info.
Pretty much done, now time to get the rims/tires/rear end.
Will post pics later tonight or tomorrow.
You still doing the winter thing or you get to work on the car any?
I pretty much finished all the tub stuff just have to do one last thing, then clean out the car and vacuum it and wash all the damn grinding dust off.
Then I'll paint all the little spots and put some body sealer over the new floor seams.
Do you have to totally weld all the seams or can you just weld several small spots like the factory does and then seal the seams with a filler of some sort?
