My Burkhart Intercooler setup!!!
How much area does it have? Lxwxh?
The only things I dont like about it is the inlet and outlet are directly opposed, so its possible since air takes the path of least restriction seeking low pressure that most of the air may simply flow through the center, with very little comming from the top or bottom of the tanks. Being so thick the rear core may not do much cooling either, being heat soaked due to little air flow and heated air.
None of that really matters though, if when you use it, you see substantial iat drop compared to what ever you did have, at the same psi level then it works.
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
Also, let say you build an intercooele thats 3 feet tall and 3 feet wide, ie totally massive and way over kill. even if the air is only passing through the center of the core, wouldn't the heat transfer to the out sections of the core and still provide wooling? after all ally makes for a very effecitve heat sink dose it not?
I am not teying to be an **** here, just thinking about things and typing. lol i think end tank design is somehting that is not really looked at very much in the aftermarket world. I have seen F1 turbo setups with end tanks that look stupid, but they work VERY well and get very even air distribution.
also how dose putting the air through a 270 degree bend (pipe inital 90degree bend then the 180 degree to bring the air inline with the tubes) compear to simply butting the pipe to the end tank at 90 degrees to the core? if you shaped the end tank (i have sene this done on a Noble) would that not be better at getting even air distributuion than the air hitting the tubes head on?
Just think out side the box.
Cheers,
Chris.
