project tin can shootin for 9's
On the other hand I found my headlight plugs so now I just need to run wire for power and brake lights.
Might as well do a little updating while im here:
Drove the car a few hundred miles breaking it in, and holy hell!, i have yet to go full WOT without it wanting to brake loose at 50+ mph. This turbo set-up is a WHOLE new ballgame, lol. I ordered a extended sunoco hood for it, that should be here in the next few weeks. Right now im making a master cylinder brace for it. When i was bleeding the brakes i checked the fire wall flex with my g/f pressing on the brakes and it flexes a LOT!, so im in the middle of that. Got all my lights working (headlights, running lights and brake lights) so its street "legal". All i have left really to make it 100% is a hood and wire up my power windows.
the joker bike is my new stunt piece....
had my hood for a little while now and just got around to getting it trimmed and mounted. I cut the back down about 3" so it would sit lower on the windshield but left cowl full length..
For the front mounting points i made some pins, almost like hood pins but they stop under the hood. Then cut down and welded on the dzus plates to them. So its basically hood pins but dzus style. Drilled hood for the fittings and its solid as can be!
Ordered a turbo blanked off ebay, for $60 shipped it fit great and for the little time iv had it, its holding up fine.
AND ill sneak in a photobomb of my new toy i got a few weeks ago, '09 crf450
So on the highway i had a few cooling issues, on the street its fine but anything 1500+ rpm over a longer period od time id get 230+ temps. Only thing i dont have is a air damn so i made one of those to help push air across it at higer speeds. My buddy bent me a piece of 14g stock that i welded nuts on the back side to mount a plastic air damn. Made it so if and when it wears out or breaks i can replace it easy. My buddy got me some really strong plastic that has channels in it that i figure would help direct the air upwards opposed to off the sides. Ill see if and how much it helps hpoefully sunday.
Then while my fans were on i felt a ton of air being pushed upwards before the radiator so had my buddy (sheet metal worker) bend me a piece of stainless and made a cover to direct more air through the fans.
Next mod im going to do is cut back some of the cowl off the sunoco hood to allow heat to escape from the engine bay and not be held in from the extended hood where basically no heat can escape. Hopefully come sunday it will run cool and i can drive it on the highway with no issues.
Heres a newer idle clip i took the other day testing out the new phone. This thing takes badass videos!!..
But the shows/comps. are callin so i need to get back to my second job to make some more money for this damn thing...
