Fireball Outlaw Drag Radial Rebuild Thread
#1503
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
scavenge pump is fixed. I put in some allen head screws with some loctite to secure the pump to the bracket. Also put a large hose clamp around the pump and bracket to further secure it....
have a higher pressure sensor for my AMS1000 on the way so I can get the boost higher than the low 30s
plan on making some more hits tomorrow night
![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
#1504
0 for 3 last night
first pass...1.39 60', blew the tires HARD at 100' out....car went completely sideways at 75mph
2nd pass...1.36 60'... had a sync loss with my crank sensor at top of first gear (aborted)...tightened up the gap some more...
3rd pass...1.33 60'...idiots at the track wasn't paying attention and let a truck roll down next to me after I started building boost. Had to back off and restart...most likely overheated the converter/trans and blew through 2nd gear bad
fugger is making some serious power now...hit 33psi...Ended up going 9.80 only in the gas for 300ft
![Icon Eek](https://ls1tech.com/forums/images/smilies2/icon_eek.gif)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
#1507
first run (definately drove out of the groove...probably why it spun)
http://www.youtube.com/watch?v=M21M0TGNRfE
third run (blew through the shift and hit the rev limiter...pretty cool fireballs
In the gas ~4seconds... and coasted to a 9.80
http://www.youtube.com/watch?v=mVIMfGSU_wo
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
#1511
trans is freshened up and back in the car...
parts are coming today so I can weld a transcooler into my icewater tank. Extra cooling should help out![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
gonna try to make a few hits tomorrow if all pans out...
#1519
I was never a sponsor...
One of my sponsors was a sponsor, but temporarily closed up shop while he was building a new house.
I did alot of watching and learning while hanging out there...this whole rebuild was done in my 2-car garage
Only things I didn't do was the engine or trans builds
