WS6 S475 official build thread.......
Noticed a little coolant drip from behind water pump area first pull. So we took overflow hose off of the radiator to see when it was lifting the heads. Coolant temps in the high 160s low 170s so we knew if any blew out it would be from boost pressure getting in. Around 6000 rpm at 16 psi you can see in the video its pushing pretty good. Corrected the final number was 775 with 12-13 degrees timing up top. 10.9-11.0 afrs all the way to the top.
It feels so slow on 16 psi compared to the 20+ im use to on the street. Took it straight off the dyno, changed nothing, and hit it on the highway in 4th and made 21psi. Felt like a rocket. Safely id say its picking up to around the 850ish range or better but still the fact remains its lifting the heads lol. Ill drive it like I been doing till I get another engine ready. It may be a while but this one is still running good long as a don't twist it to hard lol. Ill post video in a few. It only shows 761 but ill have Martin post the graph Monday.
Looks like that turbo wants to keep on going!
Really wish I would of been there, I'd of snuck 50% load on the drums when Jonathan wasn't looking so we could get that puppy to make 20psi. Hehe....
