477rwhp Lq9 milled 317's and a cam
Old Aug 11, 2012 | 08:57 AM
IllusionalTA's Avatar
Default 477rwhp Lq9 milled 317's and a cam
Posted a bit back bout getting my car goin after taking a break for 9yrs due to life, worked the bugs outta the efi , had a bad computer from sitting so long In the heat.. Anyway, details of my experiment:
29k mile 6.0 escalade short block
Super Vic with 4bbl tb
Milled 317's .075 no port work , stock valves
250/250 HYd roller specd by my buddy Bret Bauer..
Coan 5k stall 8" converter
Th400
S60 with 4.56 's
All tuned by me..
All in all I'm satisfied with how it all turned out, ESP for the minimal $$$ I have in the conbo.. The sheets std car made 450sae for the sae guys, this is the first sheet he printed...
Old Aug 11, 2012 | 09:48 AM
jims z's Avatar
How big a tire you running with those 456's and how high do u plan on spinning the motor? Great job on a fairly low budget motor!
Old Aug 11, 2012 | 10:29 AM
28"... See how it comes together at other track, I'll probably have to step down the gear a bit..
Old Aug 12, 2012 | 05:41 PM
dgcustomz's Avatar
Were the cylinder heads angle milled?
Old Aug 12, 2012 | 06:19 PM
They were not rolled.. Flat .100
Old Aug 12, 2012 | 06:40 PM
KCS's Avatar
KCS
Moderator
The torque doesn't look right. Peak looks low, but it looks like it was low everywhere else.
I'd be interested in seeing what happens when the cam is advanced a couple degrees, if there is enough P-V.
Old Aug 12, 2012 | 06:45 PM
I can do that fairly easily, my buddy used to own a dyno, and this wouldn't have a been a issue to play around.. P2v shouldn't be a issue.. i got room +/-10 deg..
Old Aug 12, 2012 | 07:17 PM
dgcustomz's Avatar
damn, So what about intake alignment? No issues? We milled 317's down .060" and had to fix the bolt holes on the intake. Bolts were going on sideways but it was worth it. 464rwhp.
Old Aug 13, 2012 | 05:56 AM
Intake was milled and redrilled
Old Aug 13, 2012 | 06:27 PM
dgcustomz's Avatar
ah! now it makes sense to me.
Old Aug 18, 2012 | 09:19 AM
Old Nov 13, 2012 | 06:46 AM
Just a update , I jumped in on a rental yesterday.. Never installed any of my rear suspension stuff. So I paid for it.. Either way was a good time.. Car went a best if 10.51@128 with a 1.47.. Rear of car wouldn't hold any more.. And my rims were spinning in my tires.. Made 16 hits, and had a blast..
http://youtu.be/lAvcaCiHukc
Old Nov 15, 2012 | 07:21 AM
Rob94hawk's Avatar
Real nice run Steve! Incredible 60ft!
Old Nov 15, 2012 | 09:54 AM
Thanks rob , got a lot left to do in the 60ft.. First time out hard to complain.. But def gotta go back
Old Dec 9, 2012 | 05:13 PM
LSFOX's Avatar
Can you tell me a little more about your combo....?
Standalone?
From what I have seen anything over .075 has PTV clearance issues... Were the pistons Flycut?
What was the weight of the car?
I am currently starting to gather parts to build my own LQ4 or LQ9 and this budget build is just what I am trying to duplicate.... in a 3100lb Mustang of course
Old Dec 9, 2012 | 06:31 PM
Sales@Tick's Avatar
Good job Steve!
Old Dec 10, 2012 | 09:05 AM
Standalone?
Car weighs 3570 with me in it.. Pistons are flycut, running a stock PCM.. I have throw the car back on dyno, to ensure my afr and timing is optimal as I had to crank limiter up to 7k to get through traps, just did it safely to get through the day..
Old Dec 10, 2012 | 09:14 AM
Sales@Tick's Avatar
You put new springs in it too and got rid of the valve float correct Steve?
Old Dec 10, 2012 | 09:25 AM
Yea I did swap the springs, have yet to throw it back on rollers since.. No rush since seasons over... But it'll get there... Been workin on the interior lately...
Old Dec 13, 2012 | 12:01 AM
93camaro_zzz's Avatar
Nice word indeed! What all is done to your TH400?
