Fireball Outlaw Drag Radial Rebuild Thread
Old 04-01-2010, 03:55 PM
  #341
DanZ28's Avatar
Couple things I am contiplating now, is putting the fuel cell in front but I'd like to put it near the firewall somewhere if possible, just dont want the car to turn into a "Fireball" (no pun intended) if I ended up nose first in the wall. I bought the Peterson external belt driven oil pump and the waterman mechanical fuel pump that I can either bolt to the back of the oil pump, or cable drive it, I thought that covered all options at that point no matter what I decide. Also, I want to run a radiator as well, but now thinking about just putting another Chiseled water tank in the back to feed water to the engine and have no radiator, otherwise I'll do what JL mentioned and put it on the drivers side nose area, or turn it horizontal and put it somewhere under the front. IC goes in the car.
DanZ28 is offline
Old 04-01-2010, 04:36 PM
  #342
Fireball's Avatar
Originally Posted by DanZ28
Couple things I am contiplating now, is putting the fuel cell in front but I'd like to put it near the firewall somewhere if possible, just dont want the car to turn into a "Fireball" (no pun intended) if I ended up nose first in the wall. .
thats why NHRA requires you put a 1 1/4" bar in front of the fuel cell to protect it (if outside the frame rails)
Fireball is offline
Old 04-01-2010, 04:37 PM
  #343
Fireball's Avatar
got the fuel cell mounted
Fireball is offline
Old 04-01-2010, 05:14 PM
  #344
Navy David SS's Avatar
Only a 2.5 gallon fuel cell? Heck the fuel will not last very long on a Saturday cruise
I assume you will running C-16 (or Q-16)? I weighed the cost of C-16 (at @$16 a gal) or E-98 (at @$2 a gal). The E-98 will double the use, but at 2 gal per run on C-16 vice 4 gal of E-98 per run ($32 vice $8). My tunner has gotten a lot of power out of the E-98 and we don't run any events that I couldn't run E-98. If we get our **** together hopefully we'll switch to C-16 and go the next LSX event.
Good luck with the build
David
Navy David SS is offline
Old 04-02-2010, 05:58 AM
  #345
Race your car!
JL ws-6's Avatar
I thought about that too, running 2 water tanks in the back of the car, one with water for the engine and one for the intercooler, and ditching the radiator all together, I know a couple people that are doing that and it works, they drain the water tank and just fill it back up with cool water after a run from teh track water supply, and they put a filter on the pickup for the water pump, so no dirt gets in the cooling system.
I dunno though, that's alot more line to run to the back of the car and whatnot... not sure if I want to go down that road, seems like alot of line, and weight.
I am heavily weighing the intercooler internally in the cabin vs putting it in the nose. I really would like to put it in the nose to keep the plumbing simple, but if it's going to be too much weight up there I can put it in the car, just more plumbing to run. If it goes in the car, mine as well put it on the tunnel in the back, so it's centralized, and run the 2 charge pipes up the center, I ditched the center console so that's not a problem, with what I'm doing with the cowl, it wouldn't be the end of the world to just face the Tb backwards, then run the charge pipe up thru the hvac delete.... I just figured the less charge pipe the less area that had to be pressurized before the motor saw boost.
Anyone have a take on that, does the actual length of the charge piping cause any type of delay with the engine seeing max boost, to the point that it effects performance?
JL ws-6 is offline
Old 04-02-2010, 04:21 PM
  #346
Fireball's Avatar
Madman's manual rack installed...Big thanks for a quality kit that fits great (although drilling the knuckles for a 5/8" bolt sucked pretty bad). I also custom built my own steering shaft (Madman provided the u-joints).
Fireball is offline
Old 04-02-2010, 05:07 PM
  #347
InconFormula's Avatar
David
Holy crap you use 2 gals of C16 per run? Im right at a gal maybe a little less.
InconFormula is offline
Old 04-02-2010, 05:14 PM
  #348
SScam68's Avatar
that the Burkhart manual brake setup?
SScam68 is offline
Old 04-02-2010, 06:17 PM
  #349
Fireball's Avatar
yes it is
Fireball is offline
Old 04-02-2010, 06:18 PM
  #350
Fireball's Avatar
yeah...x2
Fireball is offline
Old 04-02-2010, 07:43 PM
  #351
Shawn @ VA Speed's Avatar
maybe it's a long drive to the staging lanes.
I think we burn just over a gallon.
Shawn @ VA Speed is offline
Old 04-02-2010, 08:29 PM
  #352
That's warm-up, going up to the lanes, the run and back to the pits. The idiots at the track have no idea how to call cars up. I've never measure it - maybe its only 1.5-1.75 gals.
Nice work of the steering set-up.
David
Old 04-02-2010, 11:20 PM
  #353
myth's Avatar
Lookin good Brian. i hope to get started on mine in a couple of weeks. Going to have a new home for your old turbo
myth is offline
Old 04-03-2010, 09:15 AM
  #354
Fireball's Avatar
which one? The 98mm or the GT47?
Fireball is offline
Old 04-03-2010, 09:21 AM
  #355
Restricted User
98Z28CobraKiller's Avatar
Getting there. Looks great.
98Z28CobraKiller is offline
Old 04-04-2010, 11:07 AM
  #356
Fireball's Avatar
finally worked on something turbo related
Started mounting the new monster intercooler....its mounted in the back just need to fab up something to support the front...
Fireball is offline
Old 04-04-2010, 11:54 AM
  #357
ninetres's Avatar
Bo-Jesus that is a huge IC! Are you compensating for something lol? Please give info on cores and all the other specs!
ninetres is offline
Old 04-04-2010, 12:01 PM
  #358
Fireball's Avatar
old style cores (which I personally prefer)....2400 hp rating.
Fireball is offline
Old 04-04-2010, 12:12 PM
  #359
ninetres's Avatar
Who makes the cores? Are there just 2 huge ones?
ninetres is offline
Old 04-04-2010, 12:21 PM
  #360
veee8's Avatar
Those bastards are heavy huh? I cant wait till I get some paint on the floor so I can mount that thing for good. It is a procedure just moving it in and out.
veee8 is offline
Quick Reply: Fireball Outlaw Drag Radial Rebuild Thread
