Attention all KY-Turbo Customers, Supporters, and Friends:
#542
I thank you and sschoeffler and novaflash2002 for offering help. Lord knows I am going to need all the help I can get. It means a lot. I know I will be needing
1 Stock set of manifolds
1 Stock power steering pump
1 Stock fuel rails
1 Stock ECM
1 speedo cable
1 shifter cable
1 stock Throttle cable
I am not sure if the AES motor will run off the stock injectors or not. But I wanting to go through that stuff in the trunk again and all them boxes. I am hoping that I have over looked something. It would be a great find if I locate the other 4 Bosch injectors.
#548
.…(Thank you Whistler for editing that garbage)
As for parts:
As for parts:
#550
I spoke with Josh no more then a week ago. About sending my Firehawk to him for the Turbo build I was on the fence with the Twin Turbo or a large single turbo .. Thank god I didn't send my car to him or my money.
Thank you Vcious04 for sending me this link..
#551
+1 Brother, glade I could help. Us gear heads gotta stick together
#553
Yeah that is kinda what I figured on the stock injectors. Well at least I have 4 out of 8 Bosch 160lb. I pray that when I go through that stuff tomorrow I will find the other 4. But 4 is better than none, right?
#555
I gotta go through my pile o parts
but I know I have 5.3 manifolds, truck intake complete with injectors and tb
pretty sure I have a power steering pump and bracket completely gutted my car out and got rid of a lot, but I know I still have more stuff I'm not reusing, can check saturday when I"m back at the shop
#556
No they are not interchangeable. In a tcs equipped vehicle, the throttle cable goes to a little motor which is located by the battery and has two other cables attached to it, one which goes to the throttle body and one that goes to the tcs module.
#557
To all,
I will try to help anyone affected by this as best I can. If there is something you need that we can get or make. Just call and I will severely discount it for you. You will need to show proof that you were a former customer of KYTP though, I don't want anyone taking advantage of help.
thanks
Rob & Chris
thanks
Rob & Chris
#558
To all,
thanks
Rob & Chris
thanks
Rob & Chris
#559
To all,
thanks
Rob & Chris
thanks
Rob & Chris
