Cam Only Dyno Thread
Old Sep 5, 2006 | 08:44 AM
  #181
BADSZ28's Avatar
Seems like people are making more and more power cam only lately. Especially with "smaller" cams. Are tuners getting better?
Old Sep 10, 2006 | 01:12 AM
  #182
GrannySShifting's Avatar
My current setup
2000 long block, one of our custom cams (233 intake duration)
FAST 90mm we ported, 4.56 geared 12 bolt in M6
425/380 thru stock SLP dual dual 437/390 open y pipe on Mustang dyno
Old Sep 18, 2006 | 08:40 PM
  #183
baker7902's Avatar
what up everyone just bought 02 ss camaro bone stock looking for a good cam to help with some power what do you think dyno last saturday
307 whp 317 wtq
Old Oct 1, 2006 | 04:43 AM
  #184
miamifan3413's Avatar
Any1 with TR Cheatr cam???
Old Oct 2, 2006 | 09:06 AM
  #185
BADSZ28's Avatar
T-Rex: 389/374 on a Mustang Dyno. Power drops after 6300 for some reason. May be float. I will shim the springs over winter and try again next year.
Old Oct 3, 2006 | 08:33 AM
  #186
Nick Williams's Avatar
Hello everyone just wanted to say that we are having a dyno day this sat the 7th. It starts at 9:00 am and goes until when ever. Free food and drinks! Dyno pulls are $40 with wide band O2. For more info. call 704-658-2302.
Old Oct 12, 2006 | 07:10 PM
  #187
SIC LSX's Avatar
User Scoobie has 02 SS with cheater cam, fast 90/90 did 401whp/370trq
Old Oct 12, 2006 | 07:13 PM
  #188
SIC LSX's Avatar
i should be around 400whp or more now! With TSP 231/237 and all boltons without 90/90.
I did 386/360 on stock tune!,pulley,injectors,TB!!! NOW ASP pulley,42lbs injectors,Ported TB and a SD tune!
99 M6 with ls6 intake
Old Oct 12, 2006 | 10:07 PM
  #189
SSNISTR's Avatar
Any FMS F11 dynos?
Old Oct 22, 2006 | 12:57 PM
  #190
Originally Posted by GrannySShifting
My current setup
Ended up running 11.33 @ 122.6 thru catback, 3450 lbs, 1600 DA
Old Oct 24, 2006 | 08:11 PM
  #191
AlexLS6's Avatar
M6 cam only + bolt-on 443.3 rwhp/395.7 rwtq, good drivability, love the cam.
(mod in my video description)
Old Oct 30, 2006 | 11:36 PM
  #192
ls16spd's Avatar
M6-tr224 cam-Mac headers-off road Ypipe-slp loudmouth-Centerforce clutch-Moser 12-bolt(4.33 gears)-Pro5.0 shifter
383RWHP
Old Nov 2, 2006 | 07:39 PM
  #193
greatwhite99's Avatar
Dyno'd 370HP / 371 TQ with lean AFR and some KR. Added some more fuel to the PE but need to re-dyno.
Mods include LS6 Intake and Z06 (2003) injectors, HP Tuners, TSP 224R, Pacesetters, TSP Catted Y, Magnaflow catback, Home Ported TB.
Old Nov 9, 2006 | 12:07 AM
  #194
WS6FASTTOY's Avatar
Torquer v2: 232/234/598/595 on 112lsa. Boltons on sig.
Old Nov 12, 2006 | 05:24 PM
  #195
dae04383's Avatar
Default just tuned today tsp 228/228 588 588 112 lsa 390hp 372tq
1999 camaro z28 ( 2000 ls1 engine)
hooker lts tsp y with cats rumbler exhaust
ls1 intake
lid, bellow
stock pulley stock mass air
m6
3.42 gears
im happy...
Old Nov 12, 2006 | 08:02 PM
  #196
dae04383's Avatar
Default tsp 228r hooker lts y pipe w cats rumbler exh lid ......
here is the graph
Old Nov 13, 2006 | 05:11 PM
  #197
WS6 SRT-8's Avatar
Default New Dyno Numbers!
2000 WS6, MN6. LS6 intake, pulley, lid, Dynatech LT's W/cats, Speed Inc. 007 cam (228/222 588/581 114.5 LSA), 918's, Comp PR's, Tune by Speed Inc., Kenny Brown SFC's and springs, Pro 5.0, stock catback, and drivetrain with 3.42 gears. 383rwhp/358rwtq. Drives like stock! Doesn't accelerate like stock though!!!
Old Nov 15, 2006 | 09:15 PM
  #198
S99TA's Avatar
some small idle problems but nothing bad cam and dyno numbers are in the sign.
Old Nov 18, 2006 | 02:50 PM
  #199
99zMD's Avatar
405/378 on PSI custom cam, mods in sig. Still needs plenty more tuning!
Old Dec 10, 2006 | 12:05 AM
  #200
MAC4264's Avatar
520/450 FLYWHEEL horsepower/torque, 248/254 500/500 113 (lift rule class) Kooks 1 3/4 step 1 7/8 headers, stock 241 heads Ferra valves and modified for P to V clearance, .040 Cometics, LS6 intake, stock untouched throttle body, comp 918 springs, GM hydraulic race lifters, 42 lb. injectors, stock computer with HP tuners 27 degrees of timing 13.0 AFR, no belt with electric water pump.
This engine was tested with both stock computer with 87 pump gas and a FAST wideband engine mangement on VP C11 and made the same power with both setups. Dyno only never drove on street was built for track use only.
Have no idea what DCR the motor is and did not care when selecting camshaft, I just wanted the largest cam possible that would fit with NO piston modification (no valve releifs). Thinking of trying a 256/262 500/500 117 next.
