AES 390ci - Now with Callies Dragonslayer crankshaft
Old 04-01-2012, 10:00 PM
  #321
AES Racing's Avatar
Originally Posted by 3.8to6.0
Bump...
Can anyone confirm, for a fact, that the Dragonslayer crankshafts are not backordered?
The 3.800/3.819 dragonslayer crankshaft is one that I personally ordered, basically had to put my name of 5 crankshafts each order for that to happen, if they show up and have no buyer, I have to explain why Its a zero-sum game.
At this time, every order for 3.8" dragonslayer crankshaft is filled, I haven't taken any new orders for 3.8" dragonslayer crankshafts or placed an order with Callies at this time.
Old 04-01-2012, 11:26 PM
  #322
3.8to6.0's Avatar
Thanks for the clarification Fraser. Keep up the good work!
Old 04-04-2012, 12:17 AM
  #323
SChamberlin5150's Avatar
Im lookin to get 1500 crank hp out of a ls based motor for a 5000lb truck with 40" tires. would you suggest the LSX 390 or 410? What about heads and turbo/turbos. Can you ballpark a figure on those. also is there a price difference for the 410? my 900 hp turbo 5.3 just isnt cuttin it anymore.
Old 04-04-2012, 06:08 PM
  #324
I8UR4RD's Avatar
Originally Posted by mike13
cool what rotating assembly are you going with?
sry for the late reply. skipped right over the post.
Its the 390 with diamond ----15cc pistons 9:6:1 CR
Callies H beams
1/2 head studs
Callies C-series Crank
ARP Bolts
LS9 head gaskets
LS7 Lifters
GM Rockers & Bolts
PRC 237' 68cc
Brutespeed Blower cam 115lsa 232/240 .595/.608
Melling High Volume Oil Pump
LS2 water pump
Aster Bracket
JP Billet Double Roller
Brand new D1SC w/ATI FMIC with boost as high as I can get it to go without overspinning, and turning 6550rpm's.
going to run it on a lonnies double pumper with 100 120lbs injectors on e85 with methanol(overkill). should be a sweet setup. placing my order tomorrow. Just finished painting my ls6 intake so it would not look like a turd on a silver platter. Charge pipes were powdercoated and I have alot of engine dressup items coming as well as the wire mod. I am overdoing it, but arent we all.
Old 04-05-2012, 08:24 PM
  #325
I8UR4RD's Avatar
Hey AES, with the new motor I am ordering, has anything been done to address the temps in the cylinders.....My 02 ws6's ls1 has the ls6 intake and that year the rear steam vents were blocked off. That did not matter at stock power levels, but as soon as power came on.....ringlands were gone. I have even heard of forged motors going this route. I am not the most educated guy when it comes to lq9 blocks, but I just wanna make sure we keep em all cool. If a Kurt Urban Steam setup is needed to ensure longevity in my street car then that is a route I would gladly take if you thought it necessary.
Old 04-05-2012, 08:48 PM
  #326
AES Racing's Avatar
You were running coolant crossover on the heads right?
Fraser
Old 04-06-2012, 06:00 PM
  #327
Anchor's Avatar
How long is the wait on a motor from AES? I emailed Fraser on Sunday and messaged him here yesterday. Just waiting for a reply with some prices so I can spend some money.
Old 04-06-2012, 06:25 PM
  #328
offaxis's Avatar
I have the AES 390 with the dragonslayer in my car now for around 2,000 boosted miles. Motor runs great . Oil pressure is very good and I would recomend AES to anyone looking for a quality motor at a very fair price.
Thanks fraser
Jeremy
Old 04-06-2012, 09:10 PM
  #329
AES Racing's Avatar
Thanks fraser
Jeremy
Good to hear, thanks for the update.
Old 04-06-2012, 09:11 PM
  #330
AES Racing's Avatar
Message sent.
Old 04-07-2012, 05:55 PM
  #331
I8UR4RD's Avatar
Fraser
nope. did not know they were blocked off until afterwards. But i wanted to address it while you guys were still in the process of getting the motor together for me. I did not want it to be an issue with the 237's. apparently the 98-2000 ls1 cars did not have this issue because the ls1 intake did not interfere with the coolant crossover lines. learn something new everyday is what i said to myself. fool me once shame on you. fool me twice.....you get what im saying here....haha.
Old 04-08-2012, 11:20 PM
  #332
AES Racing's Avatar
So you ran block offs on all 4 holes in the heads? I'm asking cause I've never seen anyone do that. The newer style is a crossover pipe that connects the cylinder heads, the block offs go on the back 2 holes in the heads, did you have that it that way?
Old 04-09-2012, 12:17 AM
  #333
I8UR4RD's Avatar
I had it the way the factory had it. apparently in 2001-2002 when the ls6 intake was added the front two were used while the back two were blocked off. this is considered a leading cause of number 7's infamous high temps and ringland failures. an interesting thread to say the least.
"98 through 2000 are vented front and rear but do not come with LS6 intakes. 2001-2002 cars came with LS6 intakes but plugged rear vents"
https://ls1tech.com/forums/forced-in...why-7-a-2.html
Old 04-11-2012, 09:45 AM
  #334
allout06's Avatar
ill be giving you guys a call soon. to get an estimate. basical looking for something to handle 850rwhp on a D1 car. ill be on touch. do i get a discount for referring I8URFORD to you and him purchasing one?? lol
Old 04-12-2012, 09:09 PM
  #335
3.8to6.0's Avatar
According to Callies' website, the 3.625" stroke Dragonslayer is not a special order crankshaft. I think I may just go with an AES 370 when the time comes.
Old 04-12-2012, 09:16 PM
  #336
AES Racing's Avatar
You want to build a 370 with a dragonslayer 3.625" crankshaft?
Old 04-12-2012, 09:45 PM
  #337
allout06's Avatar
what kind of power does your AES 390 handle for $3899?
  #338
3.8to6.0's Avatar
Why not? In the latest issue of GM HighTech magazine, they are building a 370 utilizing a forged Lunati 3.622" crank.
Old 04-12-2012, 11:51 PM
  #339
LC
LC's Avatar
I might just as well build a 372.. this 3.8XX crank stuff is just
Old 04-13-2012, 10:57 PM
  #340
I8UR4RD's Avatar
1100-1200 has been done so far. not sure what the limits are because noone has really pushed it far enough to see. it can def handle the baby power we are going to throw at it. haha.
Quick Reply: AES 390ci - Now with Callies Dragonslayer crankshaft
