TR230/243 Dyno results. track results
After ported tb and u/d pulley I should hit 400rwhp
Full mod list:
Lid
TR230/224
LS6 intake
stock 243's milled .020
7.4 push rods
LS7 lifters
Patriot duals
Melling high volume pump
4.10
KYB AGX
LS7 clutch kit
PS LT's ORY through SLP D/D or electric cut out
http://www.youtube.com/watch?v=NDTKa...os=SO67xYwkmdA
Full mod list:
Lid
TR230/224
LS6 intake
7.4 push rods
LS7 lifters
Patriot duals
4.10
KYB AGX
LS7 clutch kit
![](http://i5.photobucket.com/albums/y165/spltblkribbon/10-19-2010074329PM.jpg)
LSX Mechanic
Casey, slap a fast 92/92 and see how much more it picks up.
Wouldn't 7.4 pushrods be too long with milled heads?
I was just curious because I was advised to use 7.4 pushrods with stock heads.
Could you elaborate on the FAST intake vs tr230 issue? I only ended up with a fast because it was an awesome deal at the time ($500) and I was getting a ls6 anyway.
Are you just referring how the cam favors a high flowing exhaust and increases intake to handicap poor flowing intake designs?
That's the numbers I expected...I think SAE it was 387rwhp 370rw trq
The graph looks pretty healthy, what do you think could be holding it back from making the right power?
Also, I DO have an ls6 intake..I forgot to add that to the list. Every dyno is different..that may have something to do with it.
My buddy here in town has a G5X4 and stock 243's and made 404rwhp through an auto. So for the general area I'd say this power is pretty good..
My numbers were pretty much spot on with what I expected but maybe since I'm not completely full bolt on and have 4.10's they weren't quite as high? Also I have a heavy LS7 clutch which sucks up some power.
Well if the push rods were too long you would see valve float and a wobbly dyno graph especially in the high rpms.
I'll see what it does at the track because dyno numbers don't mean much.
Also this dyno was in vegas so the DA is pretty high.
I'd have to disagree with you there Damian, stock head/cam ls1's were picking up 10-15rwhp with just swapping to the 90/90 setup. Im not saying its a justifyable upgrade, but its definetly not going to hinder him from making more power.
We aren't discussing track results....D/A doesnt mean squat on the engine dyno because the weather station / correction factor will take the quality of the air into account. Thats the entire reason weather stations and correction factors exist allowing results all across the country to be compared regardless of air quality at the time of the testing. If you test in a really cool climate the correction factor actually hurts your numbers!
Also, Im surprised no one touched on the fact a reverse pattern cam with a weak stock exhaust port is also costing the OP some power (thats not what I would have spec'ed).
Drop a 230/236 in that engine and I bet the peak numbers look a good bit better.
The LS7 clutch isnt helping either which has already been touched on....
Get it to the track and see what it traps....that will let you know how stingy or generous the dyno may have been also.
If you trap a big number then you know the dyno may have read a bit on the stingy side.....some of them do.
You could also ask the shop what they typically see from stock vehicles that we can all relate to get a better idea of the type of numbers it spits out (A C6Z06....a C5ZO6....even a stock LS1 car, etc.).
Good luck....
Tony
Good luck....
Tony
I would have expected 410-415rwhp out of that setup. TR230 is usually 390-400rwhp and stock 243 heads are worth 15ish, from what Ive read.
check this TR230/243 setup out:
https://ls1tech.com/forums/dynamomet...y-440rwhp.html
LSX Mechanic
How about optimizing the combination? Thanks to the internet, this philosophy has pretty much become extinct.
FWIW, the TR230 was developed 10 years ago as a way to crutch the engine for the lack of intake flow we suffered w/ the LS1 intakes (before LS6 intakes were readily accessible). The valve events are not designed for a ton of air flowing through the intake. It's the opposite, actually. Thanks to TR's marketing team over the years, this cam has been splattered on the internet as a great way to make power with any combination. However that isn't the case. It's a great way to make power if you don't have a good intake. If you've got an LS6 intake (or better), there are much better cams out there.
/Soap box mode disengaged.
