Forged LS1 AI 317 Heads S475 Build Guesses
---Motor/Exhaust---
LS1 Block
Stock LS Crank 3.622"
GM Gen IV Forged I-Beam Rods 6.098" w/ARP 2000 Bolts
Mahle PowerPak Piston and Ring Kit 3.905"
ARP Main Studs
LS6 Oil Pump
Improved Racing Oil Pan F-Body Baffle
Morel 5315 Lifters
LS2 Lifter Trays
Martin Smallwood Custom Turbo Spec'd Cam (228/228 .612/.603 115+4)
BTR .660" Lift Valve Springs
LS9 Head Gaskets
ARP Head Studs
Advanced Induction CNC 226cc 317 Heads
Fast 92mm Intake w/Nick Williams 92mm Throttle Body
Work Turbochargers Borg Warner S475 (T6, 1.32 A/R, 75mm C/W, 88mm T/W, w/few tweaks)
Custom Turbo System Front Mount Intercooled
Water/Meth Injection
93 Octane Tune
---Driveline---
3200-3800 Stall Converter (Not sure here yet depend on cam)
Built 4L65E
Quick Performance Fab'd 9" (3.50 Gear, 31-Spline Axles)
---Suspension---
Viking Coil Overs (Front & Rear) 150lb Spring in Rear
Full UMI Suspension - (You name it I got it all fully adjustable)
And A tune...... What Numbers/Track Times you think I will see? I am going to keep it full body TA only with rear seat removed
I am looking for close 600rwhp on low boost and close to 800rwhp on high boost... with low 10's in Quarter
LS1 Block
ARP Main Studs
LS6 Oil Pump
Morel 5315 Lifters
LS2 Lifter Trays
LS9 Head Gaskets
ARP Head Studs
93 Octane Tune
---Driveline---
Built 4L65E
---Suspension---
I do too lol hahaha... Deff going with yours
Really thinking about going to a setup like yours with Super Victor Intake and Elbow setup and ditching the WS6 hood and getting a VFN Sloped pin on hood.
