New 347/F1A build
New 347/F1A build
Gonna be starting a new build and just want to make sure that I have all of my bases covered. Suggestions are welcomed.
Engine
Stock crank
Compstar rods
-8.6cc diamond pistons
Custom cam 230/242 115+3 .6xx/.6xx (Canadian corvette performance speced)
Ported 317 heads
Ls6 intake
Fuel
Lonnie's double pumper
-10an feed line split to 2 -8s to aftermarket rail (haven't decided on the brand)
Factory feed as my return
Boost referenced FPR
Meth injection kit (looking for suggestions on brand)
80lbs injectors
Blower
F1a kit from Brute speed
FMIC
Aster bracket
Trans
Jakes stage 4 4l80e
Jakes converter
Rear
Moser M9 (could use suggestions on gears)
Boost/fuel pressure/wide band/Trans temp gauges will also be in for monitoring and ECS would likely be tuning the car.
Am I missing anything?
Engine
Stock crank
Compstar rods
Ported 317 heads
Ls6 intake
Fuel
80lbs injectors
Blower
FMIC
Aster bracket
Trans
Jakes stage 4 4l80e
Jakes converter
Rear
Looks like a solid plan!
Gear ratio will be based on how much power you're going to make, what size tire and how high you're gonna spin it, lastly weight. Obviously with a blower setup you want to be at peak rpm thru the trap. I assume you'll run a 28" tire. I'd probably guess a 3.73 would be in the ball park. 7000 thru the trap...
If you're gonna make around 850 rwhp, the above guess ta mate should get you in the 145-148 mph range at 3800lbs.
LS1Tech Sponsor
Engine
Stock crank
Compstar rods
Ported 317 heads
Ls6 intake
Fuel
80lbs injectors
Blower
FMIC
Aster bracket
Trans
Jakes stage 4 4l80e
Jakes converter
Rear
Engine
Stock crank
Compstar rods
Ported 317 heads
Ls6 intake
Fuel
80lbs injectors
Blower
FMIC
Aster bracket
Trans
Jakes stage 4 4l80e
Jakes converter
Rear
I recommend Alky Control for the methanol kit.
I'd run a -10 return line if the car will be driven much on the street. Using the factory line for the return can cause the fuel to heat up. If you're kicking on the 2nd pump on under boost then the stock line would be okay, but I still recommend a larger line. I would also go with teflon lines, today's fuels will tear up rubber lines and the fuel smell also leaches out of braided lines.
i agree with ajrothm, if you're going to use a 28" tall tire, I would go with 3.70/3.75 gears.
Have you checked out my prices on Moser M9's? Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
I'm up the the air about running a hobbs switch or running a larger return and leaving both pumps constantly running (a hobbs switch is just one more thing to fail). Thanks for the suggestion about the teflon coated lines, ill make sure that the ones that i get are.
I just looked at your prices on M9s and ill probably be ordering that from you as well (obviously not in one shot haha)
LS1Tech Sponsor
I'll do some research on Alk Control
Thanks, I appreciate it! Bob
__________________
https://ls1tech.com/forums/forced-in...-800-rwhp.html
This is the same cam that i would be using except ill be running an F1A rather than a D1SC
E85 is but only at 1 station and i would be worried about not having it when I traveled with the car for car show weekends and stuff. I could run 2 tunes I suppose but that would require me paying for 2 tunes and 100+ lbs injectors. Trying to keep the build fairly simple and purely a street car
Everything looks good, if you haven't purchased the injectors yet get some FIC 1000's. Never hurts to have more injector and they tune in great.
I agree 100% with everyone on the Alky Control kit-best hands down.
I run the LP kit, 1 pump runs all the time and second is triggered via a Hobbs switch. No issues 5+ years later. I run a -8 feed and a factory return.
I'm assuming that a speed density tune is the way to go since im looking to run around 20psi? I just emailed ECS to see if they'll tune it since they dont have F-Bodies listed anywhere on their page
