Fireball Outlaw Drag Radial Rebuild Thread
Old 06-14-2010, 06:01 AM
  #581
Fireball's Avatar
Originally Posted by elias_799
the hot side is not a little close to the rad ?
probably wound not matter anyway, you just do one pass and let it cool
yeah...close, but will be covered with thermal wrap...
Fireball is offline
Old 06-28-2010, 11:51 AM
  #582
Fireball's Avatar
Been a while since any updates...
I got the rear t-top area tinned over the weekend...that was a royal PITA since I ran two bars back to the frame rails for support (had to go around those bars. I also removed the spare tire well and the little well on the drivers side of the car too. Got it all seamsealed and primed...didn't get a chance to snap a pic of it yet
Also, a few weeks ago I dropped off my pontiac emblem wing strut supports (that go on the bumper) to a local shop that is doing a brand new spray "chrome" process (its actually silver-based). They got the chrome part done. The next step is to leave the border and the tabs chrome and do the rest of it in a translucent red. Should look "close" to an actual pontiac emblem when finished
here is one of them after the "chrome" step
they should look similar to this when done
I need to verify availability, but I plan on taking the car for cage certification wednesday night.
Fireball is offline
Old 06-28-2010, 12:19 PM
  #583
Coal Mining Director
onfire's Avatar
Nice detail.
onfire is offline
Old 06-28-2010, 06:47 PM
  #584
Fireball's Avatar
Picked up the finished pieces...they came out SWEET
Also snapped a few pics of the rear hatch area....that sh%t was a PITA to work with
The holes are to mount the water tank and the battery box.
Fireball is offline
Old 06-28-2010, 08:30 PM
  #585
Boosted One's Avatar
Looks great Brian! Who did the spray chrome for ya?
Boosted One is offline
Old 06-29-2010, 05:59 AM
  #586
Fireball's Avatar
sent you a PM.
Fireball is offline
Old 06-29-2010, 09:32 AM
  #587
Fireball's Avatar
Oh...I hope we made the right call...but decided to go with the RHS block on this build...by the time we added up all the parts needed for the LS2 block transformation + the 40+ hours of Shawn's labor to make it happen...it seemed like a no-brainer to go with the RHS. Since I'm short stroke, we're going with the std deck
what we really liked are the quality of the block, the beefiness of the mains, the strength of the liners (shawn hasn't seen liners this strong/hard before). Also liked the raised cam since it allows us to run a much shorter pushrod
General specs:
4.125 bore
3.622 Callies Magnum XL crank
6.125 GRP Pro aluminum Rods
Custom JE pistons
Custom Va Speed solid roller turbo cam
ETP 265cc heads (6-bolt)
Titantium intake valves
Inconel Exhaust valves
Jesel Rockers
should be a bad little bi%ch at 40++ psi boost
Fireball is offline
Old 06-29-2010, 10:46 AM
  #588
383lt1impala's Avatar
i been lurking ever since u started this thread and good job man its bad ***.
383lt1impala is offline
Old 07-07-2010, 06:01 AM
  #589
Fireball's Avatar
woohoo...cage certified last night...
legal down to 6.50 @ 3600 lbs
Fireball is offline
Old 07-07-2010, 06:37 AM
  #590
Race your car!
JL ws-6's Avatar
Nice work Brian, great to see it certify I'm sure.
Good to hear on the motor too, that should be a SOLID piece. I have heard from 3 people now that the liners in the RHS block are really hard material.. I'm not sure what they did or what they used... but they certainly aren't the std liner that the machinists are used to.
I'm considering taking this route.. I have the solid roller 408 sitting here, but the bottom end was built for n/a use, and I don't think I'm gonna be comfortable spraying this thing with any real power.
Probably gonna end up building another shortblock, see if I can get the 4 inch bore ls7 heads converted to 6 bolt, and reuse the solid roller parts, probably do a more nitrous orientated camshaft while I'm at it.
