Twin MP70's on an LS3 416 w/ AFR 225's
Old 11-24-2010 | 08:22 AM
  #261
lt1773's Avatar
is that with GM ls3 block ??
Old 11-24-2010 | 02:50 PM
  #262
bonnarls1's Avatar
got the motor in last night, need to wire up the holley hp,put on the turbo's
and get it starter this weekend!!!!
Old 11-29-2010 | 09:02 PM
  #263
98Z28CobraKiller's Avatar
Restricted User
Yes. And now it has a stock crank so cubes are down to around 380ci.
Here's the motor on the kmember ready to go back in.
In the car.
Here is a picture of the stock modified cluster with the Holley programmable gauges in it. This turned out to be a great idea that one of our Ford buddies came up with.
Old 11-30-2010 | 05:44 AM
  #264
98Camarod's Avatar
Which k member is that y'all are running?
Old 11-30-2010 | 12:05 PM
  #265
bonnarls1's Avatar
bmr turbo k-member!!!
Old 11-30-2010 | 12:56 PM
  #266
98Camarod's Avatar
Sweet! That's what I just ordered and I plan on doing a twin turbo build.
Old 11-30-2010 | 09:27 PM
  #267
craig382ci's Avatar
Hey Carlos what do you think about that Holley EFI ECU?
Old 11-30-2010 | 09:29 PM
  #268
Restricted User
Should know more in the next few days. Steve is wiring it up in Joe's car as I type this.
Old 12-05-2010 | 04:06 PM
  #269
sicksrt4's Avatar
Originally Posted by 98Z28CobraKiller
$400 and they could be yours. Not these. But ones just like them.
What would it cost for hot side and cold side minus turbos?
Old 12-19-2010 | 09:59 PM
  #270
xdamxincx's Avatar
20k later ... on easy street !!
BBC pt106.... sup?
Old 12-19-2010 | 10:50 PM
  #271
3fingas's Avatar
Originally Posted by xdamxincx
BBC pt106.... sup?
Carefull, He'll come out and beat up on that BBC. Your gonna need another screw. LOL
Old 12-19-2010 | 11:25 PM
  #272
xdamxincx's Avatar
pffftttt......
Old 12-19-2010 | 11:35 PM
  #273
westtexasbuff's Avatar
The LS3 is almost back together. It's getting a stock stroke crank and low compression pistons so the cubes will be around 380-382ci. We are looking for 9.5:1 compression.
If you don't mind me asking, what brand pistons and rods you all went with on the stock cube setup now? I'm wanting to build a stock cubed forged ls3 for boost as well, but didn't know what companies offered forged pistons for that bore...
Are they Wiseco? Or is there even Wiseco forged pistons available for the LS3?
Old 12-21-2010 | 09:00 AM
  #274
Restricted User
Hot side minus turbos is just the exh manifolds and the 2 pipes that the turbo and wg attach too. I'd say you could get it done for $600-$800 easy including all the flanges.
Old 12-21-2010 | 09:02 AM
  #275
Restricted User
BBC pt106.... sup?
This is a mullet free work place.
Old 01-07-2011 | 07:20 PM
  #276
bonnarls1's Avatar
cars done, took it to the track on wed.ran on wastegate's i can only get 4lbs
on the springs no two step wasn't hook up yet left on the trans brake built no boost leaving went 10.4 at 130 not bad on 4lbs!!!!!
Old 01-07-2011 | 08:06 PM
  #277
Rickys S/C Z28's Avatar
hmmm wander why there was no boost? but your right thats rocking for 4 PSI!! hahah
Old 01-07-2011 | 08:09 PM
  #278
71 chevy's Avatar
wow, that is exciting for only 4 psi boost. are you sure there are springs in the wastegate?
sounds like there might not be springs in them at all.
ps. just looking at your old times NA, it looks like it picked up nothing over the NA setup. what would you attribute this to?
Old 01-07-2011 | 09:16 PM
  #279
71 chevy's Avatar
oh, never mind I see that the stock crank dropped cubic inches from 416 to 380 or so. not bad at all.
Old 01-08-2011 | 03:55 PM
  #280
Restricted User
Went back out today. Still no 2 step. Wiring guy is slacking. Car went 10.34,10.42,10.38 all at 130.XX. Really soft 60 due to there being no boost on the tbrake and the full 4 psi doesn't arrive until right at the 60'.
As to why there is no boost on the transbrake, He is running 2 44mm wastegates which is way more wastegate than he needs. You gotta remember that wastegates are mechanical devices (specially w/o boost controller and CO2) so they are not an ON/OFF type thing. As you start building exhaust pressure, the wastegate will start to crack open. More so with a really soft spring. Add the fact that the WG 's are way big and it just takes them cracking open just a little bit to bleed off alot of pressure. If he put in the 8 psi spring, I would bet that he would have atleast 1-2 psi by the 4K RPM that he is launching. With this soft a spring, the 2 step will likely only give him 1-2 psi anyways so the answer is boost control + CO2 which will be coming very soon.
The main thing right now is just make sure that everything is working good. The new Holley EFI system is an absolute dream to tune on and the closed loop fueling holds target AFR VERY well all the way thru the passes without much tuning on my part. It also learns on each pass so that it has to make less corrections each time.
Another thing is that everything is setup way conservative. I'm sure that with his current compression and E85 at this boost level, we could be hitting it with 28-30* but it's only got 24* and the AFR is at 11.5 on a gas scale.
Joe's been pretty unlucky for the last couple of years so we are taking it slow and double checking everything to try and change his luck. LOL
Quick Reply: Twin MP70's on an LS3 416 w/ AFR 225's
