Drag Racing Tech
View Poll Results: What rim to run on a 315 60 15
15x12
7
43.75%
15x10
9
56.25%
Voters: 16. You may not vote on this poll
Rim size for 315 60 15
Old 11-29-2007, 01:47 PM
chrismorales75's Avatar
Default Rim size for 315 60 15
What do you think is the best rim size for a 315 60 15 to drag race on.
The car has a wide enough tub to run either with ample clearance.
Old 11-29-2007, 02:18 PM
c0ncEpT's Avatar
Well with a side wall that big I would think you would only need to use a 10in rim and anything bigger would just be adding weight.
Old 11-29-2007, 02:24 PM
9sec93's Avatar
the wider rim will give you a wider footprint and be more stable on the top end. drag radial wont be as unstable as a slick but im sure the wider rim will be more stable. makes sense to me.
Old 11-29-2007, 02:42 PM
Difference from a 10-12" rim is very little, I am mainly looking for what the fastest guy are running these 315 60 15's on.
I have sen cars go fast on both, but I was thinking a 15x12 will give me more options later if I run a 10.5w tire say 33x10.5w I wouldn't want to put that on a 10" rim.
Old 11-29-2007, 02:43 PM
You run 15x12's don't you? What size back space and how much did you narrow your rear in your setup?
Old 11-29-2007, 02:45 PM
LS1Tech Sponsor
MADMAN's Avatar
I have 15 x 14s on our drag radial Mustang.After the beadlocks they came out to be 13 1/4 wide. Works killer for us.
__________________
www.madmanandcoracing.com
225-343-9029
Old 11-29-2007, 02:50 PM
15x14 with a 315 60 15? or a 10.5w I thought a 15x12 with a 315 60 15 had a 14.25 section??
Call me stupid I am confused
Old 11-29-2007, 03:31 PM
LS1Tech Sponsor
MADMAN's Avatar
Its a "drag RADIAL" car
__________________
225-343-9029
Old 11-29-2007, 04:17 PM
How's it end up being 13.25?
I thought a 15x10 was 13.5 section
15x12 is a 14.25 section
So how the heck does a 315 60 15 end up being 13" wide on a 14" rim?
Whose car, have a link or pics I have to see this?
Old 11-29-2007, 04:42 PM
LS1Tech Sponsor
MADMAN's Avatar
The wheel ended up being 13.25 sorry.
__________________
225-343-9029
Old 11-29-2007, 04:45 PM
LS1Tech Sponsor
MADMAN's Avatar
__________________
225-343-9029
Old 11-29-2007, 07:13 PM
LS1TECH Sponsor
CutlassRacer's Avatar
Will Stevenson has been 7.51 @ 191 with 15x10s on his F-body. I think I remember him doing some testing with 12" rims and it did not show any improvements on his car, but did cause some clearance issues.
LS1TECH Sponsor
Cool ladder bar setup in the Mustang.
Old 11-29-2007, 07:43 PM
I don't have clearance issues I have a full tub and 16.5" of clearance to play with
Old 11-29-2007, 07:46 PM
That's a cool car
Old 11-29-2007, 09:09 PM
car_fixer's Avatar
umm i dont think thats a ladder bar, looks like the top brackets are being used, i guess its a stock suspension type d/r class? still a nice lookin car, well down here atleast.
Old 11-29-2007, 09:13 PM
gator's 99TA's Avatar
that is a "stock type" suspension. lots o controversy. it has a mini tq arm as well as LCA and UCA. hard to see the details. bitchin fast drag radial car for sure.
Old 11-29-2007, 09:14 PM
LS1Tech Sponsor
Brady's Avatar
Wrong. See the uppers?
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
Old 11-29-2007, 09:36 PM
LS1TECH Sponsor
HA HA HA HA. That was more of an inside joke to the guys who run stock suspension. That piece was originated by Wolfe (as far as I know) and should not be legal in ANY "stock suspension" class. Since when to Mustangs come with torque arms (or a single ladder bar as they have been called)?? And dont even gimme that "well its there for safety" junk either. Its there to prevent tire shake and to keep the tires planted. To avoid controversy at Orlando this year, Wolfe did not have it on his car and went pretty freaking fast so obviously its not totally necessary.
Chris, put them on the biggest bead lock rims you can squeeze in there. That'll look cool
Old 11-29-2007, 11:09 PM
9sec93's Avatar
mine are on a 15x12 w/ 3.875" backspace. i built my rear starting with a bare housing and when finished i compared the width to the width of a stock rear and i believe it was 16" narrower so 8" per side. i have a 4-link though.
Quick Reply: Rim size for 315 60 15
