Project Hairy Banana (1967 Camaro single turbo)
Old 05-01-2021, 11:30 PM
  #801
gjohnsonws6's Avatar
Lol Centimeter
Get out and drive it already. Glad you got it working right, I have the 1.125 master hoping to not have any issues but that’s quite a ways out yet.
Old 05-01-2021, 11:33 PM
  #802
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,148 Likes on 746 Posts
Well if the plunger is not pushed when I'm off the brakes the light stays on. I'm a little worried about that because I live in a dense area and a buddy who just finished his car got rearended by someone not paying attention.
Check this out, his first full test drive:
Old 05-02-2021, 12:18 AM
  #803
Wow that definitely sucks after all the hard work. Going back to the beginning I see it was manual brakes when you got it. Did it come factory or was it changed out from power at some time ? Check out this thread
https://www.camaros.net/threads/brak...ch-one.429786/
Old 05-02-2021, 12:47 AM
  #804
LS1Tech Co-Founder
I'll check out the thread. It was manual drum brakes when I got it, I assume that was the stock setup.
I did manual drag brakes cuz race car.
Old 05-02-2021, 12:50 AM
  #805
LS1Tech Co-Founder
Interesting link. I'll investigate tomorrow. I see some info out there about a pedal return spring too, don't think mine has one but maybe it did originally. But I know if I by-hand pull the brake up the plunger is barely engaged, so maybe it's a just a simple adjustment but I'll ask around the 1st gen groups if there should be a return spring.
Old 05-02-2021, 08:08 PM
  #806
LS1Tech Co-Founder
Back on the ground, fixed my rear brake light issue (lube the assembly which made a big difference, spaced out the plunger and also the brake push rod). Put dash back in.
Next stop, I'll drive it some, but after that I have to redo a section of fuel line for my big pump, one section has substantial kink I never noticed. After that I'll beat on it.
So:
-drive
-fix fuel line
-swap ladder bars?
-alignment
-drive harder
Old 05-02-2021, 10:18 PM
  #807
Right on, looking forward to seeing some track times.
Old 05-02-2021, 10:53 PM
  #808
LS1Tech Co-Founder
Well for track times I have to redo small section of feed line to the big pump (Weldon), and swap the ladder bars.
The following 2 users liked this post by Pro Stock John:
spray280 (05-03-2021), The BallSS (05-03-2021)
Old 05-04-2021, 11:03 AM
  #809
LS1Tech Co-Founder
Cleans up decent.
C5_Pete (05-11-2021), The BallSS (05-04-2021)
Old 05-04-2021, 11:30 AM
  #810
98CamZ28's Avatar
Cars looking good!! I just tore mine apart some to fix a rust spot on the floorboard and get some audio stuff setup. Will you be heading out to 41 for testing?
Old 05-04-2021, 02:35 PM
  #811
LS1Tech Co-Founder
For me probably just GLD, lot closer though the resurfacing that US41 looks great.
Old 05-05-2021, 12:47 PM
  #812
LS1Tech Co-Founder
  • Bled brakes about 25 times, wheels off
  • Fixed rear brake light issues, were staying on
  • Did some wiring clean up
Plan to do some weekend driving if I can get a buddy to hang out and help keep an eye on things....
The following users liked this post:
AnnivSS (05-05-2021)
Old 05-05-2021, 02:19 PM
  #813
ryeguy2006a's Avatar
Looks great John! How's it feel on the street?
Old 05-06-2021, 08:01 AM
  #814
LS1Tech Co-Founder
Planning to drive this weekend.
While I did drive the car a few times last fall, a lot of the systems were not complete, no lights lol, crap brakes, car ran a bit hot.
Since then have redone part of the cooling system, swapped brake m/c - bled brakes extensively, finished some wiring stuff. Also had Andrew B start tuning the car, and the car runs much better.
G Atsma (05-06-2021)
Old 05-07-2021, 02:58 PM
  #815
cam
cam's Avatar
Looking good, Give us some vids giddyup! yeehaw
Old 05-07-2021, 03:56 PM
  #816
LS1Tech Co-Founder
Will do
Old 05-16-2021, 07:15 PM
  #817
LS1Tech Co-Founder
Drove it half hour today, kept it very local (a big lot by my house).
No leaks, didn't lose any belts, coolant temps were okay.
Brakes were still soft so I'm going to take the car to a buddy's shop (need to call around to 2-3 I know) and pick one of them. If I pumped the brakes some they worked better, so maybe just still a bunch of air in them. I did my best on them, time for me to let someone else dial them in.
Old 05-16-2021, 07:51 PM
  #818
GMCGreg's Avatar
Been waiting to hear about the brakes , hope they can get them properly bled for you and the smaller bore master gives you an acceptable pedal effort
Old 05-16-2021, 11:50 PM
  #819
LS1Tech Co-Founder
Yeah a buddy of mine who I talk to a few times a week, former dealer tech, he thinks it might be a bad flare fitting or something, but I'm read to let a shop figure it out.
Car ran so solid I I just want to finish the street tuning with Andrew aka GottaGTO and make some real boost hits in this thing.
Old 05-17-2021, 12:20 PM
  #820
LS1Tech Co-Founder
Plan is for me to take it to my buddy's shop Pete's Auto Clinic, he's a great guy and drag races LS stuff.
Quick Reply: Project Hairy Banana (1967 Camaro single turbo)
