Fairmont 2.0 (forged lq4, s480, 800whp, under new management)
Old 09-30-2012, 10:17 PM
  #1041
redss82's Avatar
Originally Posted by denmah
yeah its a shame its no where near my house... LOL
We have the turnpike, kutztown, and now the gas station on 309 just north of mack truck and 22 those stations have e85 but this thing is already wild haha
Old 10-01-2012, 12:17 AM
  #1042
Moderator
denmah's Avatar
Originally Posted by malarlar
Are you using stock 799 valve springs? What rear end is in this car and what axles?
they have PRC duals, pretty awesome springs already
came out of my friends turbo truck
i have a mustang 8.8 in the car with 28 splined alloy USA axles, ssbc rear disk brake conversion, 3.55 gears, welded stock posi dog gears.
255x60x15 drag radials. on mustang lx 10hole wheels.
Old 10-01-2012, 01:27 AM
  #1043
atomic 6's Avatar
I put those ebay studs in before DragWeek this year, and they held up just fine on the "low boost" I was running. 18 lbs max on 799 heads on a 5.3(l33)
But then again the 800 to the rear wheels that I made on the dyno was with the Factory TTY bolts, also at 18lbs.
I torqued them to 75 lbs, with arp lube, not one broke. And I have had ARP bolts break on me before, while tightening them to 75lbs, with their lube also.
Old 10-01-2012, 10:22 PM
  #1044
Moderator
denmah's Avatar
yeah wtf is up with that! i broke one of mine on the recommended 75, i only do 65 now, i have one of those KMJ stud kits on the way for another car we are building...
i cant wait to push this thing on the dyno with the new heads, pretty excited to see what kinda power i gain, like i said 40rwhp would be awesome, put me from 585 to 625 on 18
Old 10-01-2012, 11:11 PM
  #1045
67Firebird455's Avatar
Just watched your video again of that pass, makes me giggle every single time. Just to think of what that dude in the silver eclipse was thinking as you flew by him. LOL
Old 10-02-2012, 08:44 AM
  #1046
a4ls2goat's Avatar
Are the rear water jackets from the 799 heads blocked off?
Old 10-02-2012, 09:42 AM
  #1047
Moderator
denmah's Avatar
they were on the truck, i just connected my steam tube again.
Old 10-02-2012, 05:10 PM
  #1048
Boosted Firehawk's Avatar
wondering if you guys keep all the 5.3 engine sensors are swap them over to f body sensors?
I have a 00 harness so what sensors should be used?
Old 10-02-2012, 05:14 PM
  #1049
is that kmj bolt kit for both heads complete? wtf thats cheap
Do you think it can make over 20 psi on those bolts?
I know they are not arp but wtf why not try em for that price. Its not like were building 1400hp engines that have over 5k just in the bottom end.
Old 10-02-2012, 06:33 PM
  #1050
86lxnotch's Avatar
im at basically 20lbs and they are fine. yes complete set, even has the m6 or w/e the small ones are as well
Old 10-02-2012, 07:00 PM
  #1051
Moderator
denmah's Avatar
nearly all GM sensors are the same since like 1986, im using junkyard sensors, i usually get the tps and the coolant with the motor, the IAT sensor i cut out of a 3800 series 2 supercharged buick
ive had many many stock head bolted, stock head gasket, even paper gasket motors hold over 20lbs, try not to think of everyhing in PSI though, its relative.
Old 10-03-2012, 12:58 PM
  #1052
Ok cool, Im thinking of ordering these studs right now just to install them while my heads are off.
But then I keep thinking of just putting in some arp bolts
either way its getting ls9 head gaskets on my 706 heads.
UNLESS you make more power with the 317 heads and driveability is far better than the 706s.
Old 10-03-2012, 02:44 PM
  #1053
Moderator
denmah's Avatar
we are gunna put the 317s we had on a newer 4.8l with flat top pistons, and then that is going in a pontiac sunbird and we are gunna hit it with at least 26lbs and those KMJ studs
Old 10-03-2012, 09:06 PM
  #1054
Moderator
denmah's Avatar
654rwhp today over 24psi i cant tell how much it was bit my boost controller peaked out at 29, it was blowing out spark anyway.
turned it down to a more manageable 24psi and 641rwhp 600ftlbs
here is the video of it blowing spark and coughing on fuel making 654rwhp
http://www.youtube.com/watch?v=wllA0...ature=youtu.be
Old 10-03-2012, 09:20 PM
  #1055
Stumped1215's Avatar
So do i win closest without going over? lol
Old 10-03-2012, 09:30 PM
  #1056
Moderator
denmah's Avatar
well here is the thing, it seems to have made nearly the same hp.
it did 585rwhp on 18psi before, and it did 590 near that today.
i just turned it up to 24-25lbs
so, i must have a bottleneck somewhere, possibly the stock ls1 intake? or the intercooler? or something. i went bigger turbo and bigger heads and it makes the same power as the 68mm and the 706 heads.
so something is holding it back? or is this just the biggest heart breaker dyno ever lol.
Old 10-03-2012, 09:33 PM
  #1057
I'd put my money on the ls1 intake. I've seen a couple people make big power on the ls6 though.
Old 10-03-2012, 09:54 PM
  #1058
Moderator
denmah's Avatar
my friend has a nearly identical build
th400, 5.3, s475... ls9 cam etc. it had a truck intake and we put a ls6 intake on it.
it picked up 40rwhp on 18psi
made 607rwhp on 21lbs
ive heard of people making 700whp on ls1 intakes... might be the ceiling as i am pushing hard... anyone else on here using ls1 intake?
Old 10-03-2012, 09:58 PM
  #1059
TX RED's Avatar
have you thought about trying a truck intake
Old 10-03-2012, 10:08 PM
  #1060
Moderator
denmah's Avatar
i guess i could try it, it wont clear my hood.
Quick Reply: Fairmont 2.0 (forged lq4, s480, 800whp, under new management)
