Project Hairy Banana (1967 Camaro single turbo)
Old 08-03-2021 | 05:08 PM
  #961
Pro Stock John's Avatar
LS1Tech Co-Founder
It had a stock trunk lid + spoiler when I first got it. I prefer the flat trunk look because '67 models never came with a spoiler. Plus this trunk lid is a Glasstek and lighter than stock. But I might try to paint it.
The following users liked this post:
The BallSS (08-04-2021)
Old 08-04-2021 | 10:03 AM
  #962
ryeguy2006a's Avatar
Glad you got it figured out John! Can you share some more pictures of the new shroud you had made?
Old 08-04-2021 | 04:12 PM
  #963
LS1Tech Co-Founder
Car is on the rollers today. At some point I'll go to a variable speed fan like Andrew and you are running.
G Atsma (08-06-2021)
Old 08-04-2021 | 05:15 PM
  #964
Shownomercy's Avatar
Man-Crush Warning
While not as fancy or as "right" a simple SSR brick wired up to run the fan and you can PWM the fan via holley.
Old 08-04-2021 | 07:27 PM
  #965
LS1Tech Co-Founder
My buddy has been driving the car around.
My quarters are stretched, this is a good shot of how 28s look on my car. I have a set of MT 295/65/15 DRs to swap on in the near future.
The following 2 users liked this post by Pro Stock John:
spray280 (08-05-2021), The BallSS (08-05-2021)
Old 08-04-2021 | 08:05 PM
  #966
LS1Tech Co-Founder
It's cooling, stopping, and they made 15 psi on the street today. Man all this progress in a week... shewwww buddy.
Old 08-04-2021 | 08:10 PM
  #967
3 window's Avatar
So go get the sumbitch and enjoy it!
Pro Stock John (08-05-2021)
Old 08-04-2021 | 11:28 PM
  #968
LS1Tech Co-Founder
Should have it back Friday.
Old 08-05-2021 | 11:53 AM
  #969
I'm going to steal that idea for my C7 fan. I have my fan bolted to my shroud, but I like how you have it all in essentially one piece. Thanks for posting the pictures!!
Old 08-05-2021 | 04:21 PM
  #970
LS1Tech Co-Founder
Yeah that's all Jay. He's got a buddy running a single Cruze fan in a 1970 Nova that cools great.
Old 08-06-2021 | 02:55 PM
  #971
LS1Tech Co-Founder
And... everything works!!!!!!!!!!
-Idling in the 180s in traffic... no words.
-Trans brake works
-Bump works
-Car has hit 14 psi on the street (big wide street in MI)
-Second pump (Weldon 2345A) some wiring fixed and it's doing it's job
I'm forgetting other stuff.
Big big shoutout to Jay Blanchard, JayWire Solutions in Western Michigan and Jon Capizzi for some boost tuning.
What I need to do:
-Swap WG springs to 7 lb springs, only builds 3 lbs on the current springs
-Swap ladder bars but I can f around with the current ones
-I am going to swap on the taller 295s
Thank you guys for the interest and help, Jamie, all you guys.
I feel like a 10 year old on Christmas morning.
The following 4 users liked this post by Pro Stock John:
3 window (08-07-2021), cam (08-10-2021), randeez (08-06-2021), spray280 (08-07-2021)
  #972
LS1Tech Co-Founder
The following 3 users liked this post by Pro Stock John:
C5_Pete (08-06-2021), gjohnsonws6 (08-06-2021), spray280 (08-07-2021)
Old 08-06-2021 | 05:26 PM
  #973
C5_Pete's Avatar
So happy to hear you got things all straightened out, John. Now, go enjoy it!
BTW, I like the “no spoiler” look.
Old 08-06-2021 | 06:20 PM
  #974
LS1Tech Co-Founder
Yeah I'm a big nerd for the no-spoiler look. Actually 1967 Camaros were not available with a spoiler but many folks added them.
Old 08-07-2021 | 06:04 AM
  #975
forcd ind's Avatar
Gotta be a good feeling knowing its ready to play, esp the engine temps, I would trade HP any day in exchange for a non overheating car, although mine is fine. Did they do anything special to the rad., or just fans.
Go have fun, report back, lol.
Old 08-07-2021 | 12:35 PM
  #976
LS1Tech Co-Founder
Yeah, my number one pet peeve are cooling issues. If I lived out in a rural area I'd probably not stress over it so much, but I live in actual Chicago about a mile from Wrigley Field.
Before the work, the car would get to 214 but would creep. When driving car was anywhere between 218 and 225 and I hit 230 twice.
-Northern dual pass radiator: He cut off and redid my lower bung (16AN). Wasn't leaking. I think he wanted a better angle. FWIW my core is 20.7 wide.
-1994 Contour/Taurus single 16" fan. He built a shroud that incorporates the fan and it's plastic shroud. The final shroud covers the entire core, where my old setup didn't cover the top 4 inches of the radiator. I asked the guys if they thought this fan was a keeper or I should change to something in the future. They think it's a a keeper.
-Stat. I have been running a gutted stat most recently, my car does no have heat. I also have the hose outlets removed on m 5th gen water pump and welded flush. He made (and now sells) a stat that includes a block-off. His comment, and I might be garbling it up, he wanted to block off the bypass, I will attach a pic.
-In the tune, the fan is coming on at 185. His buddy and mine Jon Capizzi did some WOT tuning and tweaked some stuff around cruise timing which we here on Tech talked about 2 weeks ago, I think the cruise timing is somewhere between 36-40 degrees, and the idle timing I'm not sure but probably somewhere around 22 but I can check.
-My Leash single relay was getting messed up, Jay notes that it's only a 30 amp piece. The solder was melting out of it. But the issue was my fan was running too hard that's why it got so hot and was burning stuff up. He's got an inline 40 amp blade fuse in there now.
forcd ind (08-08-2021), randeez (08-08-2021)
Old 08-07-2021 | 12:38 PM
  #977
LS1Tech Co-Founder
The stat with the block off, he sells them:
Old 08-07-2021 | 01:33 PM
  #978
GMCGreg's Avatar
Sounds good , quite a few changes to pinpoint which did the most but it doesn't matter now anyways 👍👍 any idea what the timing was like before?
Old 08-07-2021 | 01:34 PM
  #979
GMCGreg's Avatar
Glad to here you can get out there in it !!
Old 08-07-2021 | 04:35 PM
  #980
LS1Tech Co-Founder
I don't remember idle timing, cruise timing needed more.
Quick Reply: Project Hairy Banana (1967 Camaro single turbo)
