Fireball Outlaw Drag Radial Rebuild Thread
#601
UNDER PRESSURE MOD
If working in your garage is anything like working in my garage, then you probably lost 5-10lbs worth of sweat today as well. As least I did this past week working out there at night. Looks good Bryan.... so when are we heading down to Va Speed to get your motor?
#603
Race your car!
I've been working on finishing my garage off since father's day.. wiring, insulation, sheet rock, mudding, taping, texture on the ceiling, paint.... I'm ALMOST done LOL. Just have to put the light fixtures back up, plug covers on, and touch up the trim one more time and it's finished... just have to put everything back in, get some new shelves too.
It's been retarded working on this stuff in this heat that's for sure... but I do have an a/c out there now
It's no central air, but a 9000 BTU unit does a decent job of knocking the heat and humidity out of the room. It was 96 outside my garage in the shade yesterday, and even with the paint drying (creating alot of humidity) it was only 80 in the garage... not great, but it's certainly better.
This morning it was 74 outside @ my house... I went in the garage to see what the paint looked like after having a night to dry, and the a/c was off, I had it set down to 68 and it was 68 in there... so it's working. Now, just have to get Subarubill over this fall to put some heat in, and then I can work all year round.. maybe actually make some progress on my sled, maybe enough so I can post some pictures on here someday
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Embarassed](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_emb.gif)
#605
Race your car!
I have a 24x24 detatched.. it's not huge, but enough room to do what I need to. Now that it's finshed... I can work in the winter once the heater's in and not have to deal with picking up tools that are frozen, workign on frozen parts, etc. Summer time like now, it's not gonna be an icebox, but it's a hell of alot better then nothing that's for sure.
#606
OWN3D BY MY PROF!
You guys are lucky then because my garage is the first floor of my town home. I had to knock a wall out to fit a second car in there and it still barely fits. The only air conditioning I have is opening the garage door and the entrance door on the other side. Thankfully, my garage door faces the east and I'm a block from the ocean. Most of the time it blows North-East, but when it blows out of the west I won't even go in there. The AC upstairs doesn't work correctly either so it stays about 87* inside during the day and drops to around 82-83* at night.
West side of my house:
![](http://img841.imageshack.us/img841/2209/hotv.jpg)
Enjoy your cool weather...
#607
UNDER PRESSURE MOD
I made the mistake of pulling the t/a in the garage yesterday after driving it to work and back, and I then closed the door and went inside the house. I came back out 15 minutes later and it was 110 degrees in the garage. I guess the R-35 I put in the ceiling last year helped because it was a sauna in there.
Back to the subject at hand... Bryans race car... any new body pics Bryan? What color scheme are you going to go with?
#608
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
we painted all my rear suspension components and front upper a-arms with the rustoleum hammered paint (will do the kmember and lower a-arms when I pull the motor). I hope to finish the rear housing tomorrow (need to finish my LCA brackets and get them welded on). then I'll paint the housing with the hammered too...
For color scheme...going with a single color using Summit racing's new base/clear paint line (hey its cheap and supposedly a decent paint). I've shot PPG and Dupont paints in the past, so we'll see how this stuff is...but getting all the required material for ~600 is hard to pass up
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
![](https://static.summitracing.com/global/images/prod/large/sum-up333_w.jpg)
#614
OWN3D BY MY PROF!
PFFTTT... You're made of money. Why not just wrap the car in 24 carat gold.
http://www.vividracing.com/blog/rand...i-in-progress/
#615
worked on it for about an hour....too f'n hot outside ![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
welded on the two sides of the passenger LCA bracket...just need to weld up on the inside and install the rear plate cap.
![](http://home.comcast.net/~tfranklin5580/new_lca_1.jpg)
![](http://home.comcast.net/~tfranklin5580/new_lca_2.jpg)
#617
OWN3D BY MY PROF!
I could be wrong, but judging by the sizing or so those LCA spacers look like the same sizish of Wolfe's. My LCA mounts are now very narrow and barely allow for any movement. Are you planning on running the spacers offset all the way like that or centering the rod end between two spacers? I simply ask in reference to the end possibly binding.
#618
those are wolfe LCAs. keeping them fully offset to maximize tire clearance....they were really close before so I pulled the LCA brackets closer inboard this time.
#619
OWN3D BY MY PROF!
I have the same LCAs that's why they looked familiar. I'd have to look at mine again, but I think they are closer than yours are. I haven't looked at them in a while, but I couldn't fit the full sized spacer wolfe provides into the LCA mount. I was thinking of making two smaller spacers and centering the rod end so it won't bind.
#620
I had to cut one down on my old bracket since it was narrower...I just made this bracket so it would fit what I had. I don't have alot of room to work with since I run a tucked 315 tire
