Fireball Outlaw Drag Radial Rebuild Thread
Old 05-22-2010, 11:35 AM
  #541
Fireball's Avatar
Originally Posted by Phil99vette
What thickness material did you use for the firewall plate?
its the burkhart hvac delete plate. Its pretty thin...maybe .063
I need to grab my calipers to measure. I may pick up some .125 6061 plate and rebuild it.
Fireball is offline
Old 05-23-2010, 09:04 AM
  #542
6techniques's Avatar
Originally Posted by Fireball
dual 3s is less than a single 5. to area match you need dual 3.5s
didnt even think of that, thanks man!
6techniques is offline
Old 05-23-2010, 01:05 PM
  #543
Fireball's Avatar
haha...running out of space quickly...this poor 3 gallon summit fuel cell has been hacked up beyond recognition This time I had toadd a notch to allow it to clear the removable frontend bar while being far enough in front of the radiator to accomodate a -12 90deg AN fitting for the fuel feed line. Still need to get some more .090 aluminum plate to close off the notch
Was originally going to cut off the whole front section, but didn't want to sacrifice that much tank volume, so I put the bottom section back on just leaving the notch
Fireball is offline
Old 05-23-2010, 01:24 PM
  #544
Race your car!
JL ws-6's Avatar
That's now the fireball version of the 3 gallon summit tank
Capacity: way less then 3 gallons
Looks good though. Coming along nicely.
JL ws-6 is offline
  #545
7 Second Club
Phil99vette's Avatar
Starting to come together, how much fuel will that tank hold? We only need 2 gallons at the most.
Phil99vette is offline
Old 05-23-2010, 02:22 PM
  #546
Fireball's Avatar
a little over 2 gal I think...I need to measure it though. before the notch it was about 2.75 gal.
Fireball is offline
Old 05-23-2010, 08:26 PM
  #547
Shawn @ VA Speed's Avatar
make sure you get some 5052 alum for the cell notch
Shawn @ VA Speed is offline
Old 05-24-2010, 08:22 AM
  #548
Fireball's Avatar
good call...
I'll also probably use 5052 for my new firewall blockoff plate (1/8" vs the .063 I have now)
Fireball is offline
Old 05-24-2010, 11:05 AM
  #549
7 Second Club
Shawn, where did you get the last batch of aluminum you used for your fuel cell?
Old 05-25-2010, 07:03 AM
  #550
Fireball's Avatar
My pieces of aluminum should be here today...I'll be rebuilding the HVAC delete plate with 1/8" to replace the ocean wave plate Once I get the firewall plate done I can get going on the cold side plumbing (on the interior side...need the final motor and turbo to do the engine bay side)
really hope to get the heavy fab work complete in the next 2 months or so...I want the car in paint by end of August...
Fireball is offline
Old 06-02-2010, 05:39 PM
  #551
Fireball's Avatar
got back on the project for a bit today...started on the coldside piping...welded on the v-bands to the I/C and started laying out tubing.
Fireball is offline
Old 06-02-2010, 05:54 PM
  #552
7 Second Club
Lookin good, I like how the tubes are low in the car.
Old 06-03-2010, 05:47 AM
  #553
Fireball's Avatar
trying to keep an escape route open just in case I need to bail on the passenger side.
Fireball is offline
Old 06-04-2010, 01:24 PM
  #554
Navy David SS's Avatar
More and more done. Great job. Who made the inter-cooler? I wish I would have V-banded my inter-cooler.
David
Navy David SS is offline
Old 06-06-2010, 12:28 PM
  #555
brobards's Avatar
The build is coming out very nice. I really appreciate how you, Phil and others are willing to post pics of your build and reasons behind your actions, it makes it easy for me to steal a few ideas for my own build
looking forward to seeing this thing get back to the track
brobards is offline
Old 06-08-2010, 05:58 AM
  #556
Fireball's Avatar
David
Old style Precision 2400 that I traded for
Fireball is offline
Old 06-08-2010, 06:03 AM
  #557
Fireball's Avatar
Just a quick update:
didn't get alot done in the last few weeks, but...
Got the 1/8 plate and that fugger warped too. the way I was trying to make the hvac plate just isn't going to work (holesawing a 4" hole, passing a 4" aluminum pipe thru and welding both sides). it tends to pull the plate in funny ways when welding. I've tested some other ways with scrap and it seems that cutting a 3.5" hole, butt-welding a 4" pipe to both sides then cutting down the lip provides a warp-free setup, so I'm going to try for a third time doing that
Since the wing is done, I removed that from the car, going to get the parts coated. Will be getting the little pontiac bumper supports done in black chrome...should look cool
With the wing out of the way, I added a little more reinforcement to the the dual chute mount...also added some supports for the chute cables. just need to finish weld eveything then get that coated.
Fireball is offline
Old 06-08-2010, 06:30 AM
  #558
1fast bird's Avatar
Sounds like it's soon time for paint. Can't wait to see this get done!
1fast bird is offline
Old 06-08-2010, 06:40 AM
  #559
White.Lightning's Avatar
Is it possible to make the HVAC plate out of steel instead of aluminum?
White.Lightning is offline
Old 06-08-2010, 07:13 AM
  #560
Fireball's Avatar
yeah...but you can't weld aluminum to steel.
Fireball is offline
Quick Reply: Fireball Outlaw Drag Radial Rebuild Thread
