My first single turbo build
So, what do you think it'll run on 12psi?
to be exact, 7ish in 1st, 10psi in second and 12psi in third?
the 11.20 was with a leaking crossover due to a broken v band clamp. 7-8psi is what it would hold but drop off.
Same et and two mph. Ouch. You cut me deep. Lol
i don’t want a bunch of boost right at first. Trying to not break the engine, trans and axles.
Back then on the forums it was obvious the GTO owners were a different type of person for the most part than your average Fbody owner. That combined with the GTO not being a good drag car chassis and low aftermarket support led to disappointing track times for the mods/money.
This led anyone that actually put 1/4 times as a high priority to go with an fbody rather than a GTO.
Fast forward to today with falling prices and a different type of owner and more 8 second GTOs are popping up along with some possible 7 second cars that only run 1/8th mile. Certain comforts are given up to run those times which most Gto owners aren’t willing to do. Huron made a post about a possible kit for the gto and the comments seemed to push them toward dropping the idea.
Following in the Facebook gto group you will see some cam only cars in the 10’s and plenty of 9’s with spray, but you’ll also see plenty of big inch boosted motors running the same times. The fbody is certainly cheaper and easier to run 9’s or even 8’s, but if you show up with a gto you’ll likely be the only one there which has value to me.
The fbody is the better drag car by by a landslide, but it can be done with a gto with an owner that wants to put the focus on drag strip and spend the time/money to make it work. I don’t think a 5.3 works near as well in a heavy gto either. Most the fast GTOs have bigger inch motors and turbo, big prochargers, or lots of nitrous.
For now my car is about perfect for a street car around 650 rwhp, full weight with all the comforts of a 31,000 mile car. I do want a forged motor and a lot more boost to eventually run mid 9’s in a couple years though. I’d like to do it full weight driven to and from the track as well.
Im thinking some of the newer Camaro’s weigh as much as us with IRS and run good times. Again a more popular car with aftermarket support and guys spending big bucks to do it.
A clean gto can be had for 10-15 grand easily then another 25 to run 9’s while keeping it nice. So you’re still under 40g which is way cheaper than some of these late model cars. Sure they need less mods, but the $$$ are still there.
Ive never had someone tell me they don’t like my car. Not once. Maybe some jokers on the internet saying how heavy it is (they must live under a rock because most of the newer muscle cars weigh more, so why say that? Idiots I guess). I’ve never had someone say something bad about my car in person, should I say. In fact, just the opposite. I’ve had a couple people make me take their name and phone number in case I ever want to sell the car.
My 2011 1SS camaro (lightest version v8 you could get) weighed 4060lbs with me in it. Half tank of gas. I weigh 185. So yea, it weighs more than my gto. And the front suspension had a rattle in those cars from the factory that they never could fix.
