Fireball Outlaw Drag Radial Rebuild Thread
#1363
What about restricting the flow of oil a pinch? I know I've seen that done in the past.
#1365
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I have a scavenge pump, but I mounted too high...even though it can draw up, it reduces the flow...I lowered it so its lower than the turbo now.
Dropping it in at our local ODR race today...
#1368
Does having a dry sump fix this problem completely or lower the chances of it happening?
For some reason I was comparing your times to phil's mph in the 1/8. Hopefully you can get up there too!
#1369
Let the turbo drain to a small tank (like a overflow bottle with a breather) Then have your scavenge pump suck oil from there. You will not have any more problems with oil backing up into the drain line.
#1370
thats what I want to do, but it would hang so low I'm afraid. it still did it yesterday, though it took longer and not as severe. so it was an incremental improvement. I think I'm going to try a turbowerx exa pump vs the mocal. it has 50-100% more flow. the mocal is listed as 1-2 gal/min and the exa as 3 gal/min.
#1371
#1373
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Did you fix the oil issue then or is it just band-aided right now? Turbowerx sounds like best solution...have you thought about going to dry sump at all or do you see it unnecessary at this point?
#1375
http://www.turbowerx.com/Scavenge_Pu...odel_Pump.html
#1376
Yes, I think this is the one to get. You can even run it dry and it won't hurt it.
http://www.turbowerx.com/Scavenge_Pu.../Exa-Pump.html
