project tin can shootin for 9's
It does look good though... should make some good steam, and you certainly have done your work to get the car light enough. Pretty much a copy of KP's builds, and I know how fast his cars were at a good bit heavier then you'll be.
What are you doing for a PCM?
Thanks JL, KPs car is sick and basically what I want to build and I know he knows his **** so as gay as it sounds, his car is my insperation, lol. As for the pcm I'm using the stocker. Personially I don't see a beed "yet" to go with somethin different, plus I'm running out of money with buying a house in the next month or two. Plus I see how much power people are making on stock computers so it will be good enough for me.
KP was one of the reasons that I am going to make the change too, the level of maintenance to go in the bottom 8 second range with a nitrous car is retarded, but a gear driven XI vortech head unit, is a totally different story. Gear drive takes all the belt issues away, and the new Alston gear drives are a good solid piece.... change the oil in that and the blower on a regular basis and things will be happy for a long time.
Well, long time in racecar terms anyway.
Got a Q on the rails, what did you do on the back. I wnat to run a 3/8NPT -6 then a 90* -6 swivel on the back of them. Some said they didnt have room and it was into the firewall. But I think I see that setup on some cars, did you have room or have to change it from the off car pics setup?
I'm just doing -6 so not sure.
How did you get the under fender meatal off? can you drill out the spot welds? I see some far away pics looks like a lot cut them off, and leave the outer flange still welded on? Is ther somthing I'm missing why they leave it? I'm not finding any good close pics of that metal, the old pics are down. thanks
i dont have any pics of it yet, didnt run my fuel system yet, just have the fittings on the rails for now. Eventually ill get um swapped over but not yet. As far as the metal i used a 4" cut-off wheel on a grinder. You could drill out the spot welds but IMO it would look like *** from the engine bay and reason for leaving on the little lip is to leave it some rigidity so its not sooo flimsy and weak ya know. I have some more pics on my home computer, when i get some time ill get um posted up.