Might have to talk to Shawn about that once the car's finished, I'm very interested to see how it holds up for your application, if you have good luck with it, I'm sure it will work for the 1/2 speed setup I want to complete.
JL ws-6 is offline
Old 07-07-2010, 08:54 AM
  #591
onfire's Avatar
Great accomplishment!
onfire is offline
Old 07-16-2010, 08:07 AM
  #592
Fireball's Avatar
Moser axles suck...some twist on my 35-spline pieces of junk
Fireball is offline
Old 07-16-2010, 08:50 AM
  #593
onfire's Avatar
How old are they Brian? I'm running 35 gun drilled that were bought in early 2007 and just checked them....they look fine. I "heard" some of the Moser QC went downhill 2008-2009.
onfire is offline
Old 07-16-2010, 08:51 AM
  #594
Race your car!
JL ws-6's Avatar
Nice. Moser better get their **** together or noone's gonna be using anything they sell anymore.
I've already made the decision that the fab 9 I'm gonna do will have strange or mark williams parts in it.... and I'm not even going fast.
JL ws-6 is offline
Old 07-16-2010, 09:40 AM
  #595
Fireball's Avatar
about 3yrs. they use an induction hardening which only hardens the surface...and they do it before splining...
Ordered a new set of strange axles from MADMAN...they harden much deeper and don't do it until after the axles are complete.
I've been pretty hard on them...180 mph at 3500 lbs is hard on parts
Fireball is offline
Old 07-16-2010, 03:27 PM
  #596
Fireball's Avatar
Starting on my next project...in an effort to shave some weight, I'm cutting off the spring perches (which I don't use since I'm coilover) and the Moser LCA brackets. I need a pretty serious drop in the back (since the car is pretty low). Moser brackets + relocation brackets just don't go far enough...I had to add a relocation-relocation bracket last year to get my geometry right...all those brackets overlapping add up in weight
Started with a generic trailing arm bracket from A&A manufacturing...cut it apart and had to extend it down to add another hole where I needed it. welded on two clipped washers as reinforcement in that area...just need to get some plate and weld it back together
Fireball is offline
Old 07-17-2010, 01:31 AM
  #597
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
Didn't Phil have the same issue with his axles from Moser? I am planning on doing the same thing to my 9'' housing. It already has some pretty serious LCA brackets on it, but the wheelie bar mounts and spring perches are coming off.
Beaflag VonRathburg is offline
Old 07-17-2010, 06:25 AM
  #598
Fireball's Avatar
yeah...his twisted too...he went with strange as well...
Fireball is offline
Old 07-18-2010, 02:14 AM
  #599
OWN3D BY MY PROF!
^ I think after seeing your guy's issues with the Mosers I'll go Strange from the start. I have Phil's old S95. It'll make it on my 93 eventually. I've only been gathering parts randomly for it so far. I've been basing all of my effort around getting my Formula running. After that...
Old 07-18-2010, 01:31 PM
  #600
Fireball's Avatar
nothing like a day of heavy grinding, cutting, and sanding. Super hardcore weight reduction
Probably 9-10 lbs when all is said and done. Best part is that its all unsprung weight
Cut off the moser spring perches, and the LCA bracket assemblies. took quite a bit of time but its all good The LCA brackets I cut off came in at 6.3lbs each My new ones are ~3.6lbs each. Spring perches together weighed 2.6lbs. This is only weighing the big pieces left over after plasma cutting. I probably ground/sanded off another 1/4 to 1/2 lb of metal
Also ordered my new axles with pocket milled axle flanges. Probably will shed 1lb or so per axle I'm guessing
!Passenger side spring perch (there was a thick spacer to level the spring perch with the tube...just cut that all the way off of the panhard bracket and simply plated over the hole with 1/8 plate...
!Driver side spring perch
!Passenger side LCA bracket
!driver side LCA bracket
Fireball is offline
Quick Reply: Fireball Outlaw Drag Radial Rebuild Thread
