.96 or 1.15 a/r housing behind 355 LT1?
Long story short
I have purchased a log kit from real quick like 2-3 yrs ago one of his 1st. This one came off of 10sec lt1.... Anyways lost interest in this for a good while, the other day I was figuring how much $$$ i have in this pit, which made me decided to go ahead and get the thing going. Yes throw more money at it
To the point:
Which exhaust housing would be better for this kit/build the .96 or the 1.15 twin scroll. I am thinking the 1.15 as it will flow more up top and spool almost identical to the .96 housing. Any insight on this would be appreciated...
Specs
3.480" 4340 crank
5.7" 4340 h-beam rods
-24cc dished diamond pistons
Custom A.I. Turbo Cam
Splayed Mains
1/2 filled
Off the self 62cc TrickFlow Heads
1.6 CC Ultra
TH400 Trans
Stall?
To the point:
Specs
3.480" 4340 crank
Splayed Mains
1/2 filled
1.6 CC Ultra
TH400 Trans
Stall?
Long story short
To the point:
Specs
3.480" 4340 crank
Splayed Mains
1/2 filled
1.6 CC Ultra
TH400 Trans
Stall?
To the point:
Specs
3.480" 4340 crank
Splayed Mains
1/2 filled
1.6 CC Ultra
TH400 Trans
Stall?
Coal Mining Director
Long story short
To the point:
Specs
3.480" 4340 crank
Splayed Mains
1/2 filled
1.6 CC Ultra
TH400 Trans
Stall?
To the point:
Specs
3.480" 4340 crank
Splayed Mains
1/2 filled
1.6 CC Ultra
TH400 Trans
Stall?
Depends on the unit. The 76GTS the biggest you can go is .96A/R so no choice other then that. If its the Tnetics unit with the F1-68 wheel, then definitely go with the 1.15A/R...as its almost identical spool to a .96A/R and you get the added flow with the smaller turbine.
TC76 F-1 GTK Turbine wheel. Hoping to run it at 14/15 lbs no low/high boost setting. I want it to run top notch all the time no excuses. no low boost setting or anything like that, its a weekend car so it will come out and play weather permitting.
That will work just fine with an LT1 and a 1.15A/R. The LT1 doesn't have the heads of the LS based motors so it will run just fine with that setup at that boost level.
The 1.15A/R is around 1/4" larger Diameter.
